[Plugin Library] LibFredo6 - v11.6a - 23 Jan 21Re: [Plugin Library] LibFredo6 - v3.6b - 13 Jan 11I've copied paste libfredo6 in my plugins folder...Can the following folders be safely deleted....??
LIBFREDO6_Dir_34 LIBFREDO6_Dir_35 when you fail at something....you haven't really failed...you've found one way the thing will not work out
YES. Same for the plugin folders where you can remove the older folders. Fredo
Re: [Plugin Library] LibFredo6 - v3.6b - 13 Jan 11I must be doing something wrong here. I downloaded version 3.6 and unzipped as instructed, and sure enough, I've got the folder LIBFREDO6_Dir_36 and the file LibFredo6.rb in my \Plugins directory. But when I run Sketchup, nothing new shows up in the Window menu. Any ideas?
The Lib is support for other tools by Fredo! Many of these are Extensions and need activating from menu Window > Preferences > Extensions...... TIG
Re: [Plugin Library] LibFredo6 - v3.6b - 13 Jan 11when i try to unzip this i just get 100 error messages...what am i doing wrong?
Could you indicate which kind of error you get. thanks Fredo
Re: [Plugin Library] LibFredo6 - v3.6b - 13 Jan 11You just have problem of Security with Write access to the SU Plugins folder. This should be true for all plugins. You will have to sort it out first to have proper access. Fredo
Re: [Plugin Library] LibFredo6 - v3.6b - 13 Jan 11I've reported this quite a while ago (months) and the issue still exists. O my first iMac(Core2Duo 2.4 GHz) this plugin performed so sluggish that it was unusable. The menu items and 3D space updates when selecting edges took several seconds to update and that lag between user action and reaction of the tool rendered it not usable.
Now I have a 27" iMac 2.93 GHz Intel Core i7 with 12GB Ram (even though I doubt the latter makes any difference in this case). And while naturally this machine is much faster there still is a very definite lag between user input and reaction of the tool. Usable but really only barely. Noting for continued use. I also have a Windows XP running in VMware fusion on the same machine and have don't have these problems there. Even though it's running in a VM reaction to user input is instantaneous. No perceivable lag whatsoever! I've worked some with the Skindigo exporter plugin in OSX and that works smooth as butter. Quite strange! Re: [Plugin Library] LibFredo6 - v3.6b - 13 Jan 11Hi, I'm new to Sketchup.
I've downloaded, unzipped and put in the Plugins folder. Unfortunately, i must have done something wrong and nothing has appeared other than what i already had on there. I run windows 7 and have been using Sketchup 8. Any help greatly appreciated! Thanks. Re: [Plugin Library] LibFredo6 - v3.6b - 13 Jan 11
Hi, apologies, I realised that I'd only downloaded the Library files, and not the rounded corner tool also. Works great now, many thanks! Re: [Plugin Library] LibFredo6 - v3.6b - 13 Jan 11
LibFredo6 is just a shared library. It does nothing useful at user level by itself. You have to install one of my plugin (FredoScale, Roundcorner, Curviloft, ...) to see something in your SU environment. Fredo
Yes you can This applies to all my plugins Fredo
Re: [Plugin Library] LibFredo6 - v3.7a - 17 Apr 11NEW RELEASE LibFredo6 3.7a - 17 Apr 2011
This new version is required for SUClock. It also fixes some bugs in the Web Dialogs (to Mac users: I hope this works OK) Finally, it introduces a live Check Plugins for Update feature. New release is available for download in the first post of this thread. Fredo
Re: [Plugin Library] LibFredo6 - v3.7a - 17 Apr 11Hi Fredo,
I am getting duplicate "LibFredo6 Settings..." entries in the Window menu. I locate my plugin files in C:/Plugins and load them using require_all("C:/Plugins") Also, I have several of your plugins installed - Round Corner, Curviloft, Bezier, in C:/Plugins. These plugins do not appear in the update list. The plugins are currently not enabled in the Extensions dialog - do they need to be enabled to be visible for updates? Thanks. Hi
This is due to the fact that require_all registers the full path of ruby files (you can check it in $"). So, LibFredo6 gets loaded twice, once as C:/plugins/LibFredo6.rb and once as LibFredo6.rb. Do you get this behavior only with LibFredo6 3.7, or did you have it before? Anyway, I will publish a small update to LibFredo6 to avoid the double menu in all situations By the way, I published a small plugin to manage alternate directory for plugins. Precisely, I don't use require_all but a loop on require instead in order to avoid the issue of full path.
The answer is YES. The local registration is done by the plugins themselves. So if they are not activated as Extensions, no code is run. Hope this helps Fredo
Re: [Plugin Library] LibFredo6 - v3.7b - 22 Apr 11
I would argue that not enabled is different than not installed. Installed-but-not-enabled plugins should also be detected for upgrade purposes. Just my opinion. ![]() Hi
Re: [Plugin Library] LibFredo6 - v3.7b - 22 Apr 11Fredo,
Is there any way to keep "Check Plugins for Update" from opening at startup of SU? Update: Never mind. I figured it out. ![]() Re: [Plugin Library] LibFredo6 - v3.7b - 22 Apr 11Thanks Fredo6 for update!!
I have translated the last strings of this update to spanish language, this is the spanish language file for LibFredo6 - v3.7b [Plugin] ๏̯͡๏ + Fredo6Collection (Es-Translations)#---------------------------------------------------------------------------------
» [ Post in Spanish ] #--------------------------------------------------------------------------------- En este Post., Se Publicaran Las [ Traducciones al Español ] + Actualizaciones (Para los Plugins de la Fredo6Collection): Estas Traducciones han Sido Revisadas Línea por Línea., y se han Actualizado durante Meses., para que sean lo Mas Perfectas Posibles., Además., estas Traducciones son Armoniosas entre si, y las Frases son mas Fáciles de Entender y mas Simples (En base a Muchos Días de Investigación y Experimentación)., es decir., Usan el Mismo estilo., para que los “Fredo6 Collection Plugins” sean Mas Fáciles de Entender y mas Amigables entre Si... ႿÐ! ---------------------------------------------------------------------------------- ๏̯͡๏ [ … ] Nota: Yo También Ajunto un Plugin., que enlaza este Post desde “SketchUp”: Para Buscar Actualizaciones de las Traducciones (Rápidamente)... ႿÐ! Defisto [Dice]: Con este Plugin se Mostrara la Siguiente Opción: Menú Ventana -> + Fredo6Collection (Es-Translations) -> Descargar Traducciones [ Español ] ---------------------------------------------------------------------------------- Por cierto: Si deseas Debatir el Tema de las Traducciones Visita el Siguiente Enlace a un Tema en el Foro en Español: viewtopic.php?f=52&t=36889 ---------------------------------------------------------------------------------- PS: Ogvua... ႿÐ! #--------------------------------------------------------------------------------- » [ Post in English ] #--------------------------------------------------------------------------------- In this Post is Published the [ Spanish Translation ] + Its [ Updates ] (for the Fredo6 Collection Plugins) These translations have been checked line by line., and have been updated by months., to be as perfect as possible., also., these translations are harmonious with each other, and phrases are easier to understand and more simple (in Based on many days of Investigation and experimentation)., ie., wear the same style., for that the “Fredo6 Collection Plugins” are more easier to understand and more Match with each other... ႿÐ! ---------------------------------------------------------------------------------- ๏̯͡๏ [ … ] Note: I also Adjunct a plugin that links this Post from “SketchUp”: To Check for Updates of Translations (Quickly)... ႿÐ! Defisto [Says]: With this Plugin is will Display the Next Option: Window Menu -> + Fredo6Collection (Es-Translations) -> Download Translations [ Spanish ] ---------------------------------------------------------------------------------- By the way: If you want to discuss the topic of translations visit the following link to a topic at the Forum in Spanish: viewtopic.php?f=52&t=36889 ---------------------------------------------------------------------------------- PS: Ogvua... ႿÐ! Last edited by Defisto on Mon Jul 16, 2012 2:09 am, edited 33 times in total.
笑い男: I thought what I'd do was, I'd pretend I was one of those deaf-mutes... ႿÐ!
http://www.goear.com/listen/85c21f9/lit ... tt-matthew 笑い男: Pensé que lo que haría sería fingir ser uno de esos sordomudos... ႿÐ! Re: [Plugin Library] LibFredo6 - v3.7b - 22 Apr 11Hola Defisto,
No sabía que tenias abierto un post con las traducciones a español de FredoCollection, gracias por informar, en cuanto a los archivos de traducción yo los he traducido a Español de España, los tuyos creo que son español de Sudamérica y algunas palabras no se expresan igual, por otra parte intenta guardar los archivos en codificación Unicode (UTF-8) porque sino aparecerán caracteres extraños. De nuevo gracias por la información. Hi Defisto, I did not know that you had open a post with the translations to spanish FredoCollection, thank you for informing, in regard to the translation files i have translated into Spanish of Spain, yours i think they are in spanish of South America and some words are not expressed equal, on the other hand tries to save the files in Unicode encoding (UTF-8) because but will appears strange characters. Thank you again for the information. Re: [Plugin Library] LibFredo6 - v3.7b - 22 Apr 11@Oxer and Defisto,
First of all, thanks very much for your great contribution in translating the plugins to Spanish. I was not aware there would be major difference between Spanish languages on both side of the Atlantic. So could you each tell me what you get when typing Sketchup.get_locale in the Ruby console. Currently, I use only a two character-code (ES) but I can see if I can make a distinction. Thanks again Fredo
Re: [Plugin Library] LibFredo6 - v3.7b - 22 Apr 11Hi Fredo,
This is the message when i type Sketchup.get_locale in the Ruby console: > Sketchup.get_locale es |
Who is online
Users browsing this forum: palomeito and 12 guests
