[Plugin Library] LibFredo6 - v11.6a - 23 Jan 21Re: [Plugin Library] LibFredo6 - v4.5a - 08 May 12hi dear ferdo , I have a little question ...
.. maybe it's a bad question and I know that it takes much time for you to write these features fur us ... thanks a lot for time you spend and offering your incredible codes freely to us ... thanks ferdo .. my question is how to disable time tracer and updater part due to have a faster startup and a lighter SU ? I'm a ruby newbie .. but you codes are too complex for me to trace .. ![]() I'm sorry for asking these .. I believe that these parts ( specially Updater module )are very useful for all users .. and thanks for codding these parts ferdo .. ![]() thanks Re: [Plugin Library] LibFredo6 - v4.5a - 08 May 12
You don't need to edit the ruby files. Normally, go to the CheckForUpdate dialog box and enter 999 (days) in the 'next check' field. Fredo PS: 'Check for update' does not go to the Internet when SU Starts. It just checks the date to see if it should display the reminder, so it is very fast. The fact is that that the reminder is based on a WebDialog and the first web dialogs are used, it takes a little bit long (SU may load extra stuff or perform some operations in the background).
Re: [Plugin Library] LibFredo6 - v4.5a - 08 May 12thanks feredo ... I hade done that ( 999 ) several days ago .. but I alwase see the ruby image (update check ) at start up .. how about time tracer tool ?
thanks for answer and support ferdo ![]() Re: [Plugin Library] LibFredo6 - v4.5a - 08 May 12hi Fredo, Thanks for this work you've done
![]() I have unzipped it to my plugins folder on C:/Program Files(x86)/google/Google Sketchup 8/plugins but for some reasons I just cant find it in the menus! I have also put LibFredo6.rb in the plugins. am I missing something? kindest regards Disco Re: [Plugin Library] LibFredo6 - v4.5a - 08 May 12![]() Can't seem to get the toolbar up. I've followed some of the posts and checked its in the right directory, and also ticked the box in Sketchup. Any help would be appreciated A.Noob lol Re: [Plugin Library] LibFredo6 - v4.5a - 08 May 12Which toolbar can't you get to display?
% (THERE'S NO PLACE LIKE) G28 X0.0 Y0.0 Z0.0 M30 %
The fredo sub menu under window. I've PM'd Fredo who has been kind enough to reply but so far I've not got to the bottom of it. I do have podium installed and fredo suggest it could be a clash with that? Thanks for the reply Dave ![]() Re: [Plugin Library] LibFredo6 - v4.5a - 08 May 12Ah. I see. You said you couldn't get a toolbar to show which is confusing since it isn't a toolbar but a menu entry. So did you try disabling Podium and did that fix it?
Re: [Plugin Library] LibFredo6 - v4.6c - 11 Jul 12NEW RELEASE: LibFredo6 v4.6c - 11 Jul 12
LibFredo6 4.6 is a new release which essentially support the publishing of Curvizard See main post of this thread for Download. Fredo
Re: [Plugin Library] LibFredo6 - v4.6c - 11 Jul 12I am really new to the plugins for Google sketchup. Can anyone tell me how to update my plugins?
Re: [Plugin Library] LibFredo6 - v4.6c - 11 Jul 12For the external plugins go to to this page for the name of the plugin
and go to to the end of the first post of the thread address read on the list! You will find the last Update of each plugin! And if you want the "indispensables" see my little list ![]()
Re: [Plugin Library] LibFredo6 - v4.6c - 11 Jul 12Hi,
I know this might sound silly but I'm new to this and am having trouble with downloading the plug ins.. I want to download round corners and I thought in order to do so I needed to install the LibFred06. When it goes to download and I need to unzip it I DO NOT have a Sketchup Plugins folder option... How do I go about installing this? What do I do... Thank You Re: [Plugin Library] LibFredo6 - v4.6c - 11 Jul 12You do have a Plugins folder - unless you have deleted it.
![]() It's automatically made by the Sketchup installation - it contains example scripts etc... You will not have a Plugins Menu displayed unless you have some scripts 'active'. Copy/Paste+<enter> this line of code into the Ruby Console [open that from Sketchup's Window menu] - it will display the path to the Plugins folder on you installation.
For a PC it's typically: C:/Program Files/Google/Google SketchUp 8/Plugins Make sure you have FULL security access permissions [set via properties] for all of your Sketchup folder's subfolders and their contents... I see you have v8 - with recent versions you could install archived tools using the Window>Preferences>Extensions 'load' button - BUT note that the archive needs to have a .rbz file suffix. Thomthom has made a SimpleInstaller that does something similar, but also works on .zip archives and .rb/.rbs single files - automatically finding the Plugins folder and extracting files etc for you... Find that in the Plugins Index - however you do need to put that into the Plugins folder and restart for it to auto-load, so we need to track down where that is... TIG
Re: [Plugin Library] LibFredo6 - v4.6c - 11 Jul 12I tried typing Sketchup.find_support_file("Plugins") into the Ruby Console and nothing is happening?!!!!what do i do now?
Re: [Plugin Library] LibFredo6 - v4.6c - 11 Jul 12Looks like you'll have to reinstall Sketchup - as an Admin - it should then make all missing folders/files etc.
Before that post a screen shot of your Sketchup folder showing the subfolders that you do have... It's just weird. TIG
What do you mean "nothing is happening" If you type the command in the Ruby console (and press Return) you always get an answer. Fredo
Re: [Plugin Library] LibFredo6 - v4.6c - 11 Jul 12If you type [or copy/paste] the full text into the Sketchup Menu > Window > Ruby Console and press <enter> to confirm it, you will always get something returned as the answer !
So typed correctly: Sketchup.find_support_file("Plugins") C:/Program Files/Google/Google SketchUp 8/Plugins Typed incorrectly [i.e. not an initial capital 'S']: sketchup.find_support_file("Plugins") Error: #<NameError: undefined local variable or method `sketchup' for main:Object> (eval):155 Typed incorrectly another way [i.e. without a final 's']: Sketchup.find_support_file("Plugin") nil So even if the file/folder you are looking for doesn't exist you will get 'nil' ![]() Can't you do the folders screen-shot I mentioned before? You seem to be making very heavy-weather of this ![]() TIG
I have attached a print of the screen... Re: [Plugin Library] LibFredo6 - v4.6c - 11 Jul 12But you did get an answer, Keryn. The answer was
"C:/Program Files/Google/Google SketchUp 8/Plugins" You got that answer three times. Etaoin Shrdlu
Re: [Plugin Library] LibFredo6 - v4.6c - 11 Jul 12Hooray!
![]() You do have a Plugins folder after all ![]() Find that 'Plugins' folder [navigate your folders using Windows-Explorer...] and put the script/subfolder-of-files that ship inside the zip into it. Check that the added files are really in the folder - I know your profile says XP but you might have changed? and Vista/Win7 can sometimes put such things into a side-folder IF you are not an Admin or have insufficient security permissions. The subfolders inside the Sketchup folder should all have FULL permissions of you as you will from time to time want to add files into them... Once the file/subfolder is in place restart Sketchup and everything should then work. TIG
Re: [Plugin Library] LibFredo6 - v4.6c - 11 Jul 12hi I need to install the fredo 6 plugin for round corners and unlike other plugins where its just been a simple drag and drop into the plugins folder. this download seems to be full of lots of files and I am not sure which ones to put in the plugins folder!!! I am not very computer savvy when I read the installation instructions (im on a mac) it said:
Unzip ‘RoundCorner 2.0.zip', by doing a Select All and then Extract in the Plugins directory of Sketchup, answering YES to all prompts for file overwriting, in order to make sure you reconstruct the folder hierarchy. NEVER change the name of files or move them from their folder. The footprint should be (Windows environment): I have no idea what I should do!! can anyone plese help Re: [Plugin Library] LibFredo6 - v4.6c - 11 Jul 12All of the files in the ZIP file should go into the Plugins folder but they need to maintain the same footprint as they have when you open the ZIP file. Fredo has outlined this very clearly in his first post of this thread. Go back and look at that. It's really quite simple and you should wind up with a folder and a Ruby file when they get installed.
Who is online
Users browsing this forum: amalka7, apple88, garyt, Google Bot, hiroo wada, kamil92, muratdiri, PumpkinJack and 16 guests
