[Plugin]T2H_BuildingStructureTools2.2.4 in20141207
@gistman said:
Seems like a fantastic tool, although I can't get it to work- "Can`t click "Next point". Any tool."
Same for me.
I have now loaded the tool and get the same problems...
Here are two 'tweaked' files that work.
Replace one in Plugins and the other in the tool's own subfolder.
I have swapped the \ to / in the 'require' statements.
I have trapped a 'read_default' error. The author having used/tested the tool for some time won't have realized that his code crashed if a particular registry entry was missing [probably as he had written that entry ages ago in earlier tested code], but because it crashes at the start the entry never gets written ! In 'tst_main', at line #123, I've added a trap so there is no crash and it now works, writing the needed registry entry the first time you use the tool, and so all is now well...building_structure_tool.rbtst_main.rb -
thanks to both tak2hata & Tig
I can finally test it, and it seems a plugin with great potential
Google SketchUp Pro 7 (7.0.10248)
Mac OSX 10.4.11, old PPC G4 -
Thanks TIG!
Thank you for helping.
It was not hit on at all where I am necessary to put up the hand.
It was doubted that it was a problem of the inch in my conception.
Now It work with your help!EDIT: by TIG - An updated version of all of the files is now available here...
http://forums.sketchucation.com/viewtopic.php?p=315482#p315482Hi,howardhong!
I'm grad to see you.
Help from Korea and other countries will surely recovers Japan.
Therefore, we also work hard.Thanks for all!
best regard. -
Is there anyway to add beam sizes to this?
just a word: thankyou !
well done guys, a nifty tool is born... maybe you should get together with Goh who does the 1001bit tools ? Between you you may just turn SU into the only fun BIM program out there
all the best...
In the folder 'building_structure_tool' there are two CSV files:
default_pflist.csv
contains the steel sizes and standard sizes of other things used in the tool
You can edit those in plain text editor - e.g. around line #151
##STEEL_BEAM,āSĀÅĀĀ¬āĆ,,,,,,
b15,H-150x75x5x7,,,,matSTEEL,BLACK,BLACK
b19,H-198x99x4.5x7,,,,matSTEEL,BLACK,BLACKThis 'b15' is one country's standard 'code', and the 4 relevant sizes in 'mm', 'material' etc... but you can add your own - just ensure that the ',' count is the same...
You could also add other things like additional items at the end...
Also
default_pipelist.csv
contains 'tube' code/sizes. -
Does anyone have a "Rosetta Stone" to convert these codes into USA codes?
Don't forget this:
http://www.cad-addict.com/2009/07/sketchup-plugins-engineering-toolbox.html
and this:
http://sketchup.engineeringtoolbox.com/flange-beams-columns-to_10.html
There is also beamtool.rb and Steels.rb which can be found here http://rld.crai.archi.fr/rld/plugins_list_az.php
Regards,
Bob -
try this http://www.structural-drafting-net-expert.com/steel-beam.html ?
My old SteelSections includes most UK/EU sizes... in the txt file... -
Dear TIG,
Where would one find 'ye olde SteelSection.rb'?
Regards,
Bob -
@watkins said:
...Where would one find 'ye olde SteelSection.rb'?...
Try here http://rhin.crai.archi.fr/rld/plugin_details.php?id=412 [all all good scripts go in the twilight of their years.........] -
Ah, didn't realise that Steels was the same as SteelSection.
Thanks, Bob
It would appear that this plugin causes the old grayed out menu items. I haven't seen that for awhile but it happened after I installed this one. I've deleted it and I have no problem.
Thanks about the info of world steel beam tables.
I will read it later.
Earthquake hit me now!
Very Terrible. -
@dave r said:
It would appear that this plugin causes the old grayed out menu items. I haven't seen that for a while but it happened after I installed this one. I've deleted it and I have no problem.
This new tool does add 14 additional commands, which might just tip you over the mythical limit and then causes gray-outs...
It needs those for the Toolbar, but since it doesn't use context-menus it's weird as that is the usual connection...
You don't need to uninstall the tool completely, you can simply rename 'building_structure_tool.rb' as 'building_structure_tool.rb.txt' so it isn't auto-loaded at startup; then later if you want the tool's functions you can typeload "building_structure_tool.rb.txt"
in the Ruby Console and it's loaded for the rest of that session...
Do you have 'ContextMenuOptimizer' by AlexM, which tries to optimize 'commands' to reduce 'gray-outs'? -
Hi TIG,
I know I could have renamed it but I still have the ZIP file. I don't have AlexM's ContextMenuOptimizer but I'll look for it. The greyed out menu thing was a big issue before with TOS or something else but the plugin was updated and the problem seemed to have gone away. I don't remember what the changes was to the specific plugin, though.
@dave r said:
Hi TIG,
I know I could have renamed it but I still have the ZIP file. I don't have AlexM's ContextMenuOptimizer but I'll look for it. The grayed out menu thing was a big issue before with TOS or something else but the plugin was updated and the problem seemed to have gone away. I don't remember what the changes was to the specific plugin, though.The 'ContextMenuOptimizer' is available here http://forums.sketchucation.com/viewtopic.php?p=252413#p252413
There is a 'theoretical' limit of ~1000 commands being active before the context-menu 'breaks'.
The optimizer tries to 'flush' unused commands so this is avoided...
Unfortunately you have to have a 'command' made if you are to use a toolbar, so the more tools that you have that use toolbars the nearer you will get to the limit and then get possible gray-outs.
The earlier problem with some of Fredo's tools [and a few others] was that they remade a new command every time you used the context-menu, and thereby it quickly used up the available command slots as the old command was still remembered too... and the dreaded gray-outs ensued...
These issues were addressed in the tools' code, and one command is now initially defined and reused as needed, so as long as you've updated all of Fredo's tools etc then that particular problem has gone.
However, I still get occasional gray-outs on context-menus when I have a lot of tools loading commands during tests etc, so it is possible to exceed this limit even with the optimizer running and when all tools themselves have been optimized...
Remember that most context-menu items will remain available on the end of the Edit Menu, so you can usually do the required actions that way if the gray-out happens - but if all else fails you must save and restart -
Thanks TIG. Installing it now.
