by Dave R » Fri Sep 21, 2012 9:05 pm
If someone gives up on a plugin or anything else because it doesn't give them the results they want and without reading the instructions, they deserve what they get. As to remembering the setting, it does for the current SketchUp setting. If you close SketchUp and reopen it, the default offset will return to the ~39-3/8" (1 meter).
- Global Moderator
- Name: Dave R
- Operating system: Windows
- SketchUp version: 2021
- License type: Pro
- SketchUp use: woodworking
- Level of SketchUp: Advanced
by bagatelo » Thu Sep 27, 2012 9:27 pm
Please consider these improvements....
bagatelo
- Name: Alex Henrique
- SketchUp version: 2015
- License type: Pro
- SketchUp use: interior design
by gullfo » Thu Sep 27, 2012 10:21 pm
with the large number of profiles you should just get profile builder full version. works awesome... then hide the joining lines if you need it to blend in.
gullfo
- Name: Glenn Stanton
- License type: Pro
- SketchUp use: architecture
by bagatelo » Thu Sep 27, 2012 11:02 pm
gullfo wrote:with the large number of profiles you should just get profile builder full version. works awesome... then hide the joining lines if you need it to blend in.
I had already thought of this possibility before. And I am currently trying this. Is proving very interesting. But as the fantastic plugin "Round Corner" perhaps it would be interesting just the possibility that we can create and edit our own profiles.
bagatelo
- License type: Pro
by fredo6 » Thu Sep 27, 2012 11:32 pm
Bagatelo The interest of RoundCorner is actually fro corners with 3 edges or more. For simple profiling, ProfileBuilder or even the Follow tool can make the job. RoundCorner can actually support custom profiles but they have to be symmetric in order to have a correct jonctions at corners with 3 edges. See this post and attached file for an example. RoundCorner with custom profiles.skp RoundCorner Custom profiles.png I did not activate the functionality as this needs some work for profile selection. But if there is enough interest I can do it. Fredo
- PluginStore Author
- Name: Fredo6
- License type: Pro
- Level of SketchUp: Intermediate
by bagatelo » Fri Sep 28, 2012 12:02 am
Fredo6 wrote:I did not activate the functionality as this needs some work for profile selection. But if there is enough interest I can do it. Fredo
I'm your biggest fan.
bagatelo
- License type: Pro
by bagatelo » Fri Sep 28, 2012 12:07 am
Here we have some tests that I made.
bagatelo
- License type: Pro
by thomthom » Fri Sep 28, 2012 8:57 am
Yes please!
- Name: Thomas Thomassen
- SketchUp version: 2019
- License type: Pro
- SketchUp use: other
by TIG » Fri Sep 28, 2012 9:19 am
- Global Moderator
- Name: TIG
- License type: Pro
by hardwire » Sun Oct 07, 2012 11:15 am
I have been struggling for a day to install Roundcorner by Fredo.
I have installed other plugins with no problem but this has defeated me.
Can someone give me a step by step. Fredo's instructions just do not seem to work.
hardwire
- Name: john hardy
- SketchUp version: 8
- License type: Pro
- SketchUp use: engineering and mechanical design
- Level of SketchUp: Beginner
by TIG » Sun Oct 07, 2012 11:32 am
hardwire wrote:I have been struggling for a day to install Roundcorner by Fredo. I have installed other plugins with no problem but this has defeated me. Can someone give me a step by step. Fredo's instructions just do not seem to work. I've relocated this post into the relevant thread...It's quite straightforward - reread and follow the instructions, and also get/install the latest 'Lib' folder as directed [linked] in the first post's instructions... OR since you have v8 then why not download/install thomthom's Simple Plugin Installer - available from the Plugins Index... This automatically extracts the files and subfolders from ZIP archives and puts them into the correct places - it also works on RBZ/RBS and RB formats... That way you avoid getting into a tangle with a mis-installed set ! Although if you have already manually installed some files in the wrong places you might need to do some 'tidying up' to prevent issues with files auto-loading from Plugins wrongly etc - but then it depends on the level of you screw-up!
- Global Moderator
- Name: TIG
- License type: Pro
by hardwire » Sun Oct 07, 2012 6:13 pm
TIG wrote:hardwire wrote:I have been struggling for a day to install Roundcorner by Fredo. I have installed other plugins with no problem but this has defeated me. Can someone give me a step by step. Fredo's instructions just do not seem to work. I've relocated this post into the relevant thread...It's quite straightforward - reread and follow the instructions, and also get/install the latest 'Lib' folder as directed [linked] in the first post's instructions... OR since you have v8 then why not download/install thomthom's Simple Plugin Installer - available from the Plugins Index... This automatically extracts the files and subfolders from ZIP archives and puts them into the correct places - it also works on RBZ/RBS and RB formats... That way you avoid getting into a tangle with a mis-installed set ! Although if you have already manually installed some files in the wrong places you might need to do some 'tidying up' to prevent issues with files auto-loading from Plugins wrongly etc - but then it depends on the level of you screw-up!
Thanks very much. All now installed and working. posting.php?mode=quote&f=323&t=20485&p=433684#
hardwire
- Name: john hardy
- License type: Pro
by Caj » Mon Oct 08, 2012 8:38 am
I am trying to install roundcorner plugin for Sketchup 8 on Mac running 10.8.2 When I start SU I get this message and am not able to fine toolbar or plugin:
Cannot load plugin LibFredo6 because the script cannot create DEFPARAM_Dir folder in: /Library/Application Support/Google SketchUp 8/SketchUp/Plugins
I read in a post that I need to create the folder manually, but when I go to the plugins folder, the menu option is not available to make "New Folder" (shift+command+N does not do anything either)
How can I create this folder, or get this plugin to run??
Caj
- Name: Chris Cajolet
- Operating system: Mac
- License type: Free/Make
by Dave R » Mon Oct 08, 2012 10:01 am
It sounds to me as if the Plugins folder is set as Read Only. It needs to be set as Read and Write.
- Global Moderator
- Name: Dave R
- License type: Pro
by Caj » Mon Oct 08, 2012 4:33 pm
You were correct in thinking the Plugins folder was set to read only, however even after changing that (to all users) the option for New Folder is not highlighted. I then went up the feeding chain to Sketchup, Google Sketchup 8, Application Support, Library, and Macintosh HD and changed those to read & write to see if that would make any difference. It did not.
This seems like an unusual amount of tinkering to get a plugin to work?! Is this common?
Caj
by Dave R » Mon Oct 08, 2012 5:29 pm
No. It isn't common. Your profile isn't very specific as to the OS you are using but I'll guess its Mountain Lion. I'm still using Snow Leopard and don't have any issues like this. You shouldn't have to make the changes agin, I don't think.
- Global Moderator
- Name: Dave R
- License type: Pro
by Caj » Mon Oct 08, 2012 5:38 pm
Yes, I am using Mountain Lion and it is fairly new to me. Even had trouble locating Library which they took out of finder for some reason! I had no luck manually installing new folder, but found ThomThom's Simple Plugin Installer, and was successful using that and re-installing zip file using that. Thanks for your help.
Caj
by pho0o0 » Mon Oct 08, 2012 6:08 pm
I try to intall this plugin as recommended first page but I still have this error message
Error Loading bootstrap_RoundCorner.rb uninitialized constant RoundCorner::T6Error Loading __loader.rb undefined method `effective_load' for nil:NilClass
o:)
pho0o0
- Name: pho0o0
by fredo6 » Mon Oct 08, 2012 6:14 pm
pho0o0 wrote:I try to intall this plugin as recommended first page but I still have this error message
o:)
It looks like you don't have the right footprint for LIBFREDO6 and/or ROUDNCORNER It would be good you post a snapshot of your Plugins directory (Which will also show whether you are on Windows or on Mac) Fredo
- Name: Fredo6
- License type: Pro
by pho0o0 » Mon Oct 08, 2012 6:21 pm
windows 7
pho0o0
- Name: pho0o0
by thomthom » Mon Oct 08, 2012 10:26 pm
That is the wrong footprint. Either re-read the first post and take not of the foot print, or use this helping utility to install your plugins (probably easier): viewtopic.php?t=42315
- License type: Pro
by bagatelo » Mon Oct 08, 2012 10:47 pm
It would be interesting if the Sketchup had a control panel to install / disable / uninstall plugins. Not for just a few plugins, but for all plugins. But this is not Us, but for Trimble.
bagatelo
- License type: Pro
by pho0o0 » Mon Oct 08, 2012 11:31 pm
I removed everything and reinstalled everything; I have the red diamond and toolbar roundcorner. but I still have this message:
"Erreur de chargement du fichier bootstrap_RoundCorner.rb uninitialized constant RoundCorner::T6"
pho0o0
- Name: pho0o0
by Hiro_Bird » Tue Oct 09, 2012 5:27 am
It's Great!
Hiro_Bird
- Name: Hiromasa Ohara
- SketchUp version: 2017
- License type: Pro
by TIG » Tue Oct 09, 2012 10:22 am
pho0o0 wrote:I removed everything and reinstalled everything; I have the red diamond and toolbar roundcorner. but I still have this message:
You have NOT installed everything properly. Get the latest Lib folder and install that. Pay close attention to the diagrams that Fredo provides showing the Plugins folder's files and their sub-folder arrangements. Vous n'avez pas installé tout correctement. Obtenez le dernier dossier Lib et l'installer. Portez une attention particulière aux schémas que Fredo fournit affichant les fichiers du dossier Plugins et de leurs sous-dossier arrangements.
- Global Moderator
- Name: TIG
- License type: Pro
by Elizabeth1604 » Wed Oct 17, 2012 4:06 pm
Hi everyone! I tried to install round corner tool on sketchup, and I have no idea where to find it exactly on menu. Plz help me!!!!
Elizabeth1604
- Name: Elizabeth
by fredo6 » Wed Oct 17, 2012 8:47 pm
Elizabeth1604 wrote:Hi everyone! I tried to install round corner tool on sketchup, and I have no idea where to find it exactly on menu. Plz help me!!!!
Normally, you should get a toolbar with 3 'dice-like' icons. The menu entries are under Fredo6 Collection > RoundCorner. Fredo PS: did you install LibFredo6 library?
- Name: Fredo6
- License type: Pro
by Printabot » Thu Oct 18, 2012 3:58 pm
TIG wrote:It's trying to make/use a file called 'Fredo6Trace.txt' in the 'plugins' folder. It's failing with a 'Permission denied' error. It's not in the folder contents you show. The script ought to make it automatically. Therefore I suspect that you must have the 'security permissions' set to be oddly limited for the 'plugins' folder. I'm not sure how you change this on a MAC, but on a PC it's relatively straightforward to change them to 'FULL', so I'd expect on a MAC it'll be easy too. This change to 'FULL' permissions will allow you to add/remove files/folders etc and for scripts to write files into that folder too. Also note that your Materials, Components and Styles folders ought to have the same permissions, as from time to time you will want to add files readily to these too...
Thanks so much for the tip, had the same problem, solved now
Printabot
- Name: John
- SketchUp use: hobby
by Ad Machine » 5 minutes ago
Ad Machine
- Robot
Return to Plugins
