[Plugin Library] LibFredo6 - v10.6a - 01 Jun 20
Re: [Plugin Library] LibFredo6 - v3.7b - 22 Apr 11
Postby COSEDIMARCO » Tue Jun 07, 2011 4:25 am
Updated version of the Italian Translation of Fredo6 Library
LibFredo6_IT.zip
COSEDIMARCO
Postby TIG » Tue Jun 07, 2011 9:12 am
Daniel S wrote:
Fredo6 wrote:This is where is the problem: 99999 is too big for a number of days.
Can you change it in the default parameters or in the Upgrade dialog box
I'll put a check in a next release
I can´t change the 99999 because:
- The Upgrade dialog box don´t open
- In default Parameters I can change it but it doesn´t really change.
In the attach video I show what happens.
I tried reinstalling LibFredo6 but still no work.
Daniel S
If you feel up to adding one line of code into a rb file using a plain text-editor like Notepad[++].exe... find this file
open it and add this line and save it
Then you can't wait more than a year [365 days]
User avatar
Global Moderator
Postby fredo6 » Tue Jun 07, 2011 9:35 am
Daniel S wrote:I can´t change the 99999 because:
Daniel S
Daniel,
I published a new release that should fix the issue.
User avatar
PluginStore Author
PluginStore Author
Re: [Plugin Library] LibFredo6 - v3.7c - 07 Jun 11
Postby fredo6 » Tue Jun 07, 2011 9:58 am
NEW RELEASE LibFredo6 3.7c - 07 Jun 2011
This is a minor maintenance release.
  • Fix an issue in CheckForUpdate (next date t check) signaled by Daniel S
  • Updated Italian translation by COSEDIMARCO
  • Updated Spanish transaltion by Defisto
New release is available for download in the first post of this thread.
User avatar
PluginStore Author
PluginStore Author
Postby Daniel S » Tue Jun 07, 2011 1:07 pm
Fredo6 wrote: new release that should fix the issue.
Thank you Fredo!!! The update fix it. :berserk:
I am very good for breaking things.. and you are very good for fixing them. That´s a great team :lol:
TIG, Thank you too. You are always there when someone has a problem :thumb:
Now, time to update some plugins :D
Thank you again,
Daniel S
Daniel S
Postby fredo6 » Tue Jun 07, 2011 10:33 pm
Daniel S wrote:Thank you Fredo!!! The update fix it. :berserk:
I know you have a special bug detector :P
@TIG: thanks also for your quick support.
Daniel S wrote:Now, time to update some plugins :D
The CheckFor Update functions is actually opened to other script writers, not just mine. It does not require that the scripts use LibFredo6 (by the way, JPP an BezierSpline don't use LibFredo6 but are visible in the list).
User avatar
PluginStore Author
PluginStore Author
Postby TIG » Wed Jun 08, 2011 8:56 am
To find buggy code in others scripts I start off with Baregrep looking for the particular method or reference by name...
That then lets me open the potentially problematical .rb directly at the line indicated and I can read the code and hopefully see what needs adjustemnt...
I even do it with my own stuff, as it's often awkward to work out what's defined/changed where - especially months after you wrote it... :geek:
User avatar
Global Moderator
Postby rjjvirusx » Wed Jun 08, 2011 3:24 pm
Thank you ~~~~~~~ :berserk: :berserk: :berserk: :berserk: :berserk: :berserk: :berserk: :berserk:
rjjvirusx
Postby wagoneer » Tue Jun 14, 2011 4:40 pm
Fredo's plug in looks exactly what I need. Does it work with SU 8? Having installed it as described (I'm OSX 10.5.8) I still get an error. I've read every post over the 19 pages and can't find any clues. My directory is not quite as shown as I have:
Macintosh HD/Library/Application Support/Google SketchUp 8/SketchUp/Plugins
All the files are there as described. Is it simply that it won't work with SU8 or am I doing something wrong?
Thanks in advance to anyone can help.
Wagoneer
wagoneer
Postby Gaieus » Tue Jun 14, 2011 4:47 pm
Kelly, what are you trying to install? (LibFreo will not do anything - it is just a "background" library for a bunch of Fredo's "real" tools)
User avatar
Postby wagoneer » Tue Jun 14, 2011 4:51 pm
Sorry Gaieus, realised I hadn't said what I was doing as I hit 'submit'.....
I want to use FredoScale. I have installed as per instructions, and have also installed RoundCorner. Enclosed is a picture of my plugins.
wagoneer
Postby fredo6 » Tue Jun 14, 2011 6:40 pm
Wagoneer
You have a file __loader.rb in the Sketchup Plugin directory.
I don't know how you manage to have it there, but try to remove it and check if it works
PS: for RoundCorner, you did not do the correct installation too. Please read the main thread and check the footprint. It seems that your unzip method does not create the proper folder and files. I would suggest that you unzip in a neutral place, then check the files and folders and then copy to the Sketchup directory.
User avatar
PluginStore Author
PluginStore Author
Postby wagoneer » Wed Jun 15, 2011 9:09 am
Fredo, thank you very much. I also downloaded FredoScale to my Mac at home last night where I only use the inbuilt OSX extraction software and it worked fine. Seems the problems were with the Zipeg extraction software. Having just thrown that software away and downloaded your plug-ins again, everything works fine.
Cheers folks.
Kelly
wagoneer
Postby lavangmuathu » Fri Jun 24, 2011 5:44 am
thank you so much , great :fecstatic:
lavangmuathu
Postby billjest » Sat Jul 09, 2011 11:26 am
Thank you this transforms the whole package for me.
billjest
Postby gobilman06 » Thu Aug 04, 2011 11:39 am
Hi there i already install lilfredo6 plugins but the thing is i cant see the icon in my tool bar. pls help... cheers!
gobilman06
Postby Dave R » Thu Aug 04, 2011 12:14 pm
Do you know why you installed LibFredo6 in your Plugins directory? Or are you just installing all the plugins you can find?
This is a support file for many of Fredo's excellent plugins. It is required by them to operate correctly.
User avatar
Global Moderator
Postby fredo6 » Thu Aug 04, 2011 10:51 pm
gobilman06 wrote:Hi there i already install lilfredo6 plugins but the thing is i cant see the icon in my tool bar. pls help... cheers!
At least, do you see the menu Windows > LibFredo6 Settings....?
If so, you just have to install the plugin (like FredoScale, RoundCorner, ...) and it should be OK.
User avatar
PluginStore Author
PluginStore Author
Postby gobilman06 » Fri Aug 05, 2011 5:42 pm
No worries already sort it out. thanks a lot!
gobilman06
Re: [Plugin Library] LibFredo6 - v4.0a - 23 Aug 11
Postby fredo6 » Tue Aug 23, 2011 9:53 am
NEW RELEASE: LibFredo6 v4.0a - 23 Aug 11
LibFredo6 4.0 is a major technical release. The intention is to simplify the installation of my plugins and make their loading more robust, with error detection and protection.
A main feature of LibFred06 4.0 is that the ZLoader__xxx.rb files are no longer used (it will work however even if you still have them in your plugin folder, but it is advised to delete them). This means that my plugin will now be published as a simple folder (like ROUNDCORNER_Dir_22) to be put in the same directory as LibFredo6. The plugins will only be loaded if you have LibFredo6 installed and load errors will be tracked and reported.
LibFredo6 4.0 also includes a few plugin maintenance utilities available in the Windows > LibFredo6 Settings... menu:
1) Purge Obsolete files
This utility shows the files which are no longer useful and that you can safely delete. Indeed, you will see there all the ZLoader__xxx.rb files which are now ignored.
2) Plugin load performances
It displays the time for loading the plugins based on LibFredo6. I am interested in getting a feedback on these load times as it seems to be different on different machines and systems.
3) Trace Log viewers
LibFredo6 4.0 stores some traces (in a temporary folder). Currently this is mainly related to the load cycle of the scripts. If an error has happened it will be recorded there. Note that there is n Export feature (as a TXT file) which might be useful for reporting problems to the author if needed.
4) Plugin directory location
Just to recall that LibFredo6 (and all my scripts) can be located in another directory than the standard SU one.
In this respect, it might be useful to install 000_AdditionalPluginFolders.rb script. This will allow you to specify additional plugin directories and put LibFredo6 there.
I recommend to install LibFredo6 v4.0 as it will be more robust and easier (for me) to support.
See Main Post for detailed documentation and download.
User avatar
PluginStore Author
PluginStore Author
Postby bac9-flcl » Tue Aug 30, 2011 12:16 pm
Great release! :ecstatic:
However, there seems to be a small issue... It seems that if you won't manually delete an old ZLoader, the new menu won't appear (and perhaps the library won't be loaded properly?). The problem is that I don't remember how exactly that ZLoader file was called, something like ZLoader__LibFredo.rb, but I'm not sure at all, - just deleted it and there is now no way to know the exact name, unfortunately. :? And it's not there in LibFredo 3.7b archive I found around, so perhaps it's some ancient file from a very old release. Anyway, after I've deleted it, everything loaded properly, and is now working well. :)
User avatar
bac9-flcl
link to download [Plugin Library] LibFredo6 - v4.0a - 23 Aug
Postby Lulliloo1 » Wed Aug 31, 2011 9:06 am
There are a lot of links ABOUT '[Plugin Library] LibFredo6 - v4.0a - 23 Aug 11'. I've spent quite some time unsuccessfully looking for the link to actually download '[Plugin Library] LibFredo6 - v4.0a - 23 Aug 11'. Would someone please provide that? It would be helpful to others to also provide that as part of this subject.
Lulliloo1
Postby Gaieus » Wed Aug 31, 2011 9:35 am
In the first post, there is a big Download button under which there is the link (or click on the image below - you need to be logged in)
User avatar
Postby Lulliloo1 » Wed Aug 31, 2011 3:53 pm
ref my post this morning regarding downloading:
The download link did not work with Google Chrome, but it did with Windows Explorer (9). Problem solved...
Lulliloo1
Postby Dave R » Wed Aug 31, 2011 8:31 pm
Lulliloo1 wrote:ref my post this morning regarding downloading:
that's odd. I've never had any trouble downloading any files from here with Chrome. You might want to check your settings in Chrome.
User avatar
Global Moderator
Postby bimbachi » Fri Sep 09, 2011 11:12 am
hello
i'm having problem with "Check Plugins for Update"
attached screen info
any idea how to solve it?
regards
ps.-i'm on mac, osx 10.7.1
bimbachi
Postby fredo6 » Fri Sep 09, 2011 12:38 pm
bimbachi wrote:hello
regards
Can you check your version of Safari.
If it is Safari 5.0.6, then bad luck, there is a big issue (which is under resolution, see that thread)
Thanks to confirm. Also, do you see the images in the dialog box (I mean the small + and - at the top of the table, on left)?
PS: I hope I can publish a fix soon.
User avatar
PluginStore Author
PluginStore Author
Postby bimbachi » Fri Sep 09, 2011 5:53 pm
Safari is Version 5.1 (7534.48.3)
You are right images not showing correctly.
regards
bimbachi
Re: [Plugin Library] LibFredo6 - v4.1a - 11 Sep 11
Postby fredo6 » Sun Sep 11, 2011 5:33 pm
NEW RELEASE: LibFredo6 v4.1a - 11 Sep 11
LibFredo6 4.1 is a technical release which normally fixes some issues for recent version of Mac OS and Safari 5.0.6 and above (images not displayed and check for update not working).
User avatar
PluginStore Author
PluginStore Author
Postby bimbachi » Sun Sep 11, 2011 6:11 pm
"Fredo6"]NEW RELEASE: LibFredo6 v4.1a - 11 Sep 11
hmm, problem persist the same - images and update, message is;
"ERROR in Check for Update
Please verify your Internet connection
The Following URLS could not be checked
-- Sketchucation Forum (viewtopic.php?f=180&t=3263)"
bimbachi
by Ad Machine » 5 minutes ago
Ad Machine
Robot
PreviousNext
Return to Plugins
Who is online
Users browsing this forum: Blubk, eowens, eripea1975, Google Bot, hungven1810 and 15 guests
Visit our sponsors:
