[Plugin] Window Tools 1.1
Postby tomot » Tue Nov 25, 2008 2:10 am
I noticed some 300 downloads of Window Tools Ruby thus far. There has been little feedback as to how useful this tool is. I realize not everyone uses SketchUp for Architectural Design.
But after developing Door Tools I thought I would revisit Window Tools. To bring it in line with what I had learned creating Door Tools.
As a Designer/Builder/SketchUp users, I find it impossible to use SketchUp without a good layer Plan. Designing for Clients invariably requires changes. And its in this area that SketchUp is weak.
Making changes to an existing proposal at times can take more time than simply starting over. Hence I made the following changes to Window Tools:
1. Added a Layer option, all windows are drawn on a Window layer.
2. Added Wall thickness option, hence Windows will now cut automatically into any wall of a given thickness. This eliminates the need to establish an opening in a wall prior to installing Windows, as was the case with the previous version.
3. Added the global variable scheme similar to Door Tools.
4. Revised the Mullion tool, eliminated the superfluous surrounding frame.
If you think these added changes are worthwhile. Then follow the upgrade instruction in the WindowTools1.1.txt file included in the attached rar file. There is also there is a short video demo attached.
tomot
PluginStore Author
PluginStore Author
Re: [plugin] Window Tools 1.1
Postby dtrarch » Tue Nov 25, 2008 2:29 am
Hi Tomot
Very useful and your organization setup is right on.
Thanks a bunch
dtr Architect
dtrarch
Premium Member
Premium Member
Postby Jim » Tue Nov 25, 2008 4:31 am
Nice update, tomot. I just had a thought - for the mullions, would it be easier for the user to just click on the glass to add the mullions, instead of needing to define the rectangle? The window already defines the rectangle. So, select the mullion tool, and then click on the glass - done. Just an idea; not sure if it would work.
Jim
Global Moderator
Postby mattg » Tue Nov 25, 2008 12:50 pm
Tomot,
Thanks so much for the really useful tools, the update and the comprehensive intallation instructions.
I was just wondering how the update works if one is using your window tools as part of Cadfather's SCF toolbars.
Any difference, or do we just do the same as in the txt. file?
Cheers, and once again your efforts are greatly appreciated!
mattg
Postby gogo2suf » Tue Nov 25, 2008 2:47 pm
Thank you vary much Tomot.
It is so useful.
thank you so much.
Gogo
:berserk:
gogo2suf
Postby agrazdi » Tue Nov 25, 2008 3:40 pm
Great job
agrazdi
agrazdi
Postby CadFather » Tue Nov 25, 2008 5:16 pm
hi all
i'm working on the updates of the toolbars, so hold on a little bit more...
i've been told "i cannot spend 4 days and nights non stop on that computer" :oops:
Thank You Tomot - an even more powerful tool!
User avatar
CadFather
PluginStore Author
PluginStore Author
Postby tomot » Tue Nov 25, 2008 9:13 pm
I welcome all ideas, and anyone is welcome to make changes to Window Tools 1.1 or Door Tools.
Jim:
I like your idea, although at the moment I don't know how to implement your proposal either :)
pm me, maybe we can can come up with a solution.
CadFather:
I don't mind seeing an expanded Architect Tool bar with Window Tools 1.1 and Door Tools
being part of it......Go for it! ...... Just don't get me in trouble with your partner :)
tomot
PluginStore Author
PluginStore Author
Postby CadFather » Tue Nov 25, 2008 10:44 pm
tomot wrote: CadFather: I don't mind seeing an expanded Architect Tool bar with Window Tools 1.1 and Door Tools being part of it......Go for it! ...... Just don't get me in trouble with your partner :)
:lol: - Thanks Tomot! you will be the first to receive it if i do.. :fecstatic:
User avatar
CadFather
PluginStore Author
PluginStore Author
Postby 123zxy » Wed Nov 26, 2008 12:23 pm
Perdon, Pero hablo muy mal ingles:
Serian tan amables de comprimir el archivo en extension zip?
Gracias Carlos
123zxy
Postby Edson » Wed Nov 26, 2008 2:19 pm
123zxy wrote:Perdon, Pero hablo muy mal ingles:
Gracias Carlos
ahi lo tienes, carlos. there you have it, carlos.
edson mahfuz, architect | porto alegre • brasil
http://www.mahfuz.arq.br
User avatar
Edson
Global Moderator
Postby gksl4 » Wed Nov 26, 2008 6:09 pm
Very nice job,
Thanks,
George
gksl4
Postby decorarq » Wed Nov 26, 2008 10:30 pm
Muchas Gracias posting.php?mode=reply&f=180&t=14394# very easy to ese thanks a lot
decorarq
Postby Pixero » Thu Nov 27, 2008 6:05 pm
Does the new version also work as the old one? I mean adding windows to existion holes?
I usually use that method and if not, could you add both functionalities.
User avatar
Pixero
Postby tomot » Thu Nov 27, 2008 7:00 pm
There are only 2 lines of code I added in order to cut the opening,
which the previous version did not have. I was not able to make this
new script automatically recognize an opening from a face, at this time.
Hence if you prefer to use the opening method only, then remove the following 2 lines of code. from glass_tool.rb and frame_tool.rb
Code: Select all
#-------Cut Face
    base=entities.add_face(@pt0jj, @pt1jj, @pt2jj, @pt3jj)
    base.pushpull -$kqBC45
tomot
PluginStore Author
PluginStore Author
Postby arquitectomaracucho » Sat Nov 29, 2008 1:47 am
:thumb: :thumb: I am an architect and I feel very good improvement, is revolutionary, I can add options for example 2 windows or sliding panels swing, besides giving the same property of cutting tools wall to door. For the rest thank you very much! :sketchstatic:
User avatar
arquitectomaracucho
two version of mullion?
Postby deaneau » Sun Oct 31, 2010 12:27 pm
i have now two version of mullion, could you write the mullion.rb so that i have two version to choose in dropdown.
the new version looks like a windows in a yail ;-)
the first picture is the new mullion
thank you
dean
User avatar
deaneau
Re: [Plugin] Window Tools 1.1
Postby ReyT » Sat Feb 08, 2014 10:24 pm
Your trim tool both side option is not working.
ReyT
Postby gap007 » Sat Mar 01, 2014 3:26 am
I have installed New version Sketchup 2014 but your wiindow tools are not working!
Please let me know how to fix?
gap007
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Plugins
Who is online
Users browsing this forum: chouch94, Clementpret, KITTIROJ, lutfiparas, reta1239, tagiobon and 14 guests
