[Plugin] Export 2d with Alpha
Is there some way to separate shadows pass?
No - I have no control of how it's generated. As you see from the sample I posted the shadows even comes from the whole model, not just what is visible.
This can help for a shadow pass: http://rhin.crai.archi.fr/RubyLibraryDepot/download.php?file=displaytemplate.rb
And maybe a modification of my Shadow control script (http://www.pixero.com/downloads_sketchup.html) could be made to set everything not selected to: e.casts_shadows = false
Congratulations - one of the best for su 2d app
Hey, I did not see this, great plugin, thanks Thom!
Edit; to me, it does not export with transparent background... Nor does it export only the active context.
What version of SU did you use?
Got a screencapture? -
Have I put something in the wrong spot or something cause when I go to view/export 2D the settings comes up but then it doesn't give me a file type to save it as?
After the Settings window and you click OK you should get a File Dialog asking you what name to give the file. You must specify the file extension yourself.
I know and it doesn't give me any file type to save it as at all.
You have to type the file type yourself - there is no list of file types because the SketchUp Ruby API doesn't let me provide one.
So if you want to save a jpg file just enter "myfile.jpg" in the file dialog.
Got a screencapture?The most recent one; SU 8.
Here is a screen capture; now with a different codec than the one you could not open the other day if you remember...
Well, sigh... I can always use LO for exporting png's with transparent background...
Maybe it's an XP thing?
I don't know. Haven't got an XP machine at hand right now. Could be an SketchUp bug...
Well, you know where to report it (and who has all sorts of machines). I have no clue about the ins and outs of ruby. I could never make a proper bug report on plugins!
Just to narrow it down to a simple test case - can you try this one-liner?
<span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">write_image</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">filename</span><span class="syntaxkeyword">=></span><span class="syntaxstring">'C;\test.png'</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">width</span><span class="syntaxkeyword">=></span><span class="syntaxdefault">640</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">height</span><span class="syntaxkeyword">=></span><span class="syntaxdefault">480</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">antialias</span><span class="syntaxkeyword">=></span><span class="syntaxdefault">false</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">transparent</span><span class="syntaxkeyword">=></span><span class="syntaxdefault">true </span><span class="syntaxkeyword">}</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span>
Try what? Enter the ruby console? I get this:
If you set the background color to be 0,0,0 [pure-black] then the image will export with a transparent background in place of the 'pure-black', when you open it in Gimp or a web-browser etc you will see there is no background...
Should not need to do this - I export with the default SketchUp Sky - still I get transparency.
