[Plugin] BezierSpline - v2.2a - 22 Apr 21
require 'sketchup.rb' begin require 'libtraductor.rb' # for language translation rescue end #Specify the two curve extensions: Bezier Classic and Polyline BZ____LIST = ["BZ__BezierClassic", "BZ__Polyline"]
10Q
OK, LibTraductor disabled. The rescue statement revised.
Upon opening SketchUp I still get the error:
%(#4000BF)[Error Loading File /Users/davidrichards/Library/Application Support/SketchUp 2013/SketchUp/Plugins/BZ_Dir_14/bezierspline_main.rb
uninitialized constant Bezierspline::BezierContext::Traductor
Error Loading File bezierspline.rb
Error Loading File /Users/davidrichards/Library/Application Support/SketchUp 2013/SketchUp/Plugins/JPP_Dir_20/jointpushpull_main.rb
no such file to load -- libtraductor.rb
Error Loading File jointpushpull.rb
no such file to load -- libtraductor.rb]Edit to add: After clicking OK, I see an entry for the BezierSpline toolbar but when I enable that toolbar it is blank with only space for one button.
Hi. Im having the same issue. Done all of the above and still crashes after a few curves. Anything else I can try?
Bloody well brilliant tool! Thank you so much!
I am struggling to work out how to install this onto my sketchup 8 system on a mac. any help would be much appreciated
Hi, Ross:
Did you read the advice for Mac users on the first page of this topic?
Alternatively, have you considered using the Sketchucation Plugin Store tool?
http://sketchucation.com/resources/plugin-store-download
At the top of this page, there is a selection called Resources and in the drop down is the link to the download.There may be some other issue, so post back for someone to assist.
Fantastic. I can finally get more segments and smooth bezier curves. Thank you!
Dear Fredo,
I got problems with Bezier spline 1.4f , when I use it sketchup 2013 always close it.
My OS is macos X 10.8.5 with sketchup 2013 (spanish) version 13.0.4811 on a MacBook Pro late 2 gh intel core i7
Can you help me.
Thank you and kind regards.
@oli_sketch said:
Dear Fredo,
Can you help me.
What he said. Please. This used to be my most commonly used extension.
There have been updates to fredos plugins to work with SU2013, make sure you have the latest versions including Libfredo
I installed Bezierspline v1.4 on my mac computer in SU2013. I really like the possibilities of this plugin but the point is that SU crashes after inserting a few bezier points.
I saw that this issue was discussed a few months ago by gig500 and dave R. Does anyone know if this problem is already solved?
Thanks in advance
NEW RELEASE 1.6a - 11 Nov 2013
This release is for future Sketchup compatibility
Download new release at main post
NEW RELEASE 1.6b - 12 Nov 2013
It also fixes some crashes encountered on some Mac OSX configuration and SU13.. Thanks to Dave R for helping me troubleshoot the issue.Download new release at main post
THX FOR THIS PLUGIN
Hi there
So I'm using this a lot, umm is there a way to 'disable' the initial [Uniform B-Spline] dialog (with the Order parameter), so it would stay at the default '0' / automatic, or whatever value [without the dialog]?
Cheers
Hi.
After reading gonashvili's post above, I opened Sketchup8 to test the spline. I placed an initial spline in an empty scene with 0 default setting. Then began to place another, but changed the parameter to 10 and OK. I got a bugsplat window. I captured the window and the response. Interestingly, I immediately repeated the process and got no error.
Sorry, if the two images appear out of order. The splat window is first and the response window is supposed to be second.Also, apology to gonashvili for jumping in here. I was simply investigating.
cool tools,Thx a lot.
I type radius 10 mm, but have 14,1. (sqrt200 )
Robert
NEW RELEASE 1.6c - 03 Mar 14
This release is fixes a bug in the TBone curves, found by Robert Wan.
Remember also that v1.6 is necessary for SU14 and fixes some crashes encountered on some Mac OSX configuration and SU13..Download latest release if BezierSpline at main post
