[Plugin] Make Fur v.2.1.0(20140323)Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)awsome!!
so simple and easy to operate!! This is by far one of the best and most useful plugins I have ever seen !!!!! Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)i am unable to create furs....when i click make fur....nothing happens....what is wrong with it plz help?
Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)Hi,stef52.
I think inputing larger number to "MaxNumber(/Face)" in dialog will improve the problem. How is it? Please reply if it does not improve the problem. Thanks. -----------
by TAK2HATA
Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)hello,
thanks for the plugin, grass making is now really easy (and by using component grass, it's also super fast as well!) ![]() however, i have a question (a feature request): would it be possible to implement distributing by a B&W texture, or with an exponential fall-off (especially useful with the Valid Distance option) thanks for answers and i wish you good luck ![]() I'm using SketchUp 2017, V-Ray 3.4
Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)hi tak2hata
i just discoverd this plugin. this plugin is awesome!!! it's a great relief for all SU users. thank you very much! domo arigato gozaimashita!!!! Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)@steph52:
Viewing your example suggested that you may need to set up a more regular mesh on that slope instead of stretched triangles. More like a fishnet grid. I may have misinterpreted the image, however. I take the slow, deliberate approach in my aimless wandering.
Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)Hi,eidam655 and db9black and mitcorb.
Thanks for your replys. ![]() eidam655... Your request is difficult for me. I did not try processing from a picture yet. I will search the method for that solution. Please wait (without Expectation...Sorry.) -----------
by TAK2HATA
Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)just found this plugin, it's awesome! Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)
Hi ,peter_shaw. very nice! ![]() -----------
by TAK2HATA
Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)hi,
here's what i thought of: current algorithm distributes fur to the whole face/polygon according to a function with multiple parameters, density being one of them. i would suggest something like: request min and max density from user request/load the density map from user (file) stretch image on the face (300x300 px image onto a 1m x 1m face for example) go through every pixel in image //yeah, this sucks while 1. there's no getPixelColor method in sketchup's sdk as far as i can see, and 2. this is a loop in a loop and takes ages to complete ![]() color value divided by white (100%) is the percentage therefore current density for this area is minDensity+percentage*(maxDensity-minDensity) ...and so on. yes, there are probably more effective ways to do this. no, i'm not a computer scientist. no, i don't know ruby or sketchup's sdk. no, i'm not sure how this should have helped you. I'm using SketchUp 2017, V-Ray 3.4
Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)CREATING GRASS with HIDDEN EDGES in model with visible edges?
Any way to use the create grass function to do this? Can do this in the create crowd function, but it doesn't have the controls of the blade shape. A wonderful plug-in that really helps create lush landscaping. Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)Help! I'm doing something wrong. Here is my setup:
and my render: As you can see, the grass is just little green dots and the rendering shows nothing at all. What am I doing wrong? ![]() Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)Those green dots are the preview only. Did you also press the Make fur button?
Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)Well, I thought I did. Let me try it again just to make sure.
Thanks. Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)yippee!! grass and everything - now I guess I'l have to start mowing....
![]() ![]() Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)IVE DOWNLOADED THE MAKE FUR, BUT NO .EXE FILE, ONLY FUR_EN, NOT AND INSTALLER, ONLY IMAGES. ANY HELP PLSSS??
Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)Arman Follow the installation instructions on the download page. There is no 'exe' file or an 'installer' etc. ![]() Various files/subfolder in the downloaded 'archive' file will need extracting into the Sketchup Plugins folder... Before you restart Sketchup to get the expected menus/toolbars/etc... It sounds like you are a complete installation newbie ??? ![]() There are many posts explaining how to do this in some detail... do a search on the SCF forums... Please [re]read these and the tools download page guidance notes - if you still can't install it come back to us... PS: Please don't post using ALL CAPS - it looks like you are shouting at us, it is also harder to read... AND it is generally regarded as bad manners on almost all forums... ![]() TIG
Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)THHAAAAAAAAAAAANNNNKKKKK YOU!!!! this will be very helpfull with my models : )
Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)hello this plug in is marvellous.
Just a silly question. I finally manage to create some grass but it makes me a white model. I dont manage to change the color. It seems to be not a component (herb) so i have to change the color of every single blade of grass? Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)First of all, I would like to confratulate on this excelente plugin.
Im having a little problem with this plugin... When I make "grass", the plugin does not cover all the face. Could any one help please? Thanks a lot Last edited by FGomes on Sun Jul 15, 2012 3:39 pm, edited 1 time in total.
Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)does subdividing the face into smaller regions help?
Hi,eudam655. The face Your saying is blade of grass? Subdivide of blade setting is "DIVIDE". The blade will be generated more divides when you set it Large number. Thanks. -----------
by TAK2HATA
Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)No. dividing the area does not help. The problem still occurs.
This is very strange... for example, I made a flat rectangle, anda making fur preview, half the side as more "fur" than the other... I tried dividing the area in smaller areas but the problem persists... Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)you're wrong, dividing the are will help, you just have so many particles there that it hits some kind of ceiling.
either that or the 30000 maximum per face is too little. how big is the face? I'm using SketchUp 2017, V-Ray 3.4
Re: [Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)I tried dividing and its the same thing. See the examples and I increased the number to 900000 and it distributes less...
Who is online
Users browsing this forum: BrianGustavoLuiz, Builder54, Dave R, Marianne66, MAXIMODRAGON, nektares, pitangapedro and 15 guests
