[Plugin]Hole on Solid tool v1.6.3 upadate Jan 09, 2012
It works fine now.
Great job thank you. -
Playing with it I notice that it does not detect hole in face, this could be a great improvement.
New concept of Boolean opérations!
Wow!
Fantastic tool. Thank you very much -
Great Thanks Tak2Hata, it working like a charm now
@tak2hata said:
Hi utiler.
Your second question is the direction of the this plugin's future.
1st question is No.
It need only face for hole.Thanks
Tak2hata, another question:
When you create the whole in the solid it appear to expolde the profile shape; eg: circle / polygon.... Can you force the resulting edges to be hidden?
thanks mate!!
Hi. I just tried to extract with Winzip eval version and got this in error output:
>>Extracting file: C:\Program Files (x86)\Google\Google Sketchup 7\Plugins\HoleOnSolidTool_v1_01.zip
Extracting to "C:\Program Files (x86)\Google\Google Sketchup 7\Plugins"
Use Path: yes Overlay Files: no
Unable to process "HoleOnSolidTool_v1_01".
Severe Error: Not permitted or able to create an output directory.<<Anyone have any ideas on this? Perhaps 7zip? Note that I am placing this in x86 where my Sketchup 7 version resides. Is this tool only for Sketchup 8?
So this plugin only works with the "Pro" version? The free version does not have solids so I am unable to use it
Thanks for the great plugin even though I am unable to use it.
How did you come to that conclusion? Looking through the thread it appears that other users of the free version of SketchUp have been using the plugin. The free version of SU doesn't have the Solid Tools but it still identifies solid groups and components.
I tried the plugin with groups and components and it would not pick the solid feature. So I assumed it only worked with the pro solids.
Post an example SKP file in which it doesn't work.
Certainly. When I get home this evening I'll post an skp file. Any and all help is appreciated
Edit:
I figured out what I was doing wrong
You have to have the profile lined up with the solid in order for it to work. I had my profile off to the side. My mistake, sorry.Gorgeous plugin.
really powerful tool. thank you very much.
Edit:
Yep, that would do it.
As a followup on my previous comment, I did manage to extract and copy drag from the Winzip UI into the plugins folder the two files .rb and icon. When I tested in Sketchup 7, selection would not progress beyond the prompt for the first object/ group which was simply a cubic form made into a group and a circle oriented appropriately. Previously, in XP, I could right click on the zip file already in place in the plugins folder, "extract to here" and see the files deployed appropriately. Any thoughts on what I have managed to miss in the provided info?
Hi mitcorb.
This plugin use property of volume.
Sketchup supports solid in later version of 8.
As matter of fact,I think this script may work ,when it judges the Group(Component) is solid.
I must create the method of that judgment for that purpose.
I inquire later.Thanks.
@mitcorb said:
Hi,tak2hata:
Here is the Ruby Console error message:Error: #<NoMethodError: undefined method
volume' for #<Sketchup::Group:0xa789048>> C:/Program Files (x86)/Google/Google Sketchup 7/Plugins/create_hole_on_solid.rb:298:in
onLButtonDown'
C:/Program Files (x86)/Google/Google Sketchup 7/Plugins/create_hole_on_solid.rb:298I'm guessing you are not using SketchUp 8 -
group.volume
is a method available since SU8 when SU introduced solids. -
Ah - just noticed the file path of your SketchUp in the error - you're on SU7. That would be the problem.
Hi,tak2hata:
onLButtonDown'
C:/Program Files (x86)/Google/Google Sketchup 7/Plugins/create_hole_on_solid.rb:298I see your demo suggests that only available in Sketchup version 8 by the fact that the default component in the demo is Susan. Yet your user profile says you use Vista and Sketchup V7. Perhaps in your first post, mention that this is for V8 only?
Thanks, ThomThom:
Yes, I realize that, now. The confusion came from noting the author's profile and subsequent responders profiles have not been updated, so I assumed that this plugin was available for SU v7 also.
I do have Sketchup V8 but I have not yet installed it there.
