[Plugin] FredoTools::ReverseOrientFaces 1.0a - 11 Apr 12
Postby fredo6 » Wed Apr 11, 2012 10:46 pm
ReverseOrientFaces is a standalone script which allow to interactively revert and orientate face sides.
  1. It works across the boundaries of components and groups. You don’t need to open groups and components to paint their faces or edges.
  2. Click and Click and Drag mode to reverse or orient progressively face by face, or surface by surface and to extend a surface already painted
  3. Explicit selections of faces: single face, surfaces, connected faces, adjacent faces with same materials.
  4. Correct handling of texture inversion
  5. The tool automatically switch to Monochrome mode in order to show the front and back faces.
ReverseOrientFaces is installed as part of FredoTools.. It requires LibFredo6 4.4 or above.
See the main post for this plugin for Installation of FredoTools
No user manual (see section Quick Start and Videos below)
  • SU Versions: SU6, SU7, SU8
  • Platforms: Windows and Mac
  • Languages: English, French
  • Menus: by default, ReverseOrientFaces is installed in Tools > FredoTools. It does NOT appear in the Contextual menu.
  • Icon toolbar: Fredo6 Tools. There is only a single icon. By default, it is not shown. You need to go to the Default Parameters… dialog of FredoTools to enable the icon.
  • The plugin is free, for private and commercial usage.
ReverseOrientFaces Overview
The mode “Reverse Face” or “Orient Face” must be chosen in the button palette, You can use Ctrl Alone to toggle between the two modes.
You have two buttons to toggle between Monochrome and Textured view modes, and to toggle visibility of hidden edges.
Revert Face mode
  • Choose the Face selection mode in the button palette (use the arrow to cycle through the modes)
  • Click to Reverse
  • Click and Drag to reverse adjacent faces
Orient Face Mode
  • Click on face. This first face will indicate the orientation to propagate to adjacent faces. You can use Click & Drag to control to which faces you extend the orientation change.
ReverseOrientFaces 1.0a - 11 Apr 12: initial public release
-1
User avatar
PluginStore Author
PluginStore Author
Re: [Plugin] FredoTools::ReverseOrientFaces 1.0a - 11 Apr 12
Postby pilou » Wed Apr 11, 2012 11:11 pm
Useful in case of strange results after a Catmull-Clark subdivision result
not automatic possible resolving by the normal tool (Reverse / Orient)of SU ;)
-1
Speedy Galerie
User avatar
Top SketchUcator
Postby EarthMover » Thu Apr 12, 2012 2:17 am
Very useful! Thanks Fredo! :thumb:
Content Creator at Skapeup
User avatar
EarthMover
Premium Member
Premium Member
Postby mitcorb » Thu Apr 12, 2012 2:32 am
Excellent!! How many times could I have used this? Bravo!
User avatar
mitcorb
Top SketchUcator
Postby JClements » Thu Apr 12, 2012 3:10 pm
Thank you.
User avatar
JClements
Premium Member
Premium Member
Postby Vicspa » Thu Apr 12, 2012 4:20 pm
Thank you Fredo for all your hard work. :thumb: :thumb: :thumb:
how do I make this window show up? I can't seem to find it.
Vicspa
Postby fredo6 » Thu Apr 12, 2012 4:23 pm
@vicspa: by default, you just have one icon visible (the FredoTools Quick Launcher).
If you wish to get the icons for the tools visible, just goto the Default Parameters box of FredoTools and select the one you want.
This is explained in more detail in the main post of FredoTools.
User avatar
PluginStore Author
PluginStore Author
Postby Vicspa » Thu Apr 12, 2012 4:29 pm
:thumb: Thanks Fredo
Vicspa
Postby pilou » Wed Apr 18, 2012 2:09 pm
Why not a selection non adjacent ?
(click a reversed face and all reversed faces are selected even they are not adjacent! )
Speedy Galerie
User avatar
Top SketchUcator
Postby rv1974 » Thu Apr 19, 2012 2:27 pm
Fredo I seriously believe you're tough enough to develop your own Sketchup full of blackjack and
hookers !
rv1974
Postby shootonlee » Wed Apr 24, 2013 4:32 am
useful! thank you fredo..
shootonlee
Postby leaflett » Sun Nov 06, 2016 5:37 pm
another brilliant tool wot i needed ages ago welldone and thanks kudos due
leaflett
Postby JcAbat » Thu Jun 07, 2018 11:18 pm
i cant find the fredo tool bar, i checked the default parameters from windo>fredo but under the configuration there is no tools under it to check,help please
JcAbat
Postby fredo6 » Fri Jun 08, 2018 5:02 pm
JcAbat wrote:i cant find the fredo tool bar, i checked the default parameters from windo>fredo but under the configuration there is no tools under it to check,help please
Did you install both LibFredo6 and FredoTools?
User avatar
PluginStore Author
PluginStore Author
Postby jeff1harmed » Tue Feb 11, 2020 1:49 pm
Thanks but download screen hangs
Kind regards
jeff1harmed
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Plugins
Who is online
Users browsing this forum: Google Bot, narayanan, Pier12, Spicchio and 8 guests
Visit our sponsors:
