[Plugin] Material Tools
Re: [Plugin] Remove Materials (1.3.0) — 8 July 2009
Postby TIG » Thu Aug 19, 2010 2:45 pm
Gaieus wrote:Hi Thom,
sorry for bumping the topic... Could you add "Remove materials applied to back faces"? (Or is there a plugin that does that already?)
viewtopic.php?p=264134#p264134 = My recent tools include three options:
1. If a face has no front-material but does have a back-material it reverses the face and moves the back-material onto the front keeping the UV mapping etc. It works on selected faces, and after a confirmation-dialog faces in groups, components, or just 'all'.
2. If a face has a front-material and also has a back-material it reverses the face and moves the back-material onto the front keeping the UV mapping etc and erases the other material - i.e. the back-material is finally defaulted [it is 'forced' - use with care!]. It works only on selected faces.
3. It removes back-materials from all selected faces, and after a confirmation-dialog faces in groups, components, or just 'all'.
User avatar
Global Moderator
Re: [Plugin] Remove Materials (1.4.0) — 19 August 2010
Postby Gaieus » Thu Aug 19, 2010 3:33 pm
:thumb:
Cool, TIG, thanks! I knew I remembered reading something but you guys spoil us with the abundance of new plugins every day so it's really hard to keep up with the development!
:D
User avatar
Postby Ben Ritter » Thu Aug 19, 2010 3:47 pm
Thomas, thank you.
Ben Ritter
Postby Zacchia » Thu Aug 19, 2010 4:08 pm
thanks for this plugin!!
Zacchia
Re: [Plugin] Material Tools (2.2.0) — 21 October2010
Postby thomthom » Thu Oct 21, 2010 8:24 pm
Some various updates to this plugin - renamed it as well.
User avatar
PluginStore Author
PluginStore Author
Postby caleidos4d » Thu Oct 21, 2010 8:47 pm
Thanks thomthom :berserk: :thumb: :thumb: :thumb:
caleidos4d
Postby CAntonis » Thu Oct 21, 2010 9:17 pm
Thank U.
It 'll come in handy! Thats for sure!
CAntonis
User avatar
CAntonis
Postby dedmin » Fri Oct 22, 2010 9:44 am
Instance Material to Faces paints materials also to the back faces. Apply Color Adjustments bugsplats SketchUP when nothing is selected. The names are somehow misleading because this tools work on a selection - maybe to put them on the right click menu when click on the selection or add "selected" to the name.
WinXp SP3
SketchUP 8
dedmin
Postby thomthom » Fri Oct 22, 2010 11:37 am
dedmin wrote:Instance Material to Faces paints materials also to the back faces.
Yes - by design to preserve the same visual appearance.
dedmin wrote: Apply Color Adjustments bugsplats SketchUP when nothing is selected.
:shock: It doesn't use the selection at all - it processes all colour adjusted textures in the model. Got a sample model where this occurs? I've not seen any bugplats with this. Can't reproduce it either.
dedmin wrote:The names are somehow misleading because this tools work on a selection - maybe to put them on the right click menu when click on the selection or add "selected" to the name.
Not all work on the selection.
User avatar
PluginStore Author
PluginStore Author
Postby dedmin » Fri Oct 22, 2010 11:46 am
Itis a clean file - nothing there
dedmin
Postby thomthom » Fri Oct 22, 2010 11:49 am
I tried with a completely empty file - no splat.
Admin or user account?
User avatar
PluginStore Author
PluginStore Author
Postby dedmin » Fri Oct 22, 2010 11:52 am
Video_2010-10-22_135039.wmv
Admin
dedmin
Postby thomthom » Fri Oct 22, 2010 11:59 am
And you said it does this if the selection was empty?
It doesn't always do this?
User avatar
PluginStore Author
PluginStore Author
Postby dedmin » Fri Oct 22, 2010 12:07 pm
Video_2010-10-22_140535.wmv
dedmin
Postby thomthom » Fri Oct 22, 2010 12:12 pm
So it crashes all the time? No exceptions?
User avatar
PluginStore Author
PluginStore Author
Postby dedmin » Fri Oct 22, 2010 12:19 pm
As far as I tried - yes.
dedmin
Postby thomthom » Fri Oct 22, 2010 12:19 pm
Ok - I'll see if I can make a debug version to detect where it splats.
User avatar
PluginStore Author
PluginStore Author
Postby ray678 » Thu Dec 02, 2010 7:03 pm
thanks for sharing
ray678
Postby spence » Fri Dec 03, 2010 6:30 pm
This is a great plugin Thomas, thanks :D
Spence
User avatar
spence
Premium Member
Premium Member
Postby nektares » Sat Dec 04, 2010 8:09 pm
Thanks ThomThom! your plug-ins are really cool!
nektares
Postby bentleykfrog » Fri Jan 07, 2011 4:30 am
Great plugin thomthom, nice work, only wish remove by selection would remove the materials applied to faces and groups/components inside selected groups/components, and components in selection are made unique.
bentleykfrog
Postby Rich O Brien » Thu Jun 02, 2011 8:55 pm
I'm not getting 'Remove Material from selection' to work?
There's a frontroom and a backroom....reverse faces
User avatar
Rich O Brien
Administrator
Postby thomthom » Thu Jun 02, 2011 8:57 pm
Rich O'Brien wrote:I'm not getting 'Remove Material from selection' to work?
Errors in the console?
User avatar
PluginStore Author
PluginStore Author
Postby Rich O Brien » Thu Jun 02, 2011 8:58 pm
My bad...
Code: Select all
Error: #<NameError: undefined local variable or method `ents' for TT::Plugins::MaterialTools:Module>
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/tt_material_tools.rb:270:in `remove_all_from_selection'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/tt_material_tools.rb:256:in `each'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/tt_material_tools.rb:256:in `remove_all_from_selection'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/tt_material_tools.rb:62
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/recurve.rb:17:in `call'
User avatar
Rich O Brien
Administrator
Postby Rich O Brien » Thu Jun 02, 2011 8:59 pm
Actually I just noticed that right clicking produces this error
Code: Select all
Error: #<LocalJumpError: unexpected return>
(eval):106:in `load'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/tt_material_tools.rb:270:in `call'
User avatar
Rich O Brien
Administrator
Postby Rich O Brien » Thu Jun 02, 2011 9:00 pm
Sorry this error
Code: Select all
(eval):106:in `call'
(eval):106
User avatar
Rich O Brien
Administrator
Postby Rich O Brien » Thu Jun 02, 2011 9:02 pm
I think the problem is with Recurve? i'm getting all sorts of errors when I right click
User avatar
Rich O Brien
Administrator
Postby Rich O Brien » Tue Jun 28, 2011 12:32 pm
Problem isn't Recurve as I've removed it....
Code: Select all
User avatar
Rich O Brien
Administrator
Postby thomthom » Tue Jun 28, 2011 12:57 pm
Stop breaking things!
User avatar
PluginStore Author
PluginStore Author
Postby Rich O Brien » Tue Jun 28, 2011 12:58 pm
They call me Mr.Glass
User avatar
Rich O Brien
Administrator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
PreviousNext
Return to Plugins
Who is online
Users browsing this forum: 2gbadoodles, arturoaquino, Maithyae97, steve ashurst and 14 guests
Visit our sponsors:
