[Plugin] Simple Loft alpha 0.1b -- UPDATED May-15-09
Re: [Plugin] Simple Loft alpha 0.1b -- UPDATED May-15-09
Postby Gromit » Wed Jan 12, 2011 2:31 pm
Chris, You are A GENIUS!!! :berserk: :berserk: :berserk:
Gromit
Postby jeh397 » Sat Mar 19, 2011 12:49 am
I just downloaded the loft plugin and I'm finding that once I select the loft tool
I can't select any of the curves in my model. Any suggestions?
jeh397
Postby Dave R » Sat Mar 19, 2011 11:45 am
Jacqueline, could you post either the model or a screen shot so we can see what you're doing?
Out of curiosity, is there any chance your curves are inside components or groups that are not open for editing?
User avatar
Global Moderator
Postby Alezio » Wed Nov 23, 2011 10:49 am
Thank you so much for sharing this use full :thumb: plugin . im new in sketchup....perhaps everybody would like to help me....thank's again :D :D :D :bounce:
Alezio
Postby Chris Fullmer » Wed Nov 23, 2011 6:45 pm
You're welcome. There are better tools for lofting now. This was the first one, but TIG and FREDO in particular have done lots of amazing work with lofting plugins. I'd recommend looking at theirs.
User avatar
SketchUp Team
SketchUp Team
Postby fran6fontaine » Wed Jan 18, 2012 8:26 pm
one simple question, I downloaded the rb script for the loft tool but it doesn't appear in my sketchup. Neither in my plugins menu even if i click and drag it into the plugins folder of my sketchup.
If you could help, i would really like to use it, seems to work like a charm to creat super smooth surfaces.
fran6fontaine
Postby Dave R » Thu Jan 19, 2012 11:37 am
Almost always when a user reports that a plugin doesn't work, the reason turns out to be that it was installed incorrectly. Since I know for a fact that the plugin does work, I'll assume the your problem is the same. It appears you have Win7. In that OS you must have administrator privileges to install files into the Plugins folder. Do you? If not, you'll need to change that so you do.
Second, you say you dragged it into your Plugins folder. Did you extract the contents of the ZIP file? When you open the ZIP file you'll see there is a file whose extension is .rb and a folder. The folder has some icon and other files. Those contents must remain in that folder inside the Plugins folder.
There's a sticky post about installing plugins in this forum. Read it. After you've made sure you have administrative rights to add files to the Plugins folder and you've installed it correctly, check to see if it works. If you still have problems, let us know. Include screen shots that show the plugin installed correctly in the Plugins folder.
Also, this plugin contains a single button toolbar. You'll want to turn that on under View>Toolbars.
User avatar
Global Moderator
Postby pigfreezer2 » Fri Apr 06, 2012 1:08 am
:berserk: hollll ll ll
pigfreezer2
Postby 32bits » Thu Mar 27, 2014 3:45 pm
Hi Chris,
I have the next problem with the plug-in version 0.3.0 :
Code: Select all
[size=85]Error: #<ArgumentError: Cannot convert argument to Sketchup::Point3d>
C:/Users/AMD6128x2/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/clf_simple_loft/clf_simple_loft_data.rb:163:in `add_cpoint'
C:/Users/AMD6128x2/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/clf_simple_loft/clf_simple_loft_data.rb:163:in `block in end_handles'
C:/Users/AMD6128x2/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/clf_simple_loft/clf_simple_loft_data.rb:160:in `each_index'
C:/Users/AMD6128x2/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/clf_simple_loft/clf_simple_loft_data.rb:160:in `end_handles'
C:/Users/AMD6128x2/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/clf_simple_loft/clf_simple_loft_data.rb:68:in `onReturn'[/size]
some help? please!
Many Thanks
32bits
Postby Dave R » Thu Mar 27, 2014 5:20 pm
How did you install it? It works fine for me. I installed it via the Extension Warehouse.
User avatar
Global Moderator
Postby austint30 » Thu Aug 07, 2014 6:30 pm
When I extracted the zip contents into the plugins folder in Sketchup Make 2014, I got this error when I started Sketchup.
Load Errors
Error: #<TypeError: wrong argument type (expected Sketchup::Entity)>
C:/Users/Boys/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/clf_simple_loft/clf_simple_loft.rb:49:in `add_group'
C:/Users/Boys/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/clf_simple_loft/clf_simple_loft.rb:49:in `activate'
C:/Users/Boys/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/clf_simple_loft/clf_simple_loft.rb:328:in `select_tool'
C:/Users/Boys/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/clf_simple_loft/clf_simple_loft.rb:328:in `<top (required)>'
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in `require'
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in `load'
C:/Users/Boys/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/clf_simple_loft_loader.rb:29:in `register_extension'
C:/Users/Boys/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/clf_simple_loft_loader.rb:29:in `<top (required)>'
austint30
Postby naidokdin » Thu Oct 22, 2015 5:28 am
Thanks for another excellent effort in this Loft Tool.
naidokdin
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Previous
Return to Plugins
Who is online
Users browsing this forum: fredykurniawan, Kuzeyli, Shin haejin and 7 guests
Visit our sponsors:
