SketchUp Command Line Switches
Postby Jim » Sat Feb 02, 2013 10:48 pm
From this topic, here's a few command-line options for SketchUp.
$ Sketchup.exe [opts] [file.skp]
Where [opts] are:
-DisableRubyAPI
-RubyStartup "/path/to/ruby.rb"
-template "/path/to/template.skp"
-notemplate
-page "Scene1"
-timing
These may be options, but I haven't been able to verify they work:
-DisableAutoSave
-DisableWarnIfReadOnly
-thumbnail
-thumbprefs
Jim
Global Moderator
Re: SketchUp Command Line Switches
Postby driven » Sun Feb 03, 2013 12:07 am
cheers Jim,
on a mac, because of the ridiculous Google Folder you need to use, unless you add it to the ~.profile
/Applications/Google\ SketchUp\ 8/Sketchup.app/Contents/MacOS/SketchUp -DisableRubyAPI
anyway, that one works...
EDIT: it seems to work [as in it starts SU], but when you actually click SU, it continues loading, including the Plugins...
driven
PluginStore Author
PluginStore Author
Postby Jim » Sun Feb 03, 2013 12:27 am
Oh, that one might use a / (slash) instead of a - (dash)
Jim
Global Moderator
Postby Aerilius » Sun Feb 03, 2013 12:40 am
-lang ru
where the language is exactly the name of the localization folder in the resources directory. For example create a new folder of your favorite dialect (pfl) and load it with -lang pfl. It seems that eastern asian languages need also a special SketchUp.exe binary.
Aerilius
PluginStore Author
PluginStore Author
Postby driven » Sun Feb 03, 2013 12:48 am
knew I'd seen it before, needs a boolean
cd /
Applications/Google\ SketchUp\ 8/SketchUp.app/Contents/MacOS/SketchUp -DisableRubyAPI YES
driven
PluginStore Author
PluginStore Author
Postby TBoy » Sat Apr 29, 2017 4:50 pm
Is it possible to start Sketchup with different location for plugins folder. For example - a thumbdrive or "disk name/MyFavoritePluginsFolder" ?
TBoy
Postby TIG » Sun Apr 30, 2017 1:05 pm
SketchUp always includes its own Tools folder [and the nested Ruby folders] and your user Plugins folder in it load-path [$:]
You can include addition plugins folders in the load-path array, and any scripts in there will load as SketchUp starts.
Fredo wrote a clever extension to do this for you.
https://sketchucation.com/pluginstore?p ... ginFolders
Read its More Info... pages for usage etc...
User avatar
Global Moderator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Developers' Forum
Who is online
Users browsing this forum: ken yamasaki, stephane7429 and 7 guests
