[Plugin] Manifold v2.2
Re: [Plugin] Manifold v2.2
Postby TIG » Fri May 25, 2012 12:56 pm
It works on a copy of the original group that it has made and offset to one side.
The third 'error group' [if any] simply highlights these errors and it is overlaid onto the original group...
However... please note that this particular 'Manifold' tool is a slow old crock and it has long been superseded by some newer better things... so I no longer 'support it'...
Thomthom's 'SolidInspector' shows where errors occur that are causing non-solidity.
My newer 'SolidSolver' tries to fix them [affecting the original, but 'undo-able'].
There are also one or two other tools that try to do this kind of thing too...
I recommend you get those and retry.
User avatar
Global Moderator
Postby tarzip86 » Thu Aug 01, 2013 8:05 am
Works brilliantly for my purposes. Cheers!
tarzip86
Postby WorldWiz » Thu Oct 03, 2013 8:19 pm
While this plugin is running, does it get interrupted if my computer goes into standby mode?
WorldWiz
Postby TIG » Thu Oct 03, 2013 9:47 pm
WorldWiz wrote:While this plugin is running, does it get interrupted if my computer goes into standby mode?
I really don't know. :?
BUT there are now several better tools like SolidSolver and SolidInspector anyway :roll:
User avatar
Global Moderator
Postby ladyquestio » Wed Nov 15, 2017 5:04 am
Using version 8 free BTW
I have been trying to make use of this plugin. But it does not seem to work . I am getting an error message when i look in console
here is a copy of the messages i get .
manifold
Error: #<TypeError: wrong argument type (expected Sketchup::Entity)>
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/manifold.rb:199:in `add_group'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/manifold.rb:199:in `copy_group'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/manifold.rb:142:in `activate'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/manifold.rb:1039:in `select_tool'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/manifold.rb:1039:in `manifold'
(eval):42
#<Sketchup::Model:0xcf41cb0>
Can you look and tell me where the error is ?
ladyquestio
Postby TIG » Wed Nov 15, 2017 2:02 pm
This is a very old Plugin.
It has issues with all current versions, and v8 which is no longer supported...
I suggest you try my SolidSolver or thomthom's SolidInspector² ?
User avatar
Global Moderator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Previous
Return to Plugins
Who is online
Users browsing this forum: delusion89, JeanDoduhan and 9 guests
Visit our sponsors:
