Double Line 2 (dline.rb update)
I made some (hopefully) improvements to Didier's dline.rb double-line & wall tool. Mostly the changes are to improve user interaction with the tool.
- Tab key brings up the options dialog, otherwise the previous values are in effect.
- Values are saved between uses, and between sessions.
- Options dialog and Measurements display/accept Model Units.
- Can enter the Width in the Measurements (VCB) upon activation.
- Right-Click empty space to finish the line. (Same as Enter key.)
- Fixed line color wrt inferences, and fixed inference locking.
- Add a ConstructionPoint to start of line for later inferencing (deleted upon completion.)
- Fixed clipping.
- Wrapped code in module namespace.
- Renamed menu to Double Line 2
This file is meant to replace dline.rb file if installed, but can co-exist alongside dline.rb.
Download dline2.rb
Thank you Jim.
Sure; although there seems to be some problems with the creation of the geometry in some cases. I haven't looked at that part.
Jim
I also noticed that you use the
onKeyDown
method to get 'TAB'... this usually fails on a MAC as TAB is screwed on key-down... the recommended way is to usedef onKeyUp(key, repeat, flags, view) if key==9 or key==15 or key==48 ### TAB =9 for PC, MAC 15/48 for some locales ? ###
Note how I also have some other keys mapped as in some locales/MacOSs it seems that '9' isn't Tab
Is there no VK_* constant for tab that would be correct for the platform it runs on?
No. There should be but it's missing...
It's a simple matter to always check for 'key-up' if using 'Tab' though -
Don't work on the V6 (pc)
Drawing lines are good but
Walls are not drawn when Enter pressedError: #<ArgumentError: wrong number of arguments(2 for 1)> C:/Program Files/Google/Google SketchUp 6/Plugins/dline2.rb:157:in `start_operation' C:/Program Files/Google/Google SketchUp 6/Plugins/dline2.rb:157:in `onReturn' C:/Program Files/Google/Google SketchUp 6/Plugins/dline2.rb:157
Walls are not drawn when Enter pressed> Error: #<ArgumentError: wrong number of arguments(2 for 1)> > C:/Program Files/Google/Google SketchUp 6/Plugins/dline2.rb:157:in `start_operation' > C:/Program Files/Google/Google SketchUp 6/Plugins/dline2.rb:157:in `onReturn' > C:/Program Files/Google/Google SketchUp 6/Plugins/dline2.rb:157
This is the same problem I mentioned with
DrawHelix
andmodel.start_operation
taking a second argument after v6.
Unfortunately in this tool it is NOT coded to allow use in v6 at all... BUT here is the fix...
In a copy of the script in the v6 folder find the two lines reading [one might be in French ]
Sketchup.active_model.start_operation("Double Line", true)
and edit the text so there is no 'true' thus
Sketchup.active_model.start_operation("Double Line")
Now it will work in v6 [this will also work in v7/8 but is less efficient in refresh of display terms]
I think a relatively idiot proof way of doing a start_operation that is optimized for all versions isbegin Sketchup.active_model.start_operation("Double Line", true) rescue Sketchup.active_model.start_operation("Double Line") end
That is, it tries to start an operation with a second argument flag set [best for most v7/8 uses] BUT if it fails then it does one without the flag - e.g. v6..........
No one really responded when I asked the question about begin-rescue clause with start_operation. Probably a poor choice for a topic sentence on my part.
http://forums.sketchucation.com/viewtopic.php?f=180&t=22338Great minds think alike... fools never differ...
I agree that this begin-rescue way is less prone to error like your .version v. .version_number typo which screwed Pilou's v6... -
I can't get my Mac to print out the key code for a Tab?
using this: http://rhin.crai.archi.fr/RubyLibraryDepot/plugin_details.php?id=205
For
onKeyDown
it won't as Tab on Mac doesn't fire onKeyDown
But with onKeyUp it should return 9
BUT note that some locales/MacOSs can return 15 or even 48 for Tab...
I use this### Type 'keycode' in the Ruby Console... class TIG_KeyCode def activate @key="" puts "TIG's Non-Shortcut Keycode Reporter.\n" puts "Click in the Main Window outside of the" puts "Ruby Console then Press Non-Shortcut Keys..." end def onKeyDown(key, repeat, flags, view) @key=key.to_s puts "You Pressed Keycode = "+@key end def onKeyUp(key, repeat, flags, view) @key=key.to_s puts "You Released Keycode = "+@key end def deactivate(view) puts "You have pressed a Shortcut Key...\nExiting." return nil end end#class def keycode() Sketchup.active_model.select_tool(TIG_KeyCode.new) puts "" end#if
Well, that's rather a pain, not to mention bug-ish.
Is it reported?
@thomthom said:
Is it reported?
I have seen it discussed in various places - I've added it to the Tool's API notes...
Link?
@jim said:
Link?
http://code.google.com/apis/sketchup/docs/ourdoc/tool.html#commentWidgetTitle
I don't see any note.
Updated to fix Tab issue and correct start_operation for version 6+
@jim said:
Link?
Y'know... I don't recall... BUT I have been avoiding using onKeyDown for TAB-key for MAC compatibility for ages by using onKeyUp key==9 etc... I even teach it to my students
I've search my usual haunts... and not found a link but there must be something somewhere as I can't have dreamed up the problem alone...
It seems to have been raised around here http://forums.sketchucation.com/viewtopic.php?p=273542#p273542 Jeff was also involved and Fredo? ...
