[Plugin] KML Tools (2.0.0-beta) — updated 31.05.2013
@aerilius said:
I had done more than a week testing and hadn't imagined that there still could be such issues.
Now I've uploaded a new version. I found a work-around to drop the IE8 requirement and fixed some more things. I hope it works this time.just wanted to say thank you so much for making this tool available
cheers from Mexico
@ulisessol7 said:
just wanted to say thank you so much for making this tool available...
Hi Again Aerilus
The plugin is working fine for some kml files but for some reason inst working with others.
The ones that work have elevation data generated when they are created.
I tried importing a simple kml file with no elevation data and I get a white dialog box progress and no progress (please see hayrack boundary.kml)
I added 10 m vertices to the polygon and added elevation data to them and now get a dialog box with 50% progress where it stops (please see hayrack boundary with elevation.kml)
Any assistance would be appreciated.
Regards
David
@dawrightau said:
Thanks Aerilus,
The update worked perfectly and immediately (essentially no delay).
For some reason I thought the official site was http://extendsketchup.com/plugins/kml-tools/
The logical spot as you say was at the beginning of this forum.
Thanks again.
Kind regards
David Wright
I got an KML file I'm trying to import, but I'm getting errors:
fetching elevation from url; http://api.geonames.org/astergdemJSON?formatted=true&lat=63.430509&lng=10.395091&username=aerilius&style=full&callback=returnJson kmlImport.rb; geonames returned 6 Error; #<NoMethodError; undefined method `[]' for nil;NilClass> C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb;758;in `points_to_plane' C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb;758;in `each' C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb;758;in `points_to_plane' C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb;327;in `polygon' C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb;195;in `run2' C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb;655;in `eachp' (eval);155;in `each_with_index' C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb;653;in `each' C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb;653;in `each_with_index' C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb;653;in `eachp' C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb;195;in `run2' C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb;175;in `each' C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb;175;in `run2' C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb;151;in `fetch_alt'
This plugin is unfortunately very error-prone because it was my second plugin and it uses RegExps to parse xml (I hope I find a better way to handle xml, rexml didn't prove to perform better). I'll take a look at this whern I'm at home!
You're using a webdialog for the import - you can use the XML parsing capabilities of the web-browser:
http://www.w3schools.com/xml/xml_parser.aspIf you use jQuery it's very simple:
http://stackoverflow.com/questions/649614/xml-parsing-in-javascript -
That sounds interesting. Javascript isn't the fastest either, but this strategy probably doesn't use the script language's string functions but the browser's compiled code.
I once ported the plugin (partly) to ReXML and ran performace tests (more reliable but 107% slower, ReXML is pure Ruby and I wanted to avoid gems). So I'll try it with this again. -
ReXML is one of the slowest XML solutions - but as you mention it's pure Ruby. The others require some binaries. I want a Ruby parser because some times I don't have a WebDialog UI for plugins that has use of XML.
Hi David,
I tried both files in a non-geolocated model and in a geolocated model (with terrain) and they both work for me (plugin version 1.4.6). I have no idea what could go wrong. When you open the Ruby Console before running th plugin, do there appear some error messages?
I'm not sure what causes this problem. It looks like one point of a polygon could not be parsed (nil) or a polygon has less than 3 points. Off the bat I would have tried:
while a.length > 3 # replace line 754
return if outerLoop.length < 3 # insert after line 311
Thanks for getting back to me Aerilius,
I am using 1.4.9 being the version you updated to fix the part loading issue of mine in a previous post.
There is an error in the ruby console. This is the ruby console messages for the harack boundary file :
fetching elevation from url: http://api.geonames.org/astergdemJSON?formatted=true&lat=-30.4077328499&lng=152.0265933208&username=aerilius&style=full&callback=returnJson
kmlImport.rb: geonames returned 1098
Error: #<NoMethodError: undefined methodremove' for #<Sketchup::Materials:0xbfba0e4>> C:/Program Files/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb:740:in
color_to_su'
C:/Program Files/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb:738:ineach' C:/Program Files/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb:738:in
color_to_su'
C:/Program Files/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb:607:instyle' C:/Program Files/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb:170:in
run2'
C:/Program Files/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb:655:ineachp' (eval):48:in
each_with_index'
C:/Program Files/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb:653:ineach' C:/Program Files/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb:653:in
each_with_index'
C:/Program Files/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb:653:ineachp' C:/Program Files/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb:170:in
run2'
C:/Program Files/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb:151:infetch_alt' C:/Program Files/Google/Google SketchUp 8/Plugins/enjshape/shapes.rb:48:in
call'
C:/Program Files/Google/Google SketchUp 8/Plugins/enjshape/shapes.rb:48This is the ruby console message for the other file :
fetching elevation from url: http://api.geonames.org/astergdemJSON?formatted=true&lat=-30.40773285&lng=152.026593321&username=aerilius&style=full&callback=returnJson
Error: #<NoMethodError: undefined methodremove' for #<Sketchup::Materials:0xc11d030>> C:/Program Files/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb:740:in
color_to_su'
color_to_su'
run2'
C:/Program Files/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb:655:ineachp' (eval):740:in
each_with_index'
each_with_index'
run2'
C:/Program Files/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb:151:infetch_alt' C:/Program Files/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb:740:in
call'
C:/Program Files/Google/Google SketchUp 8/Plugins/kmlTools/kmlImport.rb:740Hope this helps nut it out.
Regards
David
@aerilius said:
Hi David,
I tried both files in a non-geolocated model and in a geolocated model (with terrain) and they both work for me (plugin version 1.4.6). I have no idea what could go wrong. When you open the Ruby Console before running th plugin, do there appear some error messages? -
Also a question
When one kml file (that imports ok) has been imported it is not possible to import another. A new instance of sketchup has to be opened to use the tool again.
Is this how it is or should I be able to import multiple kml files, one after another?
[quote="dawrightau"]Thanks for getting back to me Aerilius,
This should not happen, one should be able to import any amount of kml files ninto the same model.
I think I found the issue and have almost fixed it (I will finish and release an update this evening).
I uploaded a new version!
Thanks very much Aerilius I will give it a try.
Regards
David
Hi Aerilius,
Billiant thank you.
Just to let you know that I could import both kml files into the one session, both geolocted correctly.
Regards
David
Your kml import works so well.
Would you now consider creating a kmz import to import a geo located ongoing image.
It would in part be a matter of extracting the doc.kml file from the kmz zip file read the coordinates in the same way as you do now and then import the png file to that location.
Would be great functionality.
Could send you an example file
Cheers
David
When I use the import, I get a 'Missing Textures- Unknown Texture' window. The model info comes in but no surfaces. The jpgs for the textures are in the Files folder of the KML but it can't seem to find it.
Am I missing a step?
This is an error message from SketchUp's Collada importer, not from my plugin (and I unfortunately can't do anything about it).
SketchUp supports a lot of the Collada standard (actually more than any other program) but not all. SketchUp doesn't understand how your source program specifies the textures. I have reported this as a bug some days ago.
If you open the main file in a plain-text editor like Notepad++.exe then it will be 'readable'...
See what the image-file parts says...
Logically it should be a simple file-name [image.jpg], so that if the image-file kept with the main file it will be found.
If it's a 'relative' file-path including a folder then you must keep the image-files in that specified folder [e.g. images/image.jpg] with the main file.
If it's an 'absolute' file-path [i.e. with a drive letter etc] then you need to recreate that exact same folder for those image-files [e.g. c:/temp/images/image.jpg].When the importer runs on the main file it should then find the image-files where it's expecting them to be...
If the image-file names in the imported file bear no relationship to the actual image-file names you have, then you are in trouble - but even then you could try copying and renaming the image-files to suit, if you know which one is which that is...
