[Code] position of texture pins
Postby Aerilius » Wed Oct 19, 2011 2:01 pm
I searched in the forum everywhere but I'm not sure if there exists already some code for this. Basically I want to find the (possible) position of texture pins - or better - the corners of a texture image on a face.
uvq = uv_helper.get_front_UVQ(vert.position) gives me the texture coordinate when I input a certain model coordinate. What I want is the opposite, ie. to get the model coordinate of the uvq [0,0,1], [0,1,1] etc. At the moment it is like digging in the dark.
I would start my code by "testing" four model coordinates that are arranged as a square on the face and do some (more or less complex) math to find where uvq is [0,0,#] etc.
Aerilius
PluginStore Author
PluginStore Author
Re: position of texture pins
Postby thomthom » Wed Oct 19, 2011 10:10 pm
Get the UV of two points. From that you can calculate where the origin is. You use the two points to act as two point on a line and then see where that line intersects with the X and Y of the UV coords.
...did that make sense at all?
User avatar
PluginStore Author
PluginStore Author
Postby Aerilius » Thu Oct 20, 2011 2:21 am
Sounds easier than my approach, but I'm not sure how it would work with non-rectangular distorted textures.
I've got some progress.
I convert 3 world coordinate points into uvq coordinates (API method) and use them as fix points for a barycentric coordinate system. Then I express the texture's corners (uvq [0,0,0] etc.) in barycentric coordinates. With the world coordinates of the 3 fix points I can convert the barycentric texture corners into the world coordinate system.
Unfortunately it works only for affine texture transformations (any scale, rotation, shearing), but no distortion with four texture coordinates. Must be due to the barycentric system, I'll have to search if it can be used also with four fix points.
Aerilius
PluginStore Author
PluginStore Author
[code] position of texture pins
Postby Aerilius » Thu Oct 20, 2011 12:37 pm
get_texture_pins(face)
Code: Select all
def get_texture_pins(face)
Sketchup.active_model.start_operation("UV test")
  tw = Sketchup.create_texture_writer
  uv_helper = face.get_UVHelper true, true, tw
  # three perpendicular points
  v1 = face.vertices[0].position
  v2 = face.vertices[1].position
  vec1 = v1.vector_to(v2)
  vec2 = vec1 * face.normal
  v3 = v1 - vec2
  # their uvq
  uv1 = uv_helper.get_front_UVQ(v1)
  uv2 = uv_helper.get_front_UVQ(v2)
  uv3 = uv_helper.get_front_UVQ(v3)
  uv1.to_a.collect!{|x| x /= uv1[2]}
  uv2.to_a.collect!{|x| x /= uv2[2]}
  uv3.to_a.collect!{|x| x /= uv3[2]}
  # texture corners in texture coordinates
  t1 = to_barycentric(uv1, uv2, uv3, [0,0,1])
  t2 = to_barycentric(uv1, uv2, uv3, [0,1,1])
  t3 = to_barycentric(uv1, uv2, uv3, [1,1,1])
  t4 = to_barycentric(uv1, uv2, uv3, [1,0,1])
  # texture corners in world coordinates
  p1 = from_barycentric(v1, v2, v3, t1)
  p2 = from_barycentric(v1, v2, v3, t2)
  p3 = from_barycentric(v1, v2, v3, t3)
  p4 = from_barycentric(v1, v2, v3, t4)
  Sketchup.active_model.entities.add_cpoint(p1)
  Sketchup.active_model.entities.add_cpoint(p2)
  Sketchup.active_model.entities.add_cpoint(p3)
  Sketchup.active_model.entities.add_cpoint(p4)
Sketchup.active_model.commit_operation
end #def get_texture_pins
def to_barycentric(f1, f2, f3, p)
  area = heron(f1, f2, f3).to_f
  n = (f2.vector_to(f1))*(f2.vector_to(f3))
  # we need to change the algebraic sign when p lays outside of the triangle f1f2f3
  area1 = heron(f2, f3, p) * orientation([f2, f3, p], n)
  area2 = heron(f3, f1, p) * orientation([f3, f1, p], n)
  area3 = heron(f1, f2, p) * orientation([f1, f2, p], n)
  b = Geom::Point3d.new()
  b.x = area1/area
  b.y = area2/area
  b.z = area3/area
  return b
end #def to_barycentric
def from_barycentric(f1, f2, f3, b)
  p = Geom::Point3d.new()
  p.x = f1.x*b.x + f2.x*b.y + f3.x*b.z
  p.y = f1.y*b.x + f2.y*b.y + f3.y*b.z
  p.z = f1.z*b.x + f2.z*b.y + f3.z*b.z
  return p
end #def from_barycentric
# Heron's formular, area of a triangle
def heron(p1, p2, p3)
  a = p1.distance(p2)
  b = p2.distance(p3)
  c = p3.distance(p1)
  s = 0.5*(a+b+c) # semiperimeter
  area = Math.sqrt( (s*(s-a)*(s-b)*(s-c)).abs )
  return area
end #def heron
# points are oriented counter-clockwise (1) or clockwise in comparison to normal1
def orientation(points, normal1)
  orientation = 1
  normal2 = (points[1].vector_to(points[0]))*(points[1].vector_to(points[2]))
  orientation = -1 if normal2!=[0,0,0] && !normal1.samedirection?(normal2)
  return orientation
end #def orientation
Aerilius
PluginStore Author
PluginStore Author
Postby Aerilius » Sun Nov 06, 2011 10:13 pm
Aerilius wrote:Unfortunately it works only for affine texture transformations
As said, my own strategy only dealt well with affine transformations. I did some research and found the proper code below for affine/projective coordinate transformations with matrix calculation etc. Translated from C code to Ruby.
Usage: get_texture_pins(face, side)
- with side = true for frontface, false for backface
- returns: Array of 4 Geom::Point3d
Note: SketchUp dynamically places the texture pins where the user clicks, thus they can be translated about u/v +/-1
May it be useful.
Code: Select all
# from:
# Paul S. Heckbert, Fundamentals of Texture Mapping and Image Warping, 1989
# pages 68-73
# determinant of a 2x2 matrix
def det2(a, b, c, d)
  return a*d - b*c
end #def det2
# matrix multiply: c = a*b
def mx3_mul(a, b)
  c = [[],[],[]]
  c[0][0] = a[0][0]*b[0][0] + a[0][1]*b[1][0] + a[0][2]*b[2][0]
  c[0][1] = a[0][0]*b[0][1] + a[0][1]*b[1][1] + a[0][2]*b[2][1]
  c[0][2] = a[0][0]*b[0][2] + a[0][1]*b[1][2] + a[0][2]*b[2][2]
  c[1][0] = a[1][0]*b[0][0] + a[1][1]*b[1][0] + a[1][2]*b[2][0]
  c[1][1] = a[1][0]*b[0][1] + a[1][1]*b[1][1] + a[1][2]*b[2][1]
  c[1][2] = a[1][0]*b[0][2] + a[1][1]*b[1][2] + a[1][2]*b[2][2]
  c[2][0] = a[2][0]*b[0][0] + a[2][1]*b[1][0] + a[2][2]*b[2][0]
  c[2][1] = a[2][0]*b[0][1] + a[2][1]*b[1][1] + a[2][2]*b[2][1]
  c[2][2] = a[2][0]*b[0][2] + a[2][1]*b[1][2] + a[2][2]*b[2][2]
  return c
end #def mx3_mul
# transform point p by matrix a: q = p*a
def mx3d_transform(p, a)
  q = []
  q[0] = p[0]*a[0][0] + p[1]*a[1][0] + p[2]*a[2][0]
  q[1] = p[0]*a[0][1] + p[1]*a[1][1] + p[2]*a[2][1]
  q[2] = p[0]*a[0][2] + p[1]*a[1][2] + p[2]*a[2][2]
  return q
end #def mx3d_transform
# invert matrix
def mx_invert(a)
  b = [[],[],[]]
  b[0][0] = a[1][1]*a[2][2] - a[2][1]*a[1][2]
  b[0][1] = a[2][1]*a[0][2] - a[0][1]*a[2][2]
  b[0][2] = a[0][1]*a[1][2] - a[1][1]*a[0][2]
  b[1][0] = a[2][0]*a[1][2] - a[1][0]*a[2][2]
  b[1][1] = a[0][0]*a[2][2] - a[2][0]*a[0][2]
  b[1][2] = a[1][0]*a[0][2] - a[0][0]*a[1][2]
  b[2][0] = a[1][0]*a[2][1] - a[2][0]*a[1][1]
  b[2][1] = a[2][0]*a[0][1] - a[0][0]*a[2][1]
  b[2][2] = a[0][0]*a[1][1] - a[1][0]*a[0][1]
  return b
end #dev mx_invert
# pmap_square_quad:
# find the mapping matrix for transforming a
# unit square [0,0], [1,0], [1,1], [0,1]
# into a quad
def pmap_square_quad(face, front=true)
  tolerance = 0.000001
  # four points of a square
  v0 = face.vertices[0].position
  v1 = face.vertices[1].position
  vec0 = v0.vector_to(v1)#.normalize ?
  v1 = v0 + vec0
  vec1 = (vec0 * face.normal)#.normalize ?
  v2 = v0 + vec0 + vec1
  v3 = v0 + vec1
  # their uvq
  if front==true
    uv0 = uv_helper.get_front_UVQ(v0)
  else
    uv0 = uv_helper.get_back_UVQ(v0)
    uv1 = uv_helper.get_back_UVQ(v1)
    uv2 = uv_helper.get_back_UVQ(v2)
    uv3 = uv_helper.get_back_UVQ(v3)
  uv0 = uv0.to_a.collect!{|x| x /= uv0[2]}
  uv1 = uv1.to_a.collect!{|x| x /= uv1[2]}
  uv2 = uv2.to_a.collect!{|x| x /= uv2[2]}
  uv3 = uv3.to_a.collect!{|x| x /= uv3[2]}
  # transformation from square to quad
  t=[[],[],[]]
  px = uv0.x - uv1.x + uv2.x - uv3.x
  py = uv0.y - uv1.y + uv2.y - uv3.y
   # affine
  if px.abs<tolerance && py.abs<tolerance # zero or near zero
  puts "affine"
    t[0][0] = uv1.x - uv0.x
    t[1][0] = uv2.x - uv1.x
    t[2][0] = uv0.x
    t[0][1] = uv1.y - uv0.y
    t[1][1] = uv2.y - uv1.y
    t[2][1] = uv0.y
    t[0][2] = 0
    t[1][2] = 0
    t[2][2] = 1
    return t
   # projective
  else
  puts "projective"
    dx1 = uv1.x - uv2.x
    dx2 = uv3.x - uv2.x
    dy1 = uv1.y - uv2.y
    dy2 = uv3.y - uv2.y
    del = det2(dx1, dx2, dy1, dy2)
    return nil if del==0
    t[0][2] = det2(px, dx2, py, dy2)/del
    t[1][2] = det2(dx1, px, dy1, py)/del
    t[2][2] = 1.0
    t[0][0] = uv1.x - uv0.x + t[0][2] * uv1.x
    t[1][0] = uv3.x - uv0.x + t[1][2] * uv3.x
    t[2][0] = uv0.x
    t[0][1] = uv1.y - uv0.y + t[0][2] * uv1.y
    t[1][1] = uv3.y - uv0.y + t[1][2] * uv3.y
    t[2][1] = uv0.y
    return t
# convert a specific uvq into xyz of object coordinate system
# opposite of UVhelper.get_front_UVQ([x,y,z])
def UVQ_to_XYZ(uvq, face, transformation)
  # origin point and two vectors in 3d coordinates
  # texture coordinates to 2d coordinates
  xyw = mx3d_transform(uvq, mx_invert(transformation))
  xyw.x /= xyw[2]
  xyw.y /= xyw[2]
  # 2d coordinates to 3d coordinates
  xyz = Geom::Point3d.new()
  xyz.x = v0.x + vec0.x * xyw.x + vec1.x * xyw.y
  xyz.y = v0.y + vec0.y * xyw.x + vec1.y * xyw.y
  xyz.z = v0.z + vec0.z * xyw.x + vec1.z * xyw.y
  return xyz
end #def UVQ_to_XYZ
# get the object coordinates of the texture pins of a face (front, or back)
# Note that SketchUp places the texture pins near where the user right clicks
# to position the texture. This means it could also be translated:
#  [m+0,n+0,1]
#  [m+1,n+0,1]
#  [m+1,n+1,1]
#  [m+0,n+1,1]
def get_texture_pins(face, front=true)
  Sketchup.active_model.start_operation "get texture pins"
  t = pmap_square_quad(face, front)
  pins = [ UVQ_to_XYZ([0,0,1], face, t),
           UVQ_to_XYZ([1,0,1], face, t),
           UVQ_to_XYZ([1,1,1], face, t),
           UVQ_to_XYZ([0,1,1], face, t)
  # example: show pins with construction points
  pins.each{|p| Sketchup.active_model.entities.add_cpoint(p)}
  return pins
Aerilius
PluginStore Author
PluginStore Author
Re: [Code] position of texture pins
Postby thomthom » Sun Nov 06, 2011 10:17 pm
That's very interesting.
btw...
Aerilius wrote:Note: SketchUp dynamically places the texture pins where the user clicks, thus they can be translated about u/v +/-1
From what I see, that is only true if the texture has not been positioned. If the use has positioned the texture, then the pins appear where they where last placed.
User avatar
PluginStore Author
PluginStore Author
Postby thomthom » Sun Nov 06, 2011 10:18 pm
Btw, where was that C code?
Could be interesting to have that in a C Extension...
User avatar
PluginStore Author
PluginStore Author
Postby Aerilius » Sun Nov 06, 2011 10:42 pm
It's available as a pdf at the bottom of that page: http://www.cs.cmu.edu/~ph/
thomthom wrote:If the use has positioned the texture, then the pins appear where they where last placed.
I tested it again. It's true, when the user has changed the pins from their default positioning, they stick fixed. But still the uvq sometimes don't match the pins (once I got [-1,0,1] for the red pin).
Aerilius
PluginStore Author
PluginStore Author
Postby Aerilius » Tue Aug 14, 2012 3:31 pm
I suddenly got a bit more understanding of what we actually do here... :idea:
So this whole code is actually much simpler. SketchUp gives us a Q coordinate (that we didn't use so far). In fact we don't need a 4×4 transformation matrix (rectangle ←→ quadrilateral), but a 3×3 matrix is enough. That means we can get rid of very expansive calculations and even use SketchUp's native Geom::Transformation (which is 3×3). All the details in the code below and in this thread:
Code: Select all
module AE;end # (replace this by your author/company namespace!)
class AE::UVHelper
# This initializes our UVHelper. It calculates the transformation matrix between
# model space (XYZ) and texture space (UVQ). We also create an instance of SketchUp::UVHelper
# for faster conversion from model to texture space (but it can't do the reverse).
# @param [Sketchup::Face] face The face on which we want to convert coordinates.
# @param [Sketchup::Face] on_front True if you want the texture coordinates for the front face, false if not. Defaults to true.
# @param [Sketchup::Face] on_back True if you want the texture coordinates for the back face, false if not. Defaults to true.
# @param [Sketchup::TextureWriter] tw A TextureWriter object.
# @return [AE::UVHelper]
def initialize(face, on_front=true, on_back=true, tw=Sketchup.create_texture_writer)
  @face = face
  ### Get the native UVHelper for for conversion from XYZ to UVQ.
  @uvh = face.get_UVHelper(on_front, on_back)
  ### Get a transformation matrix for UVQ to XYZ.
  # Since every quadrilateral can be understood as a perspectivic projection of a 3d rectangle,
  # we do not need to find a transformation [square <-> quadrilateral] (4x4 matrix) but only an
  # affine transformation in 3d space (3x3 matrix, can use Geom::Transformation!).
  # Get 3 points of a square of size 1*1. It spans a local 2d space of the face's plane (XY).
  p0 = face.vertices[0].position
  p1 = face.vertices[1].position
  vec01 = p0.vector_to(p1).normalize
  p1 = p0 + vec01
  vec12 = (vec01 * face.normal)
  p2 = p1 + vec12
  # For one side of the face
  get_transformation = Proc.new{|side|
    # Get their uvq
    uvq = [p0,p1,p2].collect{|p|
      get_UVQ(p, side)
    # Get the transformation of the between model space (XYZ) and the face (XY).
    txyz = Geom::Transformation.axes(p0, vec01, vec12, face.normal) # * scaling(1)
    # Get the transformation of the between the face (XY) and UVQ.
    # Since we have input a square, it corresponds to a rectangle in UVQ space
    # and we may use an axes transformation (that's why 3 points are enough).
    vecuvq01 = uvq[0].vector_to(uvq[1])
    vecuvq12 = uvq[1].vector_to(uvq[2])
    vecuvqn = vecuvq01*vecuvq12
    tuvq = Geom::Transformation.axes(uvq[0], vecuvq01, vecuvq12, vecuvq01*vecuvq12) *
           Geom::Transformation.scaling(ORIGIN, vecuvq01.length, vecuvq12.length, 1)
    # The combined transformation from texture space to model space.
    t = txyz * tuvq.inverse
    # The projection plane (necessary if confronted with UV and Q=1)
    plane = [uvq[0], vecuvqn]
    [t, plane]
  @t_front_uvq2xyz = @t_back_uvq2xyz = Geom::Transformation.new()
  @plane_front = @plane_back = [ORIGIN, Z_AXIS]
  @t_front_uvq2xyz, @plane_front = get_transformation.call(true) if on_front
  @t_back_uvq2xyz, @plane_back = get_transformation.call(false) if on_back
# Wrapper method for Sketchup::UVHelper (more useful with front/back Boolean)
# @param [Geom::Point3d, Array] xyz A point in model space.
# @param [Boolean] on_front Whether you want the texture coordinates for the front face or the back face.
# @return [Geom::Point3d] Point The corresponding point in texture space (UVQ).
def get_UVQ(xyz, on_front=true)
  return (on_front)? @uvh.get_front_UVQ(xyz) : @uvh.get_back_UVQ(xyz)
# Get the coordinates in model space from given coordinates in texture space.
# @param [Geom::Point3d, Array] uvq A point in texture space (UV or UVQ).
# @param [Boolean] on_front Whether you want the model coordinates for the front face or the back face.
# @return [Geom::Point3d] Point The corresponding point in model space (XYZ).
def get_XYZ(uvq, on_front=true)
  # If the input is a 2d texture coordinate (UV with Q==1) it may not lay on the
  # projection plane and our transformation won't work with a 3x3 matrix.
  # Thus find the correct Q value on the projection plane.
  vec_q = [uvq[0]*2, uvq[1]*2, (uvq[2]||1)*2]
  uvq = Geom.intersect_line_plane([uvq, vec_q], (on_front)? @plane_front : @plane_back)
  return uvq.transform((on_front)? @t_front_uvq2xyz : @t_back_uvq2xyz)
# @param [Geom::Point3d, Array] Point A point in texture space (UV or UVQ).
# @param [Boolean] on_front Whether you want the texture pins for the front face or the back face.
def get_texture_pins(on_front=true)
  pins = [ get_XYZ([0,0,1], on_front),
           get_XYZ([1,0,1], on_front),
           get_XYZ([1,1,1], on_front),
           get_XYZ([0,1,1], on_front),
  return pins
Aerilius
PluginStore Author
PluginStore Author
Postby thomthom » Tue Aug 14, 2012 4:21 pm
You sure you don't need the fourth in order to get the skew and distortion?
User avatar
PluginStore Author
PluginStore Author
Postby thomthom » Tue Aug 14, 2012 4:29 pm
User avatar
PluginStore Author
PluginStore Author
Postby Aerilius » Tue Aug 14, 2012 4:37 pm
Hmm, about skewing I'm not sure, but I see it works without. I think for 4 points there are 8 degrees of freedom (? 4*[U,V] if Q=1 is constant). With varying Q it works also with 3 points 3*[U,V,Q]=9 (?).
Edit: I haven't experienced before what your image/skp shows. One construction point is across the inversion horizont of the texture (where it grows after shrinking). I have to see what can be done...
Aerilius
PluginStore Author
PluginStore Author
Postby thomthom » Tue Aug 14, 2012 4:45 pm
When you position a texture SketchUp let you provide the following Point3d and UV pairs:
1x : Position
2x : Position and Scale Uniform
3x : Position and Skew
4x : Perspective Distortion
So for the reverse one does need all four points as well - without it you lose the data.
Many render engines struggle with SketchUp's distorted textures - mainly because they read the UV data from the vertices of the face. That fails when a triangle has a distorted texture applies. And it is why SU's UV mapping methods accepts 3D points that are on the plane of the face instead of using the vertices.
Several render engines works around it by triangulating the mesh and reading the texture for each triangle - it doesn't give correct UV map though - as they only read 3 point they only get a skewed map. For some geometry you hardly notice it, but other times it is very visible.
User avatar
PluginStore Author
PluginStore Author
Postby Aerilius » Tue Aug 14, 2012 4:53 pm
But since a texture is 2d, it has 8 degrees of freedom on the plane. You need four points with 2d coordinates (UV) to sufficiently define texture position/skew/distortion. With 3d texture coordinates, we have already enough data in three 3d points (UVQ) (the third Q coordinate contains the missing info).
Aerilius
PluginStore Author
PluginStore Author
Postby thomthom » Tue Aug 14, 2012 5:19 pm
Aerilius wrote:With 3d texture coordinates, we have already enough data in three 3d points (UVQ) (the third Q coordinate contains the missing info).
I never worked out how to use that value... I tried asking the SketchUppers - but there feedback hasn't really provided anything...
User avatar
PluginStore Author
PluginStore Author
Postby renderiza » Mon Oct 15, 2012 3:50 am
I am so frustrated that I don’t possess the knowledge yet to understand most of this discussion. Correct me if I am wrong but could this code make animating textures possible? If so I am very interested in trying to figure how I can do this myself.
User avatar
renderiza
Premium Member
Premium Member
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Developers' Forum
Who is online
Users browsing this forum: AleksandrOdessa1990, Bing [Bot], Google Bot and 12 guests
