[Plugin] KML Tools (2.0.0-beta) — updated 31.05.2013
Re: [Plugin] KML Tools (2.0.0-beta) — updated 31.05.2013
Postby Kromaggs » Thu Jul 18, 2013 11:27 am
I'm using Bash under Window to dynamically generate a ruby script. This script allow me to import a specific KML file in sketchup and when the import is done I would like to export my model to KMZ file. This is an extract of my ruby script
Code: Select all
   # Impport du modèle KML.
   model = Sketchup.active_model
   status = model.import inKML, false
   if status
      # Suppression du modèle KML importé.
      #File.delete( inKML )
      # Export du modèle au format KMZ.
      modelFile=File.basename( inKML, ".kml" )
      exportPath = exportDir + modelFile + ".kmz"
      model.export exportPath
      model.entities.clear!
      #Sketchup.undo
      #Sketchup.app_safe_shutdown
But the import KML plugin seems to give back the control to my script while importing, so the exported KMZ is not complete because the KML is not completely imported.
Any idea about this problem ?
Kromaggs
Postby organicmotion » Sun Oct 20, 2013 1:43 am
"File seems not to exist.
Please check that the file path does not contain Unicode characters. This is a limitation of SketchUp and its Ruby version."
Am I doing something wrong? Took the KMZ file from gps opened in Google earth saved as KML then tried to import into SU with the KMLtools and I get the error above..
any ideas anyone? Thanks, I am a beginner with SU :)
organicmotion
Postby truga » Wed Mar 12, 2014 12:38 pm
It appears that KML Tools are not yet compatible with 2014. I get the message:
Error Loading File kmlDate.rb
Error: #<SyntaxError: C:/Users/truga/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/kmlDate.rb:77: formal argument cannot be a global variable
...previewTimeLine") {|$kmlDateDlg, param|
etc.
truga
Postby borrel » Fri Mar 21, 2014 1:54 pm
organicmotion wrote:"File seems not to exist.
I am getting the same problem (Mac OSX 10.9.2) with v 2013 and 2014 - with Google SketchUp 8.0.15157 - the old version works fine. Sad, because SU is a great tool for visualization AND a converter to make X3D files from GPS-GPX tracks thus: GPS tracker > GPX > KML (gpsbabel or GPS Viz) > SKP > VRML (WRL) > X3D (via aopt). See the models here: http://abdallah.hiof.no/drone/index.html
borrel
Postby Gorin21 » Thu Jul 10, 2014 8:33 am
great job with the plugin! I would like to know, if the functionality of adding timestamps can be included in next release? In 2.0 beta there is none, in the previous stable version, there is availability to add a timestamp.
Thanks for the reply,
Paul
Gorin21
Postby BIANI patrick » Tue Sep 09, 2014 8:33 am
Sir, would it be possible to have a detailed using your KML exporter of interesting tutorial.
I would like to export animations 'Keyframe' to Google earth to animate a plane flight or a vehicle path, but do not have your talent developer, looking for a simple tool that can help me in this regard,
thank you for your attention.
Patrick
patrickbiani13@gmail.com
http://www.wix.com/patrickbiani13/scan-service
BIANI patrick
Postby BIANI patrick » Tue Sep 09, 2014 9:08 am
Sir, I have installed your update (SketchUp 8 Pro), but I can not find anywhere in the menu can add Timespan, thank you for your help
BIANI patrick
Postby Antimo98 » Mon Oct 05, 2015 6:22 pm
I use SketchUp 2014.
The file (attached) contains an image and a single poligon realized and exported in KML by Google Earth
When I run the kml tools for any files .kml everywhere it is in PC (c:, Desktop, other directory) always it says:
1) "the model does not contain a Google Earth terrain. Do you want import one first , Yes No"
in both cases
2) "File seems non to exist. Please check the file path does not contain Unicode characters. This is a limitation of SketchUp and its Ruby version."
Where is the problem?
Thank you for all contributions.
Regards
Antimo
Antimo98
Postby balique_bap » Thu Mar 24, 2016 1:47 pm
Post to be deleted.
balique_bap
Postby balique_bap » Thu Mar 24, 2016 2:12 pm
Antimo98 wrote:I use SketchUp 2014.
in both cases
Regards
Antimo
I have the same issue.
Has anybody found a solution ?
Thank you very much,
Baptiste
balique_bap
Postby usablake » Wed Oct 25, 2017 12:48 am
Sweet plugin, any plans for an update to use with new versions?
usablake
Postby PatrickBiani » Wed May 09, 2018 12:11 pm
Hello, I'm looking for a tutorial explaining in detail how the "TimeSpan" plugin works, thank you in advance and good luck
PatrickBiani
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Previous
Return to Plugins
Who is online
Users browsing this forum: Bing [Bot], fredo6, Peter Ustinov, suncaP and 9 guests
Visit our sponsors:
