[Plugin] Curvizard - v2.4b - 10 Feb 20
Re: [Plugin] Curvizard 1.0c - 11 Jul 12
Postby smicha » Sat Aug 25, 2012 9:38 am
This plugin is so useful! Thank you so much.
smicha
Postby Ricalbur » Sat Aug 25, 2012 3:56 pm
Thank you for this post
Ricalbur
Postby guanjin » Sun Sep 09, 2012 6:04 pm
Hello:Fredo6
Translated language files, and can not be changed!
User avatar
guanjin
Postby blajnov » Sun Oct 14, 2012 12:00 pm
Thanks for the plugin!!!
Translation into Russian...
blajnov
Postby cotty » Sun Nov 25, 2012 8:52 am
I've seen the new features of V1.1 on youtube, can't wait to try ;-)
User avatar
cotty
Top SketchUcator
Postby JClements » Sun Nov 25, 2012 5:37 pm
I saw the You-Tube demo too. Very interesting!
User avatar
JClements
Premium Member
Premium Member
Re: [Plugin] Curvizard 1.1a - 28 Nov 12
Postby fredo6 » Wed Nov 28, 2012 11:17 pm
NEW RELEASE: Curvizard v1.1a - 28 Nov 12
Curvizard 1.1 is an interim version which introduces 3 new functions:
  • Smooth Contour, with 2 methods and several options for adjustments
  • Cleanup Contour, which just removes collinear edges and small spikes
  • Change Edge properties, which allows modifying properties such as Smooth, Soft, Hidden and Cast Shadows of selected edges
There is now some rudimentary error checking when you select contours (needle eyes and spines). This is also applicable to Curviloft.
There is a video for the Smooth Contours function
Curvizard 1.1 requires an upgrade to LibFredo6 4.7 or higher.
User avatar
PluginStore Author
PluginStore Author
Postby Rich O Brien » Wed Nov 28, 2012 11:22 pm
Wow....thanks Fredo
There's a frontroom and a backroom....reverse faces
User avatar
Rich O Brien
Administrator
Postby utiler » Thu Nov 29, 2012 2:51 am
Double WOW!!! Thank you Fredo. I can't say enough about what you contribute to my SketchUp workflow....! :thumb: :thumb: :thumb:
purpose/expression/purpose/....
User avatar
utiler
Top SketchUcator
Postby guanjin » Thu Nov 29, 2012 2:59 am
Thanks for update again, but the language translation problems still exist, thank you!
User avatar
guanjin
Postby pilou » Thu Nov 29, 2012 4:00 am
Research of the perfect voluptuous inaccessible curves! :enlight:
Speedy Galerie
User avatar
Top SketchUcator
Postby pbacot » Thu Nov 29, 2012 4:51 am
Thank you Fredo! This looks fantastic. Thanks for everything...looking of Donate button.
MacOSX Mojave High Sierra SketchUp Pro v19 Twilight v2 Thea v2 PowerCADD
User avatar
Top SketchUcator
Postby cotty » Thu Nov 29, 2012 9:20 am
Thank you not only for the impressive plugin, but also especially for the excellent and detailed documentation (PDF)!
User avatar
cotty
Top SketchUcator
Postby fredo6 » Thu Nov 29, 2012 10:16 am
guanjin wrote:Thanks for update again, but the language translation problems still exist, thank you!
Thanks for signaling the bug. I fixed it and will republish.
But before I do, do you have the Curvizard_ZH.lang file so that I integrate it in the release.
User avatar
PluginStore Author
PluginStore Author
Postby guanjin » Thu Nov 29, 2012 2:57 pm
Dear Fredo6: Chinese language file has been sent to your mailbox, please find Thank you!
User avatar
guanjin
Postby Oxer » Thu Nov 29, 2012 4:03 pm
Thanks Fredo for the update it's very useful !! :thumb:
The problem with the translation continues and missing some translations. I have done the Spanish translation (Spain) but how i say you there are missing translations.
Thanks again Fredo.
Curvizard_SP.lang
User avatar
Oxer
Postby fredo6 » Thu Nov 29, 2012 6:04 pm
Oxer wrote:The problem with the translation continues and missing some translations. I have done the Spanish translation (Spain) but how i say you there are missing translations.
Oxer,
Thanks very much for the update.
Note that part of the transaltion is in LibFredo
The issue with the translation effective in the Luancher and tooltips of the main icons will be fixed in release 1.1b.
User avatar
PluginStore Author
PluginStore Author
Re: [Plugin] Curvizard 1.1b - 29 Nov 12
Postby fredo6 » Thu Nov 29, 2012 7:08 pm
NEW RELEASE: Curvizard v1.1c - 29 Nov 12
Minor release over 1.1a:
  • fix a problem in Cleanup Contour which cannot be launched
  • fix to a problem for translation for the Quick Launcher
  • Integration of Chinese translation (guanjin)
  • Update to the Spanish (Spain) translation (Oxer)
User avatar
PluginStore Author
PluginStore Author
Re: [Plugin] Curvizard 1.1c - 29 Nov 12
Postby Oxer » Thu Nov 29, 2012 7:23 pm
Thanks Fredo!!
User avatar
Oxer
Postby Arc » Fri Nov 30, 2012 11:22 am
Translation into Chinese...
Curvizard_ZH.lang
User avatar
Arc
Postby smicha » Sat Dec 01, 2012 2:26 pm
Fredo, You are genius!!! Thank you so much for fantastic update.
smicha
Re: [Plugin] Curvizard 1.1d - 05 Dec 12
Postby victor hugo » Fri Dec 07, 2012 9:17 am
Pretty useful plugin!!!
I've downloaded the update 1.1c and installed per instructions and when I go to "Fredo tools" to "Check the Plugin Update"; Curvizard still shows in pink/red. I re-downloaded the file and it keeps saying I need to do update!!!??
Thanks.
victor hugo
Postby cotty » Fri Dec 07, 2012 9:20 am
1.1c or 1.1d?
User avatar
cotty
Top SketchUcator
Postby victor hugo » Fri Dec 07, 2012 9:29 am
I had 1.1c and just did 1.1d and the attched is what is showing
Thanks.
victor hugo
Postby cotty » Fri Dec 07, 2012 10:34 am
You are right, it seems that in the 1.1d file "Curvizard.plugin" the version is still 1.1c ...
User avatar
cotty
Top SketchUcator
Postby guanjin » Fri Dec 07, 2012 5:59 pm
cotty wrote:You are right, it seems that in the 1.1d file "Curvizard.plugin" the version is still 1.1c ...
I am also, but does not affect use.
User avatar
guanjin
Re: [Plugin] Curvizard 1.1e - 07 Dec 12
Postby small08 » Sat Dec 08, 2012 12:41 am
Amazing work Fredo, Thank-you!
small08
Postby matt.gordon320 » Mon Dec 10, 2012 10:59 pm
Hi Fredo,
I was wondering if you might be able to take a look at my office's model to see what might be causing the error(s) I'm getting? I've attached both the model and the error report.
Matt
matt.gordon320
Premium Member
Premium Member
Postby TIG » Mon Dec 10, 2012 11:18 pm
Matt
What are you trying to do when you get the error message ?
Your post is too scant. :?
User avatar
Global Moderator
Postby matt.gordon320 » Mon Dec 10, 2012 11:40 pm
My apologies, my message is absolutely lacking in any detail :oops:
I've brought in a dwg containing topographic information from a civil consultants's office, and I'm trying to use Curvizard to simplify the contours. When I do, the interface of SketchUp pauses for a second, then comes up with an error message window containing the information in the attached text report. I can't quite figure out what the error is, or whether it's something that I introduced through cleaning up the DWG, or whether it's something that is just lost in translation from AutoCAD => SketchUp.
Hope that's better :)
Matt
matt.gordon320
Premium Member
Premium Member
by Ad Machine » 5 minutes ago
Ad Machine
Robot
PreviousNext
Return to Plugins
Who is online
Users browsing this forum: imerino488, jweaver100, kyb3683, nicolettasantelli, saradhisravan, sergavstr and 10 guests
Visit our sponsors:
