[Plugin Library] LibFredo6 - v11.4d - 27 Nov 20
Re: [Plugin Library] LibFredo6 - v3.6b - 13 Jan 11
Postby tonyliu52 » Wed Jan 19, 2011 1:32 am
Thank you!I have downloaded the plugins.
tonyliu52
Postby arjunmax09 » Mon Jan 31, 2011 5:43 pm
I've copied paste libfredo6 in my plugins folder...Can the following folders be safely deleted....??
LIBFREDO6_Dir_34
LIBFREDO6_Dir_35
when you fail at something....you haven't really failed...you've found one way the thing will not work out
arjunmax09
Banned
Postby fredo6 » Tue Feb 01, 2011 12:26 pm
arjunmax09 wrote:I've copied paste libfredo6 in my plugins folder...Can the following folders be safely deleted....??
LIBFREDO6_Dir_34
LIBFREDO6_Dir_35
YES.
Same for the plugin folders where you can remove the older folders.
User avatar
PluginStore Author
PluginStore Author
Postby John P » Tue Feb 01, 2011 8:40 pm
I must be doing something wrong here. I downloaded version 3.6 and unzipped as instructed, and sure enough, I've got the folder LIBFREDO6_Dir_36 and the file LibFredo6.rb in my \Plugins directory. But when I run Sketchup, nothing new shows up in the Window menu. Any ideas?
John P
Postby TIG » Tue Feb 01, 2011 9:00 pm
John P wrote:I must be doing something wrong here. I downloaded version 3.6 and unzipped as instructed, and sure enough, I've got the folder LIBFREDO6_Dir_36 and the file LibFredo6.rb in my \Plugins directory. But when I run Sketchup, nothing new shows up in the Window menu. Any ideas?
The Lib is support for other tools by Fredo!
Many of these are Extensions and need activating from menu Window > Preferences > Extensions......
User avatar
Global Moderator
Postby hero719 » Thu Feb 03, 2011 12:02 pm
i'm beginer. thk you! :thumb: :thumb: :enlight:
hero719
Postby k2wengen » Mon Feb 07, 2011 12:32 pm
thank you!!! ^^
have a nice day :roflmao:
k2wengen
Postby Hexmeister » Wed Feb 09, 2011 7:21 am
Fantastic
Hexmeister
Postby ohsleeper » Fri Feb 11, 2011 2:13 pm
when i try to unzip this i just get 100 error messages...what am i doing wrong?
ohsleeper
Postby fredo6 » Sat Feb 12, 2011 9:59 am
ohsleeper wrote:when i try to unzip this i just get 100 error messages...what am i doing wrong?
Could you indicate which kind of error you get.
thanks
User avatar
PluginStore Author
PluginStore Author
Postby ohsleeper » Sun Feb 13, 2011 6:47 pm
ohsleeper
Postby fredo6 » Sun Feb 13, 2011 11:38 pm
ohsleeper wrote:
You just have problem of Security with Write access to the SU Plugins folder. This should be true for all plugins.
You will have to sort it out first to have proper access.
User avatar
PluginStore Author
PluginStore Author
Postby Headroom » Wed Feb 16, 2011 3:18 am
I've reported this quite a while ago (months) and the issue still exists. O my first iMac(Core2Duo 2.4 GHz) this plugin performed so sluggish that it was unusable. The menu items and 3D space updates when selecting edges took several seconds to update and that lag between user action and reaction of the tool rendered it not usable.
Now I have a 27" iMac 2.93 GHz Intel Core i7 with 12GB Ram (even though I doubt the latter makes any difference in this case). And while naturally this machine is much faster there still is a very definite lag between user input and reaction of the tool. Usable but really only barely. Noting for continued use.
I also have a Windows XP running in VMware fusion on the same machine and have don't have these problems there. Even though it's running in a VM reaction to user input is instantaneous. No perceivable lag whatsoever!
I've worked some with the Skindigo exporter plugin in OSX and that works smooth as butter. Quite strange!
Headroom
Postby aungaung » Sat Feb 19, 2011 6:29 pm
thxxxxxxxx
aungaung
Postby cfarrell10 » Tue Feb 22, 2011 12:00 pm
Hi, I'm new to Sketchup.
I've downloaded, unzipped and put in the Plugins folder. Unfortunately, i must have done something wrong and nothing has appeared other than what i already had on there.
I run windows 7 and have been using Sketchup 8. Any help greatly appreciated!
Thanks.
cfarrell10
Postby cfarrell10 » Tue Feb 22, 2011 12:36 pm
cfarrell10 wrote:Hi, I'm new to Sketchup.
Thanks.
Hi, apologies, I realised that I'd only downloaded the Library files, and not the rounded corner tool also.
Works great now, many thanks!
cfarrell10
Postby fredo6 » Tue Feb 22, 2011 5:40 pm
Thanks.
LibFredo6 is just a shared library. It does nothing useful at user level by itself.
You have to install one of my plugin (FredoScale, Roundcorner, Curviloft, ...) to see something in your SU environment.
User avatar
PluginStore Author
PluginStore Author
Postby arthur87 » Tue Apr 12, 2011 9:05 pm
can i safely remove older libfredo6 folders??
arthur87
Postby fredo6 » Tue Apr 12, 2011 9:27 pm
arthur87 wrote:can i safely remove older libfredo6 folders??
Yes you can
This applies to all my plugins
User avatar
PluginStore Author
PluginStore Author
Re: [Plugin Library] LibFredo6 - v3.7a - 17 Apr 11
Postby rjjvirusx » Sun Apr 17, 2011 9:05 pm
:berserk: :fecstatic: :fecstatic: :fecstatic: :fecstatic: :fecstatic: :fecstatic: :fecstatic: :fecstatic:
rjjvirusx
Postby fredo6 » Sun Apr 17, 2011 9:14 pm
NEW RELEASE LibFredo6 3.7a - 17 Apr 2011
This new version is required for SUClock.
It also fixes some bugs in the Web Dialogs (to Mac users: I hope this works OK)
Finally, it introduces a live Check Plugins for Update feature.
New release is available for download in the first post of this thread.
User avatar
PluginStore Author
PluginStore Author
Postby Jim » Fri Apr 22, 2011 2:36 pm
Hi Fredo,
I am getting duplicate "LibFredo6 Settings..." entries in the Window menu. I locate my plugin files in C:/Plugins and load them using require_all("C:/Plugins")
Also, I have several of your plugins installed - Round Corner, Curviloft, Bezier, in C:/Plugins. These plugins do not appear in the update list. The plugins are currently not enabled in the Extensions dialog - do they need to be enabled to be visible for updates?
Thanks.
Jim
Global Moderator
Postby fredo6 » Fri Apr 22, 2011 4:11 pm
Jim wrote:I am getting duplicate "LibFredo6 Settings..." entries in the Window menu. I locate my plugin files in C:/Plugins and load them using require_all("C:/Plugins")
This is due to the fact that require_all registers the full path of ruby files (you can check it in $"). So, LibFredo6 gets loaded twice, once as C:/plugins/LibFredo6.rb and once as LibFredo6.rb.
Do you get this behavior only with LibFredo6 3.7, or did you have it before?
Anyway, I will publish a small update to LibFredo6 to avoid the double menu in all situations
By the way, I published a small plugin to manage alternate directory for plugins. Precisely, I don't use require_all but a loop on require instead in order to avoid the issue of full path.
Jim wrote:Also, I have several of your plugins installed - Round Corner, Curviloft, Bezier, in C:/Plugins. These plugins do not appear in the update list. The plugins are currently not enabled in the Extensions dialog - do they need to be enabled to be visible for updates?
The answer is YES. The local registration is done by the plugins themselves. So if they are not activated as Extensions, no code is run.
Hope this helps
User avatar
PluginStore Author
PluginStore Author
Re: [Plugin Library] LibFredo6 - v3.7b - 22 Apr 11
Postby Jim » Sat Apr 23, 2011 4:21 pm
Fredo6 wrote:The answer is YES. The local registration is done by the plugins themselves. So if they are not activated as Extensions, no code is run.
I would argue that not enabled is different than not installed. Installed-but-not-enabled plugins should also be detected for upgrade purposes. Just my opinion. ;) Thanks for the update - the ability to check for updates is a great step forward.
Jim
Global Moderator
Postby Gus R » Sun Apr 24, 2011 6:39 pm
Fredo,
Is there any way to keep "Check Plugins for Update" from opening at startup of SU?
Update:
Never mind. I figured it out. :oops:
User avatar
Gus R
Postby Oxer » Sun Apr 24, 2011 7:24 pm
Thanks Fredo6 for update!!
I have translated the last strings of this update to spanish language, this is the spanish language file for LibFredo6 - v3.7b
LibFredo6_ES.lang.zip
User avatar
Oxer
[Plugin] ๏̯͡๏ + Fredo6Collection (Es-Translations)
Postby Defisto » Tue Apr 26, 2011 9:36 am
» [ Post in Spanish ]
En este Post., Se Publicaran Las [ Traducciones al Español ] + Actualizaciones (Para los Plugins de la Fredo6Collection):
Estas Traducciones han Sido Revisadas Línea por Línea., y se han Actualizado durante Meses., para que sean lo Mas Perfectas Posibles., Además., estas Traducciones son Armoniosas entre si, y las Frases son mas Fáciles de Entender y mas Simples (En base a Muchos Días de Investigación y Experimentación)., es decir., Usan el Mismo estilo., para que los “Fredo6 Collection Plugins” sean Mas Fáciles de Entender y mas Amigables entre Si... ႿÐ!
๏̯͡๏ [ … ] Nota: Yo También Ajunto un Plugin., que enlaza este Post desde “SketchUp”: Para Buscar Actualizaciones de las Traducciones (Rápidamente)... ႿÐ!
Defisto [Dice]:
Con este Plugin se Mostrara la Siguiente Opción: Menú Ventana -> + Fredo6Collection (Es-Translations) -> Descargar Traducciones [ Español ]
Por cierto: Si deseas Debatir el Tema de las Traducciones Visita el Siguiente Enlace a un Tema en el Foro en Español:
viewtopic.php?f=52&t=36889
PS: Ogvua... ႿÐ!
» [ Post in English ]
In this Post is Published the [ Spanish Translation ] + Its [ Updates ] (for the Fredo6 Collection Plugins)
These translations have been checked line by line., and have been updated by months., to be as perfect as possible., also., these translations are harmonious with each other, and phrases are easier to understand and more simple (in Based on many days of Investigation and experimentation)., ie., wear the same style., for that the “Fredo6 Collection Plugins” are more easier to understand and more Match with each other... ႿÐ!
๏̯͡๏ [ … ] Note: I also Adjunct a plugin that links this Post from “SketchUp”: To Check for Updates of Translations (Quickly)... ႿÐ!
Defisto [Says]:
With this Plugin is will Display the Next Option: Window Menu -> + Fredo6Collection (Es-Translations) -> Download Translations [ Spanish ]
By the way: If you want to discuss the topic of translations visit the following link to a topic at the Forum in Spanish:
PS: Ogvua... ႿÐ!
笑い男: I thought what I'd do was, I'd pretend I was one of those deaf-mutes... ႿÐ!
http://www.goear.com/listen/85c21f9/lit ... tt-matthew
笑い男: Pensé que lo que haría sería fingir ser uno de esos sordomudos... ႿÐ!
Defisto
Postby Oxer » Tue Apr 26, 2011 12:57 pm
Hola Defisto,
No sabía que tenias abierto un post con las traducciones a español de FredoCollection, gracias por informar, en cuanto a los archivos de traducción yo los he traducido a Español de España, los tuyos creo que son español de Sudamérica y algunas palabras no se expresan igual, por otra parte intenta guardar los archivos en codificación Unicode (UTF-8) porque sino aparecerán caracteres extraños.
De nuevo gracias por la información.
Hi Defisto,
I did not know that you had open a post with the translations to spanish FredoCollection, thank you for informing, in regard to the translation files i have translated into Spanish of Spain, yours i think they are in spanish of South America and some words are not expressed equal, on the other hand tries to save the files in Unicode encoding (UTF-8) because but will appears strange characters.
Thank you again for the information.
User avatar
Oxer
Postby fredo6 » Tue Apr 26, 2011 6:07 pm
@Oxer and Defisto,
First of all, thanks very much for your great contribution in translating the plugins to Spanish.
I was not aware there would be major difference between Spanish languages on both side of the Atlantic. So could you each tell me what you get when typing Sketchup.get_locale in the Ruby console.
Currently, I use only a two character-code (ES) but I can see if I can make a distinction.
Thanks again
User avatar
PluginStore Author
PluginStore Author
Postby Oxer » Tue Apr 26, 2011 7:51 pm
Hi Fredo,
This is the message when i type Sketchup.get_locale in the Ruby console:
> Sketchup.get_locale
es
User avatar
Oxer
by Ad Machine » 5 minutes ago
Ad Machine
Robot
PreviousNext
Return to Plugins
Who is online
Users browsing this forum: dezmo, tiagodutra and 12 guests
Visit our sponsors:
