[Poll] What do you think of the new SketchUp logo designs ?
To me, the new logo indicates a shift to the more engineering mindset of Trimble. There are a lot of trained architects on the SketchUp team and the original vision of SU was likely as an architectural visualization tool. The latest icons with the house seemed to reflect those roots (and the largest user base? - not sure about that one). As we all know, SketchUp is used for a lot more than building architecture. In that sense, the new logo may be more applicable to the wider SU audience. That being said, I had to really hunt for the new icon on my taskbar this morning.
Edit: I do really like the visually consistent icons for Layout and Style Builder.
I wonder if the team who developed this logo knew that Microsoft was going to change theirs. The two are very similar.
The mark itself is successful; it shows an object, in perspectiveโthe default view for SketchUpโand it has clearly been push-pulled, another SketchUp original. The color doesn't even matter to me. It can be any color and still be a successful mark. To the R-G colorblind out there it's probably brown.
I thinks, it's like they give low opportunity to Sketchup as the famous and easy 3d modeling software, unlike C4D & Max's logo.
On a positive note. When searching through windows explorer, the 2D & 3D logo versions signifying Layout & SketchUp files respectively are a lot easier to identify than the old logos, which were a little difficult to tell apart if you using small icons.
yes we all did notice right ?
Has anyone played around with the actual logo model? See attached file. It looks to me the the plan view does not correspond to the 3d view!
I take the point regarding a logo's requirement to 'look good' when zoomed out but we are now entering the age of retina display! So does this principle still apply?
Co-incidentally I tried out the 15" MBP Retina today in my local Apple store. It was hard to drag myself away and found my right hand reaching for the wallet in my back pocket but I resisted as I want to wait a few months to check out the 13.3" MBP Retina which is rumored to appear shortly.
My point being that things will look just as good, if not better on the 13.3" than my current 17" MBP.
So, my question is, should the 3D logo be a little more defined with line edges? We are going to be looking at this logo for some time to come
It's inevitable, TT.
(actually that was my thought on the logo too. I dig your cubes.)
Hi Takahiro, I initially thought it would turn out like your model (which I like) but I don't think it is like this. Have you studied the line projections in my model?
I was looking at your image, Mike, and I THINK that it is extruded "squares" with a heavy, 2D outline:
I drew an "extruded" square with red sides and white tops.
Then I used photoshop to trace around the outside with a thick outline, and changed all red to the same hue... -
I think that is close, but based on mike breakdown, I don't think it can be models purely in 3d.
I think the previous logo was a little toy like. A change of image is good i think.
They did make tweaks in post.
When I use small icons in my explorer folders, it is hard to distinguish between SU and LO. It did inspire me to create an avatar though.
Who cut the cheese ?
**Hey, we passed the 100 vote mark!
**Don't forget to vote in this poll also:
[Poll] What do you think of the new SketchUp logo color ?****
it is natural for people to feel uneasy about any innovation. we get attached to things which are familiar to us. I confess feeling that way when I first saw the new sketchup icon but it slowly grew on me and now I quite like it.
to be perfectly honest I always felt the sketchup icon to be a bit silly, with its pencil and little house. so much so that I changed it for the one you see below.
however, I do not think the Layout icon is as successful as Sketchup's. I find it too flat in a literal as well as figurative way.
