[Code] Rantexpos
[Code] Rantexpos
Postby g.moggel » Wed Feb 09, 2011 9:09 pm
hey guys. first up, i dont take credit for that plugin. its by axel lee. i found this plugin rantexpos at http://rhin.crai.archi.fr/rld/plugin_details.php?id=324
it doesnt seem to work in su 8. can one of you look into it and maybe correct it? i'm not into coding but really need this to work.
its supposed to randomize the texture position of the selected group/faces.
code is as follows.
Code: Select all
def rantexpos
   Sketchup.active_model.start_operation("RANTEXPOS!")
   selected = Sketchup.active_model.selection
   for ent in selected
      if( ent.is_a? Sketchup::Face )
         tex = ent.material
         texpoint = []
         texpoint.push [rand(2048), rand(2048), rand(2048)]
         texpoints = [texpoint[0],texpoint[1]]
         ent.position_material (tex, texpoints, true)
         ent.position_material (tex, texpoints, false)
      if( ent.is_a? Sketchup::Group )
         for fac in ent.entities
            if( fac.is_a? Sketchup::Face )
               tex = ent.material
               texpoint = []
               fac.position_material (tex, texpoints, true)
               fac.position_material (tex, texpoints, false)
   Sketchup.active_model.commit_operation
filename="rantexpos.rb"
if !file_loaded?(filename)
   plugins_menu = UI.menu("Plugins")
   if plugins_menu
      plugins_menu.add_separator
      plugins_menu.add_item("Randomize texture positions") {rantexpos}
   file_loaded(filename)
thanks in advance.
Reason: Added [Code] tag for indexing
g.moggel
Re: Rantexpos
Postby Dan Rathbun » Thu Feb 10, 2011 8:37 am
g.moggel wrote:it doesnt seem to work in su 8.
Parenthesized argument lists for methods. (And remove a few spaces when they were in between method names and arg lists. This causes an error in Ruby 1.8.6)
Wrapped in a module.
Added Constants at top for setting menus.
Code: Select all
#  rantexpos.rb
module AxelLee
# CONSTANTS
  TOPMENU = 'Plugins' unless defined?(TOPMENU)
  # SUBMENU is blank to put on Plugins menu
  # Enter a string in the quotes to create a submenu:
  SUBMENU = "" unless defined?(SUBMENU)
  Filename = File.basename(__FILE__).downcase
module_function
def rantexpos
    Sketchup
    for ent in selected
        if ent
.is_a?(Sketchup::Face)
            tex = ent.material
            texpoint
            texpoint.push([rand(2048), rand(2048), rand(2048)])
            ent.position_material(tex, texpoints, true)
            ent.position_material(tex, texpoints, false)
        if ent
.is_a?(Sketchup::Group)
                if fac
                    tex = ent.material
                    texpoint
                    fac.position_material(tex, texpoints, true)
                    fac.position_material(tex, texpoints, false)
    Sketchup
if
!file_loaded?(Filename)
  @@topmenu=UI.menu(TOPMENU)
  unless SUBMENU.empty?
    @@menu=@@topmenu.add_submenu(SUBMENU)
  else
@@menu=@@topmenu
@@menu.add_item("Randomize texture positions") {rantexpos}
  file_loaded(Filename)
# module
    I'm not here much anymore. But a PM will fire email notifications.
    User avatar
    Dan Rathbun
    PluginStore Author
    PluginStore Author
    Re: Rantexpos
    Postby g.moggel » Thu Feb 10, 2011 10:05 am
    thanks dan for looking into it. when starting sketchup i get an error now:
    "Error Loading File rantexpos.rb
    undefined local variable or method `filename' for AxelLee:Module"
    and still when i start the plugin from the plugins menu su crashes.
    greets,
    mo
    g.moggel
    Re: Rantexpos
    Postby Didier Bur » Thu Feb 10, 2011 12:50 pm
    Typo: replace: file_loaded(filename) with: file_loaded(Filename)
    Didier Bur
    User avatar
    Didier Bur
    Re: Rantexpos
    Postby Dan Rathbun » Thu Feb 10, 2011 4:59 pm
    Didier Bur wrote:Typo: replace: file_loaded(filename) with: file_loaded(Filename)
    Done. Edited the code.
    I did that in a secs just before bed. I have not tested it. (I assume it worked under Ruby 1.8.0, and didn't under 1.8.6 because of spaces between method names and argumentlists, etc.)
      User avatar
      Dan Rathbun
      PluginStore Author
      PluginStore Author
      Re: Rantexpos
      Postby Dan Rathbun » Thu Feb 10, 2011 6:47 pm
      g.moggel wrote:and still when i start the plugin from the plugins menu su crashes.
      I was able to get it to work on a simple model (attached.)
      SaucePan.skp
      I was also able to get a BugSplat! on a very complex old ver 7.1 model. I selected the terrian mesh, and tried it on that. (splatto!)
        User avatar
        Dan Rathbun
        PluginStore Author
        PluginStore Author
        Re: [Code] Rantexpos
        Postby g.moggel » Sun Feb 13, 2011 9:58 am
        hey man this is awesome. i needed to make a cutting board like ikeas whole-wood boards and they consist of individual parts glued together... anyway: NICE ONE!
        although i have another thing. the textures original rotation is changed and completely oriented in the other way. is it possible to not let the rotation change or choose whether it randomizes rotation at a given angle?
        thanks again, this was a big help ;)
        greets,
        mo
        g.moggel
        Postby Dan Rathbun » Sun Feb 13, 2011 11:18 pm
        I don't have time myself to work on this.
        Um.. if you have control.. then it would no longer be random ? :lol:
        but I did notice that when I ran it on a pavement texture on a bridge model, that the roadway became misalign with the bridge. (Looked terrible.)
          User avatar
          Dan Rathbun
          PluginStore Author
          PluginStore Author
          Postby g.moggel » Mon Feb 14, 2011 12:37 am
          figured it out. i just need to rotate my face/object to be oriented with the axis. then i can hit rantexpos and it aligns them in the other way. thanks again for your help.
          mo
          g.moggel
          by Ad Machine » 5 minutes ago
          Ad Machine
          Robot
          Return to Developers' Forum
          cron
          Who is online
          Users browsing this forum: No registered users and 3 guests
