[Plugin] ExtrudeTools - Full Set
Re: [Plugin] ExtrudeTools - Zipped Set 20110528
Postby TIG » Sat May 28, 2011 12:47 pm
Here's an updated set viewtopic.php?p=217663#p217663
The 'Extrude Edges By Vector To Object' tool has been improved considerably:-
A new algorithm has been added for the intersecting with objects: now walls extend to soffits with additional apex vertices and so on so it extrudes fully to the faces/edges.
'Ghost' extrusions now show intersections as red dots.
The original selection is kept, unless the is group exploded.
Some ES lingvos updated by Defisto [thanks].
User avatar
Global Moderator
Re: [Plugin] ExtrudeTools - Zipped Set 20110528a
Postby TIG » Sat May 28, 2011 2:10 pm
Here's another update viewtopic.php?p=217663#p217663
The 'Extrude Edges By Vector To Object' tool has additional traps added for rare glitches when a faced edge-selection was used.
User avatar
Global Moderator
Re: [Plugin] ExtrudeTools - Zipped Set 20110528b
Postby TIG » Sat May 28, 2011 2:30 pm
Here's yet another update viewtopic.php?p=217663#p217663
The 'Extrude Edges By Vector To Object' tool has had a glitch fixed with 'undo' if you'd reversed faces etc...
User avatar
Global Moderator
Re: [Plugin] ExtrudeTools - Zipped Set 20110528c
Postby TIG » Sat May 28, 2011 5:44 pm
The 'Extrude Edges By Vector To Object' tool has had glitches fixed with 'commit' and extruding faces inside groups to objects outside...
User avatar
Global Moderator
Postby Wildchild » Sat May 28, 2011 7:16 pm
:berserk: DUUUDE! Exactly what I was talking about!
Here's a few tests:
I have a couple more tiny requests to ask, but now i don't have time! :lol:
Eternity is very long, especially towards the end. Woody Allen
Wildchild
Postby unclex » Sun May 29, 2011 3:01 am
[Plugin] ExtrudeTools - Zipped Set 20110525 Installed
[Plugin] Shape Bender Beta v0.55 Can't work...
Need Help !!!
ThanX
unclex
Postby hebeijianke » Sun May 29, 2011 4:25 am
TIG wrote:....
I translate All the plugins in ExtrudeTools into chinese
This is the translation file
hebeijianke
Postby TIG » Sun May 29, 2011 9:55 am
unclex wrote:[Plugin] ExtrudeTools - Zipped Set 20110525 Installed
Need Help !!!
ThanX
I [and many others] have both toolsets installed without any interconnected problems :?
Can you explain the nature of the problem a bit more ?
Are there any error messages [either at startup or when it's run with the Ruby Console open]? if so please post them here, or perhaps more logically in the ShapeBender thread, as that's the broken tool.
Nothing has changed between recent versions of the EEby... tools that I could think might affect ShapeBender in any way. that tool itself has been around for some time...
Please check you have progressbar.rb installed in the Plugins folder [available free from Smustard.com] - this is a frequent cause of tools failing that need it [it's not needed for any of the EEby... tools though!]
User avatar
Global Moderator
Postby TIG » Sun May 29, 2011 9:56 am
hebeijianke wrote:
TIG wrote:....
I'll include them with the next update of the toolset.
Meanwhile Chinese locale users can install them into the TIGtools folder and feedback...
User avatar
Global Moderator
Postby Jim » Sun May 29, 2011 10:47 am
Hi TIG,
Shouldn't there be a Toolbar? I don't see it. I have all the EEb Tools in the Plugins menu, but no Extrusion* in Toolbars.
Jim
Global Moderator
Postby TIG » Sun May 29, 2011 11:06 am
There should be a file in ../Plugins/ #extrusionToolbar.rb makes the Toolbar/Sub-Menu.
It starts with a '#' so it loads first - it then checks to see if any of the possible EEby...rb files exist and if so it adds the 'Extrusion Tools' toolbar referenced as '$extrusionToolbar' and an 'Extrusion Tools' submenu referenced as '$extrusionToolsSubmenu'. As each of the EEby...rb files loads it checks for these $ references and if they don't exist then there is no toolbar/button and the tool's menu item is added direct to Plugins-menu rather than into a subfolder...
Your screen-shot suggests that #extrusionToolbar.rb is missing as there's no 'Extrusion Tools' submenu ??
Note that the EEby... tools also 'require' deBabelizer.rb ?
User avatar
Global Moderator
Postby Jim » Sun May 29, 2011 11:11 am
TIG wrote:Your screen-shot suggests that #extrusionToolbar.rb is missing as there's no 'Extrusion Tools' submenu ??
Ah, I renamed it without the #. Guess I can't do that.
Jim
Global Moderator
Postby TIG » Sun May 29, 2011 11:13 am
NO! It needs to load before the other tools so they find the toolbar/submenu ready-made...
The existence of the EEby...rb tools are checked by it 'by name' so renaming all of those would also stop the toolbar/submenu getting created...
Its filename doesn't have to start with a #, it just needs to list somewhere before the other tools in alphanumeric order... I use a leading # on the name of for my tools if I want it to load early - like the '#HolePunchTool.rb', as I want its items high up on the context-menu listings...
:roll:
User avatar
Global Moderator
Postby Jim » Sun May 29, 2011 11:16 am
And I use C:\Plugins rather than the default so I can share plugins between versions. EEbX isn't portable in that way either.
Thanks.
Jim
Global Moderator
Re: [Plugin] ExtrudeTools - Zipped Set 20110529
Postby Jim » Sun May 29, 2011 11:32 am
I made these mods to make it portable:
starting @ ~ line 50
Code: Select all
    eePlugins.each{|plugin|
   path = File.join(File.dirname(__FILE__), plugin+".rb")
   #if Sketchup.find_support_file(plugin+".rb","Plugins/")
   if File.exists?(path)
       gotPlugin=true
       break
   end#if
Jim
Global Moderator
Postby TIG » Sun May 29, 2011 11:36 am
The tool now makes the Extrusion Tools toolbar/submenu even if the various .rb files are not located in the standard ../Plugins/ folder and are loaded from elsewhere [it now uses File.dirname(__FILE__) rather than the .find_support_file() which is limited to a standard set of folders]. It just requires that all of the files [including those in the ../TIGtools/ submenu] are kept in the same relative locations rather than the previous absolute ../Plugins/ location...
It also includes the latest Chinese lingvo files, thanks to 'hebeijianke'...
User avatar
Global Moderator
Postby TIG » Sun May 29, 2011 11:37 am
Jim wrote:I made these mods to make it portable:
Code: Select all
       gotPlugin=true
       break
   end#if
I had just made very similar changes - you posted as I uploaded it - see updated set... :roll:
User avatar
Global Moderator
Postby Jim » Sun May 29, 2011 11:40 am
Frequent updates are another advantage of using a shared Plugins folder! :lol:
Thanks again.
Jim
Global Moderator
Postby TIG » Sun May 29, 2011 11:41 am
Jim wrote:Frequent updates are another advantage of using a shared Plugins folder! :lol:
I think I'm done for a while on updating this tool... :roll:
User avatar
Global Moderator
Postby unclex » Sun May 29, 2011 12:51 pm
Sorry , my mistake
the reason is another Plugins
Thanx for ur replied
unclex
Postby manson666 » Fri Jun 03, 2011 2:29 pm
I'm new Sketchup user
now learning it
I founded out sketchup plug in is strong tool
thx share
manson666
Postby openhatch » Fri Jun 03, 2011 10:47 pm
If I haven't said this before, awesome tools, thx. :thumb:
This doesn't play well with SketchyPhysics; this newest version won't extrude edges by rails successfully if SketchyPhysics is installed. So I keep the two installed in different versions of Sketchup. :(
openhatch
Postby TIG » Sat Jun 04, 2011 9:24 am
openhatch wrote:If I haven't said this before, awesome tools, thx. :thumb:
I know about the SketchyPhysics issue - it can also affect other tools... viewtopic.php?p=300111#p300111
The fix is relatively simple BUT it means recoding a few lines in one of the SketchyPhysics rubies...
viewtopic.php?p=300105#p300105
User avatar
Global Moderator
Postby Destors » Sun Jun 05, 2011 7:37 am
How i need to make these things, help me please :)
Destors
Postby openhatch » Sun Jun 05, 2011 7:43 am
TIG wrote:I know about the SketchyPhysics issue - it can also affect other tools...
Okay, I knew you knew; I guess I might have clarified I was wondering if it's an outstanding problem (I hadn't read those posts you link to here). But the fix you link to will do (assuming it works, as I haven't tried it yet), thanks!
openhatch
Postby billychaics » Tue Jun 07, 2011 12:36 pm
Thanks guys this is extremely good plugin that i was looking for so long
billychaics
Postby doraemon79 » Wed Jun 29, 2011 10:47 am
Wonderful tool....
doraemon79
Postby rock1 » Mon Aug 08, 2011 9:30 am
this toolset is a bit complicated for usage for a novice like me. I'm getting some unexpected results. Are there any video tutorials :roll:
Signature removed by SCF Admin
rock1
Postby majid » Mon Aug 08, 2011 6:41 pm
ow... it jumps out of Sketchup with no error message!!! (almost half of tools!!!! eebe , eebf,eebfs, EEbR)
My V-Ray book for architects: https://goo.gl/cz1oRc
User avatar
majid
Top SketchUcator
Postby TIG » Mon Aug 08, 2011 7:32 pm
Majid
Have you installed any new Plugins lately?
Try disabling them temporarily and see if that helps.
Do you get any error messages in the Ruby Console before the 'crash'?
If you do find the culprit let use know asap.
Have you tried repair/reinstall Sketchup and/or reinstalling the Extrusion tools again...
This is weird :?
User avatar
Global Moderator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
PreviousNext
Return to Plugins
Who is online
Users browsing this forum: Google Bot, guilhermeseror, Roselia, Samshit Samshit, shashankraok, vishnu palaniappan and 8 guests
Visit our sponsors:
