by Simon B » Sat Oct 02, 2010 1:41 am
Visual Color Picker does exactly what it says =)
Simon B
by Gaieus » Sun Oct 03, 2010 12:12 am
Thanks James, impressive list! I already use some of them but there's indeed a bunch to discover...
- Name: Csaba Pozsárkó
- Operating system: Windows
- SketchUp version: 2013
- License type: Pro
- SketchUp use: historical reconstruction
- Level of SketchUp: Advanced
by solo » Fri Oct 08, 2010 1:32 am
- Global Moderator
- Name: solo
- SketchUp version: 2017
- License type: Pro
- SketchUp use: other
- Level of SketchUp: Intermediate
by Zacchia » Wed Oct 20, 2010 8:36 am
sure this is very helpful if you work with a lot of files: http://www.mootools.com/plugins/us/index.aspYou can see all files as small tumbnails. It reads different files and you can also save them as different. Also convert files with batch command or polygon reduce with batch command and much more is possilbe. I could not be without it!
Zacchia
- Name: Zacchia
- SketchUp version: 7
- License type: Pro
- SketchUp use: interior design
by majid » Wed Oct 20, 2010 1:58 pm
http://www.artweaver.de/ is ignored.... simple and powerfull painting application for free
majid
- Top SketchUcator
- Name: Majid
- SketchUp version: 8
- License type: Free/Make
- SketchUp use: architecture
by Pixero » Wed Oct 20, 2010 7:58 pm
Found this free photoshop plugin for normal map creation: http://cgted.com/
Pixero
- Name: Pixero
- SketchUp version: 2019
- License type: Pro
by solo » Wed Oct 20, 2010 8:05 pm
Nice find Pixero.
- Global Moderator
- Name: solo
- License type: Pro
by pichuneke » Thu Oct 21, 2010 9:57 am
Plugin for Gimp for normal map creation: http://code.google.com/p/gimp-normalmap/(Only free software, as always  ) By the way, do you know how to turn a normal map into a bump map? I want to use Bitmap to Mesh with a normal map, but first I have to turn it into a bump map...
Forgive my spanglish...
pichuneke
by Pixero » Thu Oct 21, 2010 6:29 pm
pichuneke wrote:By the way, do you know how to turn a normal map into a bump map? I want to use Bitmap to Mesh with a normal map, but first I have to turn it into a bump map...
Converting a normal map to a bumpmap/heightmap/displacementmap isnt so easy. You can maybe fake it either by converting the normalmap to grayscale or using the blue channel as a base. There are some programs that can do it rather well: http://www.crazybump.com/Commercial, good but kind of expensive. http://www.xnormal.net/Downloads.aspxFree? Can convert normalmap to cavity map but that isnt really a heightmap more like a occlusion map. http://shadermap.com/Free command line version or commercial (19.95) pro version with UI. Here is some examples with Shadermap: nlinsample.jpg nlinsample_DISP.jpg
Pixero
- Name: Pixero
- License type: Pro
by pichuneke » Thu Oct 21, 2010 6:43 pm
Thanks Pixero. It seems that Shadermap is what I am looking for (as I do my work for free, with free tools).
pichuneke
by pilou » Thu Oct 21, 2010 6:54 pm
ChaoscopeThe more easiest program : 3 keys F3,F4 ESCAPE Maybe a day it will gives the 3D Export  Usefull for make crazzy background Click image if scroll bar chaos.jpg
- Top SketchUcator
- Name: Pilou
- SketchUp use: hobby
by Al Hart » Tue Oct 26, 2010 5:34 am
[Edit - I presumed you wanted to turn a mesh into a bump map - I may have answered the wrong question.] We wrote a (not free) app to turn a mesh into a bump-map. The trick is to look at the mesh from head on and make the closer faces either brighter or darker. A bump map does not have colors, but uses intensity of gray scale to represent Z-distance offsets. We did this by extracting all the faces and running them through an OpenGL renderer which turned the distance from the camera into shading intensity. This worked well, but it was hard to find a good application for it. You might be able to get a similar effect by making the object white, using a parallel projection, turning off all lighting, turning off edges, and adding fog. Then the amount of fog should represent the distance from the camera plane, and product the bump map.
Al Hart
- PluginStore Author
- Name: Al Hart
- License type: Pro
by shura » Tue Oct 26, 2010 8:21 am
Thanks for sharing Pilou, Chaoscope is really beautiful!
shura
- Name: Alexander
- License type: Pro
by Gaieus » Tue Oct 26, 2010 8:25 am
Al Hart wrote:You might be able to get a similar effect by making the object white, using a parallel projection, turning off all lighting, turning off edges, and adding fog. Then the amount of fog should represent the distance from the camera plane, and product the bump map.
I have made reasonable displacement maps like this actually. Best is to use hidden line face style (to get rid of face shading completely) and hide all edges in the style panel. You may want to exaggerate the geometry a little bit to get the desired effect with the fog but grouping the whole thing and scaling along the Z axis makes it easy.
- License type: Pro
by notareal » Sat Apr 30, 2011 4:47 pm
http://www.holmes3d.net/graphics/meshman/What is MeshMan?
MeshMan is a 3D modeling tool. It loads and manipulates 3D mesh geometry in a few useful ways. It supports multiple subdivision schemes for smoothing a mesh, decimation for thinning a mesh, transforms for rotating, scaling, or translating a mesh, can tessellate a mesh into triangles, and supports a few other minor manipulations.
The primary file format MeshMan works with is the OFF format, a simple format for storing 3D data. For more information on the OFF format, see the pages for my RoffView OFF viewing program and the related OFF Tools page. MeshMan works only with the most basic type of OFF files and does not load the texture coordinates that RoffView can handle. This is because handling that extra data is beyond the scope of MeshMan's manipulations. MeshMan can also open simple OBJ files, and can export to several other formats, including STL and PLY.
notareal
- Thea Render Support
- Name: notareal
by Burkhard » Wed May 04, 2011 9:42 pm
Zacchia wrote:sure this is very helpful if you work with a lot of files: http://www.mootools.com/plugins/us/index.aspYou can see all files as small tumbnails. It reads different files and you can also save them as different. Also convert files with batch command or polygon reduce with batch command and much more is possilbe. I could not be without it!
Skp files are only for 32 bit available
Burkhard
- Premium Member
- Name: Burkhard
- License type: Pro
by valerostudio » Fri Aug 19, 2011 1:31 pm
http://www.artrage.com/Hands down one of the best 'painting' programs out there. The Ipad app is amazing and super cheap and the desktop versions are much much cheaper than Corel Painter and Artrage has all of the same functionalities.
valerostudio
- SketchUp version: 2015
- License type: Pro
by Mike Lucey » Fri Aug 19, 2011 3:43 pm
Thanks for the headsup on Artrage. I did not know it was now available for the iPad. Must check it out AND yes the iPad Apps are great value for money. This seems to be a GOOD trend. I imagine an app like Artrage would rock on the rumoured iPadHD
Mike Lucey
- Mayor
- Name: Mike Lucey
- Operating system: Mac
- SketchUp version: 2021
- License type: Pro
by bjornkn » Fri Aug 19, 2011 10:22 pm
A program I've been using for many years, but still not often mentioned is Xara http://xara.comIt comes in different versions, and is a very fast and nice vector drawing program as well as capable of doing a lot of bitmap editing as well. Great for materials as well as all kinds of images, brochures, pdfs, Flash animations etc. And it is also excellent for making great web sites, which looks pretty much identical in all browsers - which is not an easy task to do by hand
bjornkn
- Name: Bjørn Kåre Nilssen
- License type: Pro
by EscapeArtist » Sat Oct 29, 2011 11:28 pm
Don't know if this has been mentioned already: https://chrome.google.com/webstore/deta ... i?hl=en-USFor Chrome. 3DTin.
EscapeArtist
- Top SketchUcator
- Name: EscapeArtist
- License type: Pro
by 3eighty » Sun Oct 30, 2011 6:05 am
Is there a free version someplace? (edited by solo as free copy sounded suspect, I'm sure you meant version)
3eighty
by Pg09 » Sun Oct 30, 2011 1:27 pm
Hello! Is there a free panorama maker that i could use for my photos?
Pg09
by Jim » Sun Oct 30, 2011 1:41 pm
Pg09 wrote:Hello! Is there a free panorama maker that i could use for my photos? Hugin?
Jim
- Global Moderator
- Name: Jim
- License type: Pro
by utiler » Sun Oct 30, 2011 11:40 pm
bjornkn wrote:A program I've been using for many years, but still not often mentioned is Xara http://xara.comIt comes in different versions, and is a very fast and nice vector drawing program as well as capable of doing a lot of bitmap editing as well. Great for materials as well as all kinds of images, brochures, pdfs, Flash animations etc. And it is also excellent for making great web sites, which looks pretty much identical in all browsers - which is not an easy task to do by hand
Ditto!!! Very powerful app!!
purpose/expression/purpose/....
utiler
- Top SketchUcator
- Name: Andrew
- License type: Pro
by Pg09 » Sat Nov 05, 2011 6:54 pm
Jim wrote:Pg09 wrote:Hello! Is there a free panorama maker that i could use for my photos? Hugin?
Nice, gonna try it. Thank you!
Pg09
by RichardCherry » Tue Nov 22, 2011 9:38 pm
Here is an app that I use quite frequently: Wood Workshop (Freeware) by Spiral Graphics http://www.spiralgraphics.biz/ww_overview.htmIt's not only great for creating wood textures it is also great for creating stone patterns as well. It has lot of flexibility and is quite powerful for freeware.
RichardCherry
- Name: RichardCherry
by tridem » Wed Nov 23, 2011 9:18 am
 that's great! I believe to have already saw and then forgot it, in the past. thanks
tridem
- Name: Luca
by mitcorb » Thu Nov 24, 2011 2:59 pm
I just visited the Spiralgraphics link that Richard Cherry suggested above and noted that there was a link to another app called Genetica with a Free, Pro, and Studio version. Genetica is similar, but with extended capabilities for those not familiar. I suggest checking it out. I would guess free capability with resolution up to 3000 x3000 would be ok with folks?
mitcorb
- Top SketchUcator
- Name: mitcorb
- SketchUp version: 2016
- License type: Pro
by JMdesigns » Mon Nov 28, 2011 1:51 pm
Great info
JMdesigns
- Name: JD
by utiler » Sun Dec 04, 2011 2:17 am
utiler
- Top SketchUcator
- Name: Andrew
- License type: Pro
by Ad Machine » 5 minutes ago
Ad Machine
- Robot
Return to Extensions & Applications Discussions
