[Plugin] TIG.splitdonut
Postby TIG » Sat Feb 18, 2012 12:44 pm
(c) TIG 2012
Script:
TIG-splitdonut.rb
Splits 'donut' shaped faces made with followme etc into 'quads'
[four-sided faces].
Select some faces to process.
All other selected entities and any non-compliant faces are discarded.
Only those faces with an outer-loop and just one inner-loop which both have
the same number of vertices are processed.
Lines are then added between 'matching' vertices to divide the 'donut' face
into 'quads' [four-sided faces]...
Type into the Ruby Console: TIG.splitdonut
OR use Tools > Split Tools... submenu item.
It is one step undoable.
Donations: by PayPal.com to info @ revitrev.org
Version:
1.0 20120218 First issue.
1.1 20120219 At the end all new Edges added are selected to let you use
Entity Info to set them soft/smooth or hidden etc as desired.
Error messages added if incorrect selection.
Now in Tools > Split Tools submenu
2.0 20160818 Now comes in the SplitTools RBZ. No longer available separately.
http://forums.sketchucation.com/viewtop ... 58#p386658
User avatar
Global Moderator
Re: [Plugin] TIG.splitdonut v1.0 20120218
Postby cotty » Sat Feb 18, 2012 12:55 pm
Very helpful (e.g. for artisan proxy creation), thank you very much!
User avatar
cotty
Top SketchUcator
Postby Gaieus » Sat Feb 18, 2012 12:59 pm
Interesting tool and thanks TIG. It only works on donut shapes however. Could it be improved so that it could work on non-circular shapes, too? Like an arch for instance.
User avatar
Postby TIG » Sat Feb 18, 2012 1:36 pm
Gaieus wrote:Interesting tool and thanks TIG. It only works on donut shapes however. Could it be improved so that it could work on non-circular shapes, too? Like an arch for instance.
Try this viewtopic.php?p=386610#p386610 TIG.splitsausage...
User avatar
Global Moderator
Postby jason_maranto » Sat Feb 18, 2012 3:48 pm
Are these ultimately going to be grouped together on a toolbar?
Best,
Jason.
User avatar
jason_maranto
Postby TIG » Sat Feb 18, 2012 3:56 pm
Like this viewtopic.php?p=386658#p386658
TIG-splitTOOLS toolbar/menu combing all three related tools...
User avatar
Global Moderator
Re: [Plugin] TIG.splitdonut v1.1 20120219
Postby TIG » Sun Feb 19, 2012 1:25 pm
Here's v1.1 viewtopic.php?p=386601#p386601
At the end all new Edges added are selected to let you to use Entity Info to set them soft/smooth or hidden etc as desired.
Now in Tools > Split Tools submenu viewtopic.php?p=386658#p386658
User avatar
Global Moderator
Postby d12dozr » Mon Feb 20, 2012 6:11 pm
cotty wrote:Very helpful (e.g. for artisan proxy creation), thank you very much!
Exactly...Thanks TIG! :D
http://goo.gl/f7ooYh
d12dozr
Top SketchUcator
Postby Drachenbauer » Wed May 23, 2018 3:07 pm
Where is the download-Button?
Drachenbauer
Postby TIG » Thu May 24, 2018 2:16 pm
This tool was combined into SplitTools with other similar ones...
https://sketchucation.com/pluginstore?p ... splitTOOLS
User avatar
Global Moderator
User avatar
Global Moderator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Plugins
Who is online
Users browsing this forum: mvm1990 and 14 guests
