How to debug?
Re: How to debug?
Postby Jim » Tue Aug 23, 2011 10:11 pm
end if!
Jim
Global Moderator
Re: How to debug?
Postby Dan Rathbun » Tue Aug 23, 2011 10:29 pm
tomot wrote:
Dan Rathbun wrote:
    line 7: no argument for the instance method DefinitionsList.add()
    No that's not it ! ..... nice try!..... try again?
    Wow... that's strange! An empty argument creates a new definition, whose name is "Component". The API does not mention this!!!
    And Jim.. got it correct... although I would think Ruby would issue a ScriptError, something like "blah blah blah...`end' expected"
      I'm not here much anymore. But a PM will fire email notifications.
      User avatar
      Dan Rathbun
      PluginStore Author
      PluginStore Author
      Re: How to debug?
      Postby tomot » Tue Aug 23, 2011 10:49 pm
      yup! Jim is right!. So back to the initial subject, is there a debug routine for such errors?
      your editor should be causing a high pitch sound for end if or at least a blicking, or bouncing simile. :bounce:
      tomot
      PluginStore Author
      PluginStore Author
      Re: How to debug?
      Postby Jim » Tue Aug 23, 2011 11:02 pm
      I was going to suggest checking the syntax, but you would need to have Ruby version 1.8.6 installed (not a bad idea if you are developing plugins.)
      $ ruby -c plugin.rb
      plugin.rb:32: syntax error, unexpected $end
      Jim
      Global Moderator
      Re: How to debug?
      Postby tomot » Wed Aug 24, 2011 12:16 am
      Jim wrote:I was going to suggest checking the syntax, but you would need to have Ruby version 1.8.6 installed (not a bad idea if you are developing plugins.)
      $ ruby -c plugin.rb
      Jim: you have helped me with a few rubies I have posted here in the past,
      would you please elaborate on I would install Ruby version 1.8.6 within the current Ruby/SU environment.
      Currently I simply use NotePad ++ or SciTE to edit and develop my SketchUp Rubies.
      tomot
      PluginStore Author
      PluginStore Author
      Re: How to debug?
      Postby Dan Rathbun » Wed Aug 24, 2011 12:30 am
        User avatar
        Dan Rathbun
        PluginStore Author
        PluginStore Author
        Re: How to debug?
        Postby tomot » Wed Aug 24, 2011 12:33 am
          Dan, FYI, I have used that particular code several times to space entities between 2 know points, equally. I don't recall who helped me with the original code, many years ago.
          tomot
          PluginStore Author
          PluginStore Author
          Re: How to debug?
          Postby tomot » Wed Aug 24, 2011 4:25 pm
          Jim wrote:Ruby Toolbar started - on Windows, it can open/close the Ruby Console, Clear it, and load/reload a file.
          Jim: I get the following error when starting SU
          tomot
          PluginStore Author
          PluginStore Author
          Re: How to debug?
          Postby Dan Rathbun » Wed Aug 24, 2011 5:26 pm
          You need WIn32API.so
          v186_p287_so.zip
            User avatar
            Dan Rathbun
            PluginStore Author
            PluginStore Author
            Re: How to debug?
            Postby brian_concannon » Thu Dec 22, 2011 6:40 am
            I have written a debugger for Sketchup plugins with watches and breakpoints. Why isn't such a debugger already available? Would it be a good contribution to the community? The breakpoints based on watched variable changes seem like the best part.
            Download the user guide that I attached.
            It needs some work yet, as it processes only the Ruby snytax that I have
            programmed with myself. It is a VB6 app. It would be free.
            Quote message
            Face2Face plugin - autoextrusion between faces
            Sent: Wed Dec 21, 2011 4:58 pm
            by brian_concannon
            TIG,
            I posted the plugin as you suggested, in the Resources/Plugins forum. It is being downloaded like crazy!
            I hope you make it part of your Edgedraw plugins somehow.
            anyway, I have written a debugger for Sketchup plugins with watches and breakpoints. Why isn't such a debugger already available? Would it be a good contribution to the community?
            Quote message
            Re: Face2Face plugin - autoextrusion between faces
            Sent: Wed Dec 21, 2011 5:16 pm
            To: brian_concannon
            It would probably be a useful adjunct.
            Why not post in the Developers' forum with a new thread.
            You don't need to post the whole of your code, just some ideas to get a discussion rolling...
            Thomthom, Jim and Dan are more in debugging etc than I am. I manually slog through with my own return nils, breaks, testing puts, UI.messageboxe, refreshes etc till I get it to work
            brian_concannon
            Re: How to debug?
            Postby thomthom » Thu Dec 22, 2011 9:39 am
            brian_concannon wrote:I manually slog through with my own return nils, breaks, testing puts, UI.messageboxe, refreshes etc till I get it to work
            That's my method of debugging as well. A debugger would be welcome. There is one out there already SuRDebug: http://code.google.com/p/surdebug/wiki/SuRDebug
            I never got around to fully make it work... :(
            User avatar
            PluginStore Author
            PluginStore Author
            Re: How to debug?
            Postby brian_concannon » Thu Dec 22, 2011 2:14 pm
            I tried SurDebug early on and could not make it work either. I was told that the author got angry about some criticism, and he stopped working on it. There were no recent posts about it at the site that you show.
            Debuggifier's concept is not as nice as the SurDebug concept, as it inserts debug statements after every Ruby statement in all or part of the code. It can be commented / uncommented at will, and totally removed ("undebuggified") when the Plugin development is complete. But I found it necessary to develop for my own programming, because Ruby is so hard to program with. Anyone using a true IDE knows this.
            I will clean up Debuggifier a little and then post it. Since it is an EXE and requires VB6 DLL's to be installed with InstallShield etc, can I upload it to this forum? Can I upload a zip file?
            brian_concannon
            Re: How to debug?
            Postby Rich O Brien » Thu Dec 22, 2011 2:19 pm
            There's a 4mb limit and it'll will need to be .zip
            There's a frontroom and a backroom....reverse faces
            User avatar
            Rich O Brien
            Administrator
            Re: How to debug?
            Postby Chiefwoodworker » Wed Jun 20, 2012 1:42 pm
            thomthom wrote:And under Windows you have this snippet to output the data to debuggers like DebugView:
            viewtopic.php?f=180&t=31216&p=274668#p274467
            A friend of mine showed me how to interface Unit Test (http://ruby-doc.org/stdlib-1.9.3/libdoc ... /Unit.html) to the SketchUp API and the Ruby Console. It works really great for certain classes of scripts or methods and it allows you to develop a suite of tests that you can run automatically.
            If anyone is interested I can add instructions to this forum.
            User avatar
            Chiefwoodworker
            Re: How to debug?
            Postby thomthom » Wed Jun 20, 2012 1:46 pm
            Chiefwoodworker wrote:If anyone is interested I can add instructions to this forum.
            :thumb: :thumb:
            User avatar
            PluginStore Author
            PluginStore Author
            Re: How to debug?
            Postby liquid98 » Sun Jul 01, 2012 6:58 pm
            [encourage] :thumb: [/encourage]
            Things that flourish fall into decay. This is not-Tao, And what is not-Tao soon ends ~ Lao tse
            User avatar
            liquid98
            by Ad Machine » 5 minutes ago
            Ad Machine
            Robot
            Previous
            Return to Developers' Forum
            Who is online
            Users browsing this forum: eneroth3, michnaw, rxavi and 12 guests
            Visit our sponsors:
