[Plugin] Perpendicular Face Tools (UPDATED 26-03-09)
Re: [Plugin] Perpendicular Face Tools (UPDATED 26-03-09)
Postby Box » Sat Mar 16, 2013 10:28 am
TS200010 wrote:Just installed them - however, no icons on the buttons and an almost immediate Bug Splat. Lost all my work.
This suggests you installed the plugin while working on a file.
Generally speaking you should install plugins with SU closed, or at the very least close and reopen SU before using the plugin for the first time.
Also worth trying it out on a junk file before anything important.
So having said that, if you did install it with SU open, try installing it again with SU closed.
User avatar
Postby Dave R » Sat Mar 16, 2013 1:39 pm
TS200010 wrote:Dave,
Thanks - I am a RubyNewbe ... there were no installation instructions so I just guessed - apparantly incorrectly.
There are multiple threads here explaining how to install plugins. The basic thing which would apply to any ZIP folder is to maintain the file structure as shipped in the compressed folder.
Since the icons don't appear on the toolbar, it is safe to assume that the icon images are not in the colder called clf_perpendicular_face_tools which is where the related loader file would be looking for them. If you didn't keep those image files in that folder, you probably also don't have clf_perpendicular_face_tools.rb in that folder either.
You should explore through the Plugins folder and find the .rb and the six image files and put them where they belong. It would probably be easier to delete those files and reinstall the plugin correctly. I wopuld suggest you download and use 7-zip to do this. It won't destroy the folder structure as the Windows native unzipper is wont to do.
User avatar
Global Moderator
Postby Chris Fullmer » Sun Mar 17, 2013 4:47 am
I also have problems with winzip destroying the folder structure, depending on the winzip version. Also from what I understand Macs add an extra folder to the mix. For most of my plugins, I have a single file that just goes into the plugins folder. If there are additional files, they get loaded into a subfolder.
User avatar
SketchUp Team
SketchUp Team
Postby HornOxx » Thu Jun 20, 2013 10:11 am
Great - Thank you so much !!!
I discovered this great tool so late :)
User avatar
HornOxx
Postby stpauljason » Mon Jul 01, 2013 3:32 am
Chris,
I love your plugins.
However I've just recently added your plugins (Extended Views and Perpendicular Faces to Sketchup 2013. When I check the box for the toolbars, they seem to create a unique toolbar just below the normal context menu (File, edit, etc). This toolbar is hidden if any other toolbar is there, and the unique toolbar can not be moved. Additionally only one of the toolbars either Exteneded Views, or Perpendicular Faces displays at one time, hiding the other one.
stpauljason
Postby thomthom » Mon Jul 01, 2013 9:10 am
Jason: That's a bug in the first release of SketchUp 2013 - install the update that was released some weeks ago and it should work fine.
User avatar
PluginStore Author
PluginStore Author
Postby vojo » Mon Jul 01, 2013 4:06 pm
I want to take a quick minute to point out that this plugin works VERY WELL.
I have not had one problem with this and have used it quite extensively.
This is a plugin I would recommend
vojo
Postby stpauljason » Mon Jul 01, 2013 8:10 pm
Thanks Thomas,
I updated Sketchup 2013 and the plugin has its own toolbar now.
stpauljason
Postby Hammerhead64 » Thu Nov 14, 2013 11:52 am
Chris this is such a good tool, I have spent years using a combination of the standard tools in SU to get elements perpendicular to a path. Thx for sharing.
....... Quicker models here I come.
Hammerhead64
Postby gonashvili » Wed Dec 11, 2013 4:49 pm
Just wanna say that this plugin is them bananas. Super, SUPER useful.
Cheers.
User avatar
gonashvili
Postby sicksickisck » Thu Oct 16, 2014 9:22 am
still does not work inside a component
User avatar
sicksickisck
Postby cotty » Thu Oct 16, 2014 9:29 am
sicksickisck wrote:still does not work inside a component
What do you mean here? Do you have an example?
User avatar
cotty
Top SketchUcator
Postby Dave R » Thu Oct 16, 2014 10:12 am
Yes. What do you mean? I just tried it and it works fine inside a component. I made a component of the Bezier curve, opened the component for editing and ran the tool. It put the face on the end where I clicked.
User avatar
Global Moderator
Postby djohnson.nz » Wed Oct 18, 2017 12:31 am
Thanks Chris, extremely useful time saver.
I did have trouble creating a circle in a group, it didn't seem to work but after closing the group I found the circles outside the group. I was able to remedy this by changing your "Perpendicular Circle" script to read entities=model.active_entities which I found was the only thing different from your Perpendicular Square script.
Thanks for all your great work...
nO fiKst ideas
User avatar
djohnson.nz
Postby designerbursa » Wed May 22, 2019 12:11 pm
still does not create circles of less than 30 mm
I'm working in mm, 2540 is the default by default.
Changed by changing the r.b code
thanks for the plugin
my edit:
def activate
@ip = Sketchup::InputPoint.new
@iptemp = Sketchup::InputPoint.new
@displayed = false
@sp = []
@end_pos = []
@ctrlflag = 0
@group = nil
if @@ls.to_s == ""
@@ls = 100.mm
Sketchup.set_status_text @@ls.to_l, SB_VCB_VALUE
Sketchup.vcb_label = "Face Width x Height"
User avatar
designerbursa
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Previous
Return to Plugins
Who is online
Users browsing this forum: iketutrudi, Meck22, meirin177, RafaVictoria and 11 guests
Visit our sponsors:
