[Plugin] BezierSpline - v2.1a - 01 Nov 18Re: [Plugin] BezierSpline v1.4f - 23 Jan 11 (upgrade SU8)In using the Classic Bezier Curve, I tried to change segments from 20s to 6s but doesn't seem to want do that and pressing tab doesn't seem to bring up anything obviously I'm missing something here I'm sure maybe someone can help. Thanks
2011 iMac
SU 2015 Pro, 2017 Make V2 Twilight macOS Sierra 10.12.5
i'm not 100% sure of the # with classic bezier but i do know that if you're using a uniform B-spline, the lowest acceptable amount of segments is 15s (and if you enter something lower, it will still be 15 segments) [EDIT]-- with classic bezier curves, the lowest acceptable # is 7 dotdotdot
Re: [Plugin] BezierSpline v1.4f - 23 Jan 11 (upgrade SU8)Thanks Jeff will try that
2011 iMac
Re: [Plugin] BezierSpline v1.4f - 23 Jan 11 (upgrade SU8)Thank you Fredo, a most excellent plugin and easy to use!
Re: [Plugin] BezierSpline v1.4f - 23 Jan 11 (upgrade SU8)Is anybody using this plug in on Mac Sketch Up Pro2013? My plugin crashes after a few seconds....
Re: [Plugin] BezierSpline v1.4f - 23 Jan 11 (upgrade SU8)Have you got the latest files and the latest LibFredo...
Which was recast for v2013 compatibility. Also do you have any other know problem tools loading like Vray-beta ?? TIG
Re: [Plugin] BezierSpline v1.4f - 23 Jan 11 (upgrade SU8)I've been using BZ_Spline tools on Mac in SU2013 with no problems. I do have the latest version of LibFredo6.
I wonder if you have a permissions issue. Revised: It seems to work fine unless I try to use a number of tools from the toolbar in succession. Even just switching tools seems to cause a crash. I hadn't ever had an occasion to do that in my normal workflow so hadn't seen it. It doesn't seem to throw any Bug Splats, either. Etaoin Shrdlu
% (THERE'S NO PLACE LIKE) G28 X0.0 Y0.0 Z0.0 M30 %
Re: [Plugin] BezierSpline v1.4f - 23 Jan 11 (upgrade SU8)library and all that - downloaded from the store, so all new...Tried to delete and reinstall - the same thing.Without changing tools, just a few curves on a blank file, sometimes less than a complete curve - bugsplat. I am attaching a screen shot of plug ins - maybe you see something that I do not. Permissions are all the same for other plugins,including Fredos, so should not be an issue. His other plugins work just fine, no crashes.
Re: [Plugin] BezierSpline v1.4f - 23 Jan 11 (upgrade SU8)You have a wrong installation
jointpushpull_main.rb should be in JPP_Dir_20, NOT in the main SU Plugins directory. Fredo
Re: [Plugin] BezierSpline v1.4f - 23 Jan 11 (upgrade SU8)You are right. I moved it. Bezier lasted this time for maybe 8 curves, then bugsplat:(((
Re: [Plugin] BezierSpline v1.4f - 23 Jan 11 (upgrade SU8)Fredo, I'm seeing the same thing on my Mac. I successfully drew 5 Bezier curves but while drawing the 6th, SketchUp crashed without a Bug Splat.
Re: [Plugin] BezierSpline v1.4f - 23 Jan 11 (upgrade SU8)I am attaching a new screen shot - got rid of all plugins but native sketch up and bezier. Still Crashes!
Re: [Plugin] BezierSpline v1.4f - 23 Jan 11 (upgrade SU8)What is the FULL path to that Plugins folder ?
You leak out the story drip by drip... ![]() TIG
Re: [Plugin] BezierSpline v1.4f - 23 Jan 11 (upgrade SU8)the normal for mac:library/application support/sketchup2013/plugins/
Everything else works. And Dave R apparently encountered the same thing...I got rid temporarily of other plugins to make sure they do not affect that one. No change. Re: [Plugin] BezierSpline v1.4f - 23 Jan 11 (upgrade SU8)@gigi500, @Dave,
Not sure what it can be and why it appears now (I did not change anything to the plugin for a while). Since you have a deterministic crash situation (after a few curve), would you mind to remove the file LibTraductor.rb (or rename it .rb!). Since you have LibFredo6 installed, it should be harmless. Fredo
Re: [Plugin] BezierSpline v1.4f - 23 Jan 11 (upgrade SU8)I disabled LibTraductor.rb and opened SU. I got the following:
I do have the most recent LibFredo6 installed. Etaoin Shrdlu
Re: [Plugin] BezierSpline v1.4f - 23 Jan 11 (upgrade SU8)Dave,
But do you still get BezierSpline loaded? And if so, do you get the crash? Fredo
Re: [Plugin] BezierSpline v1.4f - 23 Jan 11 (upgrade SU8)No. With LibTraductor disabled I don't get BezierSpline loaded at all. No option for toolbar nor any menu entry.
My mistake, You should replace the statement rescue by rescue LoadError on line 35 of bezierspline_main.rb. This will allow checking for potential conflicts ebtween the old version (libTraductor.rb) and the new one embedded in LibFredo6. If you still get a crash, then it is something else Fredo
Re: [Plugin] BezierSpline v1.4f - 23 Jan 11 (upgrade SU8)I can't easily see line numbers. "rescue" appears several times. Could you give me a bit of surrounding text?
There's a frontroom and a backroom....reverse faces
Re: [Plugin] BezierSpline v1.4f - 23 Jan 11 (upgrade SU8)10Q
Re: [Plugin] BezierSpline v1.4f - 23 Jan 11 (upgrade SU8)OK, LibTraductor disabled. The rescue statement revised.
Upon opening SketchUp I still get the error: Error Loading File /Users/davidrichards/Library/Application Support/SketchUp 2013/SketchUp/Plugins/BZ_Dir_14/bezierspline_main.rb uninitialized constant Bezierspline::BezierContext::Traductor Error Loading File bezierspline.rb uninitialized constant Bezierspline::BezierContext::Traductor Error Loading File /Users/davidrichards/Library/Application Support/SketchUp 2013/SketchUp/Plugins/JPP_Dir_20/jointpushpull_main.rb no such file to load -- libtraductor.rb Error Loading File jointpushpull.rb no such file to load -- libtraductor.rb Edit to add: After clicking OK, I see an entry for the BezierSpline toolbar but when I enable that toolbar it is blank with only space for one button. Etaoin Shrdlu
Re: [Plugin] BezierSpline v1.4f - 23 Jan 11 (upgrade SU8)Hi. Im having the same issue. Done all of the above and still crashes after a few curves. Anything else I can try?
Re: [Plugin] BezierSpline v1.4f - 23 Jan 11 (upgrade SU8)Bloody well brilliant tool! Thank you so much!
![]() ![]() Re: [Plugin] BezierSpline v1.4f - 23 Jan 11 (upgrade SU8)Hi,
I am struggling to work out how to install this onto my sketchup 8 system on a mac. any help would be much appreciated ![]() Re: [Plugin] BezierSpline v1.4f - 23 Jan 11 (upgrade SU8)Hi, Ross:
Did you read the advice for Mac users on the first page of this topic? Alternatively, have you considered using the Sketchucation Plugin Store tool? http://sketchucation.com/resources/plug ... e-download At the top of this page, there is a selection called Resources and in the drop down is the link to the download. There may be some other issue, so post back for someone to assist. I take the slow, deliberate approach in my aimless wandering.
Re: [Plugin] BezierSpline v1.4f - 23 Jan 11 (upgrade SU8)Fantastic. I can finally get more segments and smooth bezier curves. Thank you!
Who is online
Users browsing this forum: FRANCISCO QUINTERO, hoquoctuan123 and 9 guests
