Hi fellow sketchupians.
I am about to model this building in Norway:
http://tinyurl.com/cncqch5
My question is, would you do this as one, or more buildings for google earth?
One or more buildings
• Page 1 of 1
Re: One or more buildingsThat's a whole block. According to the SketchUp to Google Earth modelling guide lines, each building in the block should be a separate model to submit.
You can model them together however (best practice to keep the buildings perfectly aligned) but make each building a separate component. Once done, go to the Component browser and right click on each component (the whole buildings only, if you use nested subcomponents) and "Share component" from there. They will now be shared and uploaded separately. Re: One or more buildingsThanks!
One thing tho, that is not very visible from the photo. The "Center" of this blosck is raised. The whole inner of the block is raised to a second floor. Does this change your previous answer? Re: One or more buildingsWell, here is the guide line for the individual buildings:
http://support.google.com/sketchup/bin/ ... er=1267399 Then you can also add a (small) "terrain skirt" (which I would use for that central area if it is only raised and not a building like a garage): http://support.google.com/sketchup/bin/ ... wer=167465 But make sure that small is small. Like it should not extend out of the yard in your case, I guess. Here is the guide line: http://support.google.com/sketchup/bin/ ... er=1267403 And all the guide lines: http://support.google.com/sketchup/bin/ ... er=1267260
• Page 1 of 1
