V5 Beta MOI 3D on MAC / PC April 2022 !
You must go there for a new beta of 6 NOV 2012 format SAT/IGES/STEP have some crashes!
9 nov 2012
Interview! of Michael Gibson the creator of Moi!He speaks also of Sketchup
Have you try that inside Moi3D?
CTRL + SHIFT + Click on the Options' icon? -
Beta V3 03 18 2013
(full detailed functions on the link -
Moi3D beta V3 first August 2013 (only for owners of the V2 ! )
News: Blend Multiple!Of course you can have any number! 3 to 5 for example!
No time for detail, I must load the trailer!
Moment of Inspiration the Zen Nurbs modeler
moi beta V3 19 Nov 2013 (only for owners of the V2)
The main new thing is hidden line removal when exporting to AI, PDF, and DXF formats.
Shift while drawing now works for an enhanced straight snap. When you hold down shift straight snap will have priority over object snap, and the current straight snap line will stay locked on for as long as you hold shift. Also when you hold down shift straight snap will activate to the closest straight snap line regardless of how far away it is to the mouse.AI format for clipboard transfer should work on on OSX.
Some bugs fixed in surface/surface intersection, some cases that didn't work before with things like 2 pipes crossing each other should work better now.
Layers are exported to DXF format
Bug fixes to Blend between 2 edges that touch each other at sharp "pole points", and to order sorting for loft to point.
Render with C4D
By Samardac -
With new export Ai
By Martin -
The complete list of new stuff of the Beta V3 of 19 November 2013
By Stefan -
For some customize of the UI, shortCuts plugins, Snapshots, Lightings... by Max Smirnov
You can put any numbers of librairies and any numbers of objects!
My little test !
Moi Beta V3 03 24 2014
Ok owners of the V2 can have variable fillets! -
April's Fish
Maybe ScriptArray can help for some many things! because basic Transform / Array / Circular has not Size parameter inside!
ScaleArray has not the rotationJust edit the header of the page for the 3 functions Move, Size, Rotate! (like Grow By TIG but some different
Draw original ellipse on Right View following your parameters : here movement will be on the X
Movement of the original on the X will be : 5, 10, 15,...
Size of the original will be on Y, Z : size y2 size z2, size y3 size z3, size y4 size z4,...
Rotation of the original will be: 10°, 20°, 30°...Advantage : you can input any formulas and parameters, any conditions... you want!
Beta v3 06 27 2014
For owners of a license
List of news -
Nice, my demo's just finished so I'm gonna buy a license. Great software and so easy to use.
Bienvenue au club!
cool feature!
Fx graph 3D by Max Smirnov
