A Welcome Message to New SketchUcation Members  Topic is solved
The ideal place for beginners to get help using SketchUp
Re: A Welcome Message to New SketchUcation Members
Postby Rich O Brien » Mon Jun 18, 2012 9:30 am
kmthor wrote:G,day Guys
Im a new member from Australia, i work in the engineering field at present doing an off shore project in Queensland , iv been using sketch up for a long time now (7 years) and get to use it in my job every day. i found these forums the other day and thought i would jump in hoping i can learn/help.
keith
Hi Keith,
Welcome. Help is always appreciated.
There's a frontroom and a backroom....reverse faces
User avatar
Rich O Brien
Administrator
Postby Slusarenko » Mon Jun 18, 2012 6:53 pm
Hello all from a newbie...
I am totally new to SU, but I am looking to use it to help with my utility mapping needs.
I have been learning the basic functions and have a couple of plugins loaded. One is the pipealongpath ruby tool and the other is the roundcorner toolset from Fredo6.
I am looking specifically for the answers to the following...
Is there a utility to replace the sharp angular bends on lines (something like round corners does with geometric shapes)? Perhaps roundcorners does this bit I couldn't get it to work for me on just lines...
Is there a utility to draw lines based on geocoordinates (latitude and longitude, or lat, long and elevation)?
I am hoping to be able to plot the start and finish of lines (or a number of points along a line or lines) using geolocation and have them drawn in my sketch with the appropriate bends depending on the parameters that I specify for a material. For example, if a 300mm plastic pipe is the specified material, then I would like to have a 300mm radius 90 degree elbow show where the line takes a 90 degree bend. I don't necessarily want to draw them as pipes, but rather just represent the centreline of the pipe so as not to us up too much bandwidth...
Thanks in advance and cheers,
Steve
Slusarenko
Postby mitcorb » Mon Jun 25, 2012 3:11 am
Hello, Steve:
Maybe "3dskeng" is the tool for you. I believe there is a trial version and a pay version. Seems it does fittings too. There may be another pipe tool that approaches this one. Otherwise, "Pipe Along Path", "Lines 2 Tubes". But you will have to create the arcs yourself and link/"Weld" them together on the path. Get Weld at Smustard. Lines2Tubes either at Ruby Library Depot, or possibly in the Plugins Index- red button at top of this page?
User avatar
mitcorb
Top SketchUcator
Postby fraserj » Tue Jun 26, 2012 2:43 pm
Good Morning:
I am a retired stock broker from the Boston Massachusetts USA area and have been using SketchUp for several years. To keep myself busy I have been designing and building Sheds, Cabanas and out buildings for a few years. I begin with an ad in Craigslist. Once a customer has contacted me and wants to proceed, I begin with a SketchUp design. After tweaking the design to satisfaction I sign a contract and begin precutting the lumber. For this I use SketchUp in a very linear design. Rafters, Joists, and sheathing.
Recently, however, I have purchased from Fine Woodworking two references. One a book (SketchUp guide for woodworkers by Timothy Killen and similar video's by Dave Richards. The video takes you through "how to set up the program, use drawing tools, navigate in a 3-D space, refine drawings, and create shop-ready plans." Like a Highboy. For me it's a lot of learning but at 66 I want to keep myself active and it's fun.
Finally, in the not to distant future, I am going to build a beautiful Post and Beam home in New Hampshire and will use SketchUp to design it. Referencing http://www.northernlightstimberframing.com/su/.
I found SketchUcation referenced in the video by Dave Richards and glad he did.
fraserj
Postby bagger05 » Wed Jun 27, 2012 2:12 pm
Howdy.
I work for a small manufacturing company and am considering SketchUp as a solution to our modeling needs. We make pretty basic parts, but sometimes it is useful to send our customers a 3D picture of the part so that they can have a visual of how it will fit into where they're going to put it. I downloaded SketchUp maybe two weeks ago and am shocked at how simple it is to draw 3D objects.
I'm currently exploring file compatibility with TurboCAD and the eDrawings plug-in so that we can easily send our drawings to customers and they can "explore" the part.
Looking forward to getting to know everyone and having a great resource for SketchUp.
bagger05
Postby stang08 » Sat Jul 07, 2012 10:43 pm
Hello,
I am a new user to SketchUcation. I have been using SketchUp for about 2 years now for my job, a drafting technician for a construction company in the US. I bascially am self-taught with SketchUp, and although I feel comfortable with it, I am always looking for improvement. Along with SketchUp, we have been using Shaderlight to render out our SketchUp models. I am still getting the hang of the software and would appreciate any suggestions for improvement. I am always looking for better backgrounds and treelines to improve the look of my drawings, but don't slow down the render. I have seen a few here and they were very nice and helpful. Any advice on where the best place for free stuff, would always be appreciated. Thanks and have a good day, all!
stang08
Postby estrender » Sat Jul 14, 2012 4:15 pm
I am new here at SketcUcation and I found this forum to be of great help to sketchup user like me. I am still an amateur sketchup and vray for sketchup user and I found lots of free sketchup stuffs on this forum so I am looking forward to learn more. Thanks in advance.
estrender
Postby foxromeo2k » Sun Jul 15, 2012 8:05 am
Im new here and been playing with sketchup 8 free v. for a month now and im hooked. Been following basic tutorials on youtube and want to learn more and so i signed up here. Thank you.
foxromeo2k
Postby flyxcad » Sun Jul 15, 2012 2:58 pm
HEllo my name is Flavio i hope to learn from this forum some tips and tricks for SketchUp fantastic program.
Thank You
flyxcad
Postby freeyourmind2 » Sun Jul 15, 2012 10:13 pm
I'm Edi and Hello to all!
freeyourmind2
Postby SRQrainbarrels » Fri Jul 20, 2012 4:41 pm
Hello, my name is Mark.
I've been using SketchUp for about a year now. My main focus is in rainwater harvesting and I have found SKP to be a great tool in every aspect of developing a rainwater system. I recently decided to branch out a little and install some plugins and found Sketchucation. I am very pleased with what I have seen so far! Great job, thank you!
If you're looking for models of rain barrels, cisterns, rain tanks, specialty fittings, first flush diversion, or anything relating to rainwater harvesting, check out my models in the 3D Warehouse. Search for rainwater harvesting, or type in: SRQrainbarrels
Also, let me know if you need help with one of our models, or have any questions. I will be glad to help in any way I can.
SRQrainbarrels
Postby vhyck » Sat Jul 21, 2012 1:47 am
:ecstatic: :ecstatic: Good Morning Guys!
Newbie here....
I was sent here by one of the thread i am in,
my question is that how can i get the plugin for round corner? and how to add it so that i can use it in SU8
TIA :D :D
vhyck
Postby pbacot » Sat Jul 21, 2012 5:09 pm
Welcome vhyck
viewtopic.php?f=323&t=20485&start=0
One way to find Plugins: Click the big red "Plugins Index" button at the top of the forum page. Use your browser page search to find the word "round" Or scroll through the page by author.
In this forum the current plugin is usually in the FIRST post under the [Plugin] titled thread. Be sure to download all the required files.
viewtopic.php?f=323&t=35746
This is the place to start learning about installing.
viewforum.php?f=323&start=0
This is the Plugins forum under "Resources/Plugins" There is more information on where to get plugins, and how to install and use them, in the different threads.
There is also this: http://sketchup.google.com/intl/en/down ... ripts.html
This is a page found if INSIDE SketchUp you click Menu item: "Help/Learn about Ruby Plugins".
Note: Roundcorner.rb is a plugin that must be activated (check mark) inside SU using Menu item: "Preferences", tab:"Extensions". (not all plugins are)
Again, welcome to the forums! Peter
MacOSX Mojave High Sierra SketchUp Pro v19 Twilight v2 Thea v2 PowerCADD
User avatar
Top SketchUcator
Postby pbacot » Sun Jul 22, 2012 5:10 am
User avatar
Top SketchUcator
Postby Cveti » Mon Jul 23, 2012 1:02 pm
Hi all!!! :D
I would like to join to your community!
My name is Cveti. I'm a civil engineer, but my interests are mostly in the fields of architecture and interior design.
I use SU ( the free versions) since a few years and I love it.
My new task is to learn to make a photorealistic renders of interiors, so I'm going now right to the gallery, which I hope will help me to choose the right render for a cmplete beginner.
Good luck to all of you! :enlight:
Cveti
Postby aries_marz » Tue Jul 24, 2012 8:59 am
hello new on this forum help me welcome myself thanks of being here ill will take a long walk on this forum site hope it helps me improve how to use sketch up thanks guys :thumb:
aries_marz
Postby bichodamadeira » Sat Jul 28, 2012 5:13 pm
Hello, my name is Antonio Guerreiro! I'm happy to be part of this forum. Congratulations on there! I want to learn a lot from you all here. I love projects mainly in wood! :)
bichodamadeira
Postby Raizinmoon » Tue Jul 31, 2012 11:27 pm
Hello Ucation and thank you for memberizing me..
I am totally new not only to this forum but to sketchup also. I have no experence with sketchup and was looking for resources and just happen to be reading an article and someone mentioned this your site, so here I am..... I am an avide woodworker and I wanted to learn how to draw the things I think of. I looked at a couple of the posted pics with the 3D renderings and loved what i saw could be completed. Thank you and sorry for spelling and carrying on.
Dan C in Northern California
Raizinmoon
Postby thedrcarl » Fri Aug 10, 2012 6:24 am
Hey everyone!
Nice forum. I got some great info from posts here and there and thought I would join to say thanks where thanks is due.
I do have a question, but I'll search around for an existing answer first.
I'm a second year Construction Management student, and have been using SU for three years now, and have used it to design furniture, house extensions, building takeoff models (sort of BIM) and piece together building systems for my job as an estimator / contract admin.
Sometimes we come across a new system we haven't used before and I virtually build it in SU to look ahead for any issues. It's saved us lots of time and money in the past. Best of all, I get paid to play with SketchUp!
Anyways, talk to you all soon.
thedrcarl
Postby moogle » Sat Aug 11, 2012 11:21 am
Hi all,
Just thought I'd introduce myself.
My names Moogle (its a nickname not my real one! :lol: ) and I've been gradually dabbling with SU for just over a year.
Mainly using it for making model train stuff I need.
I've just found this forum. Looks like its gonna help me a lot!
moogle
Postby Gaieus » Sat Aug 11, 2012 11:24 am
Hi Moogle and wlcom!
There are a bunch of train enthusiasts here - feel free to browse around (unfortunately the forum search function is rather crappy though if you do not exactly know what you are searching for)
User avatar
Postby moogle » Sat Aug 11, 2012 11:57 am
Thanks Gaieus!
I'm sure I'll find them/things eventually.
Just found the solid inspector plugin.
Hopefully it'll cure the holes I keep getting when I export to a dae file!
If not I'm sure there's other things on here that will help.
Cheers
Moogle
moogle
Postby Gaieus » Sat Aug 11, 2012 12:07 pm
You will find out... Just ask questions and you my be surprised how many useful plugins there are out there - but of course, mastering the native, "manual" tools should always be the first.
User avatar
Postby arfaxad » Sun Aug 12, 2012 3:17 pm
Hello;
Planning on converting my deck into a room and would like to design it in SketchUp.
Downloaded SketchUp and now I'm browsing through the forum looking for tips etc.
Didn't know that sketchup uses plugins. If anyone knows of a plug in free or otherwise that would help me, I'd appreciate the info.
thanks;
Andrew
arfaxad
Postby Rapidkirby3k » Sun Aug 12, 2012 10:13 pm
Hey folks, how are things going? I'm Rapidkirby3k, also known as RK3 for short. ;)
While I'm a newbie at creating 3D models in SketchUp at this time, I decided to join this forum to learn more about its features and techniques. In fact, my first 3D experience was actually when I played around with an old program named POV-Ray, using LEGO models in 3D many years ago.
Also, according to my personal list of ideas in OpenOffice, I plan to use some of my own models for creative usage in Photoshop CS5, such as artworks and maybe webcomics. 8-)
With my introduction out of the way, I thought I'd say hello to the SketchUcation people! =D
Rapidkirby3k
Postby Mike Lucey » Mon Aug 13, 2012 2:10 am
Hi Michael and welcome.
'webcomic' you say. We have had some guys here into this end of things. I'd be interested in seeing anything you may care to share on this art form.
Best,
Mike
User avatar
Mike Lucey
Mayor
Postby Awan » Sun Aug 26, 2012 7:30 am
Hi myself Awan Ahmad n m an architect by profession..working on sketchup for the past 3 years but still need to learn a lot. I have a very basic knowledge of sketchup, came to know about sketchup forum and i believe its going to help alot in understanding the sketchup properly.
thankx everyone for making this page
Awan
Postby mitcorb » Sun Aug 26, 2012 4:04 pm
Welcome to the Forum, Awan.
User avatar
mitcorb
Top SketchUcator
Postby stumor » Tue Aug 28, 2012 7:36 pm
Hi My name is Stuart,
I retired a few years ago and have been using sketchup as occupational therapy and with a purpose. I had a fairly unique second career as I founded Collectors Cases and created the products that my company put onto the walls of British pubs and hotels and further around the world. I have been asked to demonstrate some of my techniques of 3D framing, but do not wish to travel so I have been using SU to create the 2D graphics, I should like to go further with rendering to show how 3D artwork could look in the actual decor market and also to animate the virtual reality of my workbench to get the demonstration of skills more firmly embedded into my articles.
I only learnt to switch on a computer after I retired and as purchase of software is in conflict with my pension, I tread cautiously.
stumor
Premium Member
Premium Member
Postby mitcorb » Wed Aug 29, 2012 2:22 am
Hi, Stuart, and welcome.
I wish you the best in your new work/ play.
User avatar
mitcorb
Top SketchUcator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
PreviousNext
Return to Newbie Forum
cron
Who is online
Users browsing this forum: meirin177 and 3 guests
Visit our sponsors:
