Re: [Plugin] Flatten to Plane v1.2 20101023
• Page 1 of 3 • 1, 2, 3
Re: [Plugin] Flatten to Plane v1.2 20101023(c) TIG 2010
Permission to use, copy, modify, and distribute this software for any purpose and without fee is hereby granted, provided that the above copyright notice appear in all copies. THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE. ___________________________________________________________________________ You need this file #FlattenToPlane.rb >>> Plugins Folder You must also have this file #WorkPlane.rb >>> Plugins Folder http://forums.sketchucation.com/viewtop ... 45#p274345 ___________________________________________________________________________ Usage: Make or choose a 'WorkPlane' that is located on the 'plane' onto which you want to project your 'flattened' Geometry. Select the 'WorkPlane' and the required Geometry [Edges etc, note that Faces etc will be ignored], and/or Groups, and/or Component_Instances. Run this Tool from the menu 'Plugins' > 'Flatten to Plane' or type 'flattentoplane' in the Ruby Console. If there is no 'WorkPlane' and/or other objects in the Selection you get an error message. Assuming it runs... All Edges in the Selection that are not 'hidden' or not on 'off layers' are projected onto that 'plane'. The new 'flattened' Edges are put into a new Group named 'FLAT_123456.789' [it has a 'date/time' suffix]. Each new Edge takes the original Edge's layer. If an Edge is in a Group it is put into a new Group made inside the new 'FLAT_123456.789' Group that is named after the original Group's name + '_FLAT'. This nested Group takes the original Group's layer. If an Edge is in a Component_Instance it is put into a new Group made inside the new 'FLAT_123456.789' Group that is named after the original Component Definition's name + '_FLAT'. This nested Group takes the original Instance's layer. On completion the new Group ['FLAT_123456.789'] is left highlighted. ___________________________________________________________________________ Donations: by PayPal to info @ revitrev.org ___________________________________________________________________________ Version: 1.0 20101022 First release. 1.1 20101022 Nested groups/instances now included. 1.2 20101023 The correct Plane of a 'WorkPlane' is now used even if it has been Transformed inside its own Group. ___________________________________________________________________________ TIG
Re: [Plugin] Flatten to PlaneCool Plugin, will definitely use this, thank you. I've got one request though, is there a way to make an option that the new geometry created becomes a plane with no interior lines. See the image below, the cylinder has a lot of lines but is not a plane. I feel more often than not if you are using this plugin you'll want to extrude the geometry afterwords but for complex shapes you'll end up with a lot of lines to delete. I could be wrong though. Maybe just make it so the new geometry has all the planes drawn in.
Re: [Plugin] Flatten to PlaneTo add faces you can quickly over-drawn th whole thing with a giant circle which will 'face' and intersect with any edges that could 'face': then erase the outer giant circle.
To make a 'silhouette' is much more complex as we'd need to do the above programmatically AND then erase inner island faces and afterwards we need to tidy unfaced edges and any coplanar edges that are not needed... I'll think about it... TIG
Re: [Plugin] Flatten to Plane v1.1Here's v1.1 viewtopic.php?p=281320#p281320
Nested groups/instances now included. TIG
Re: [Plugin] Flatten to Plane v1.1ThomThom's Cleanup script works pretty well to delete all the co-planar lines once the face exist. I tried creating the large circle around the geometry to get the faces but it doesn't always create all the necessary faces, so maybe you could look into just create the faces for the resultant geometry. But that's just a suggestion.
Re: [Plugin] Flatten to Plane v1.1I have no words to thank for your quick response. Your speed to make the solution is amazing.
I just got the script and was playing with it for a while. I created a work plane i selected my group and run it. The result was the model got unfolded on the working plane. Or is it my problem I've attached the model. And One more thing, If i have my section plane on, does it flatten only the visible geometry. Again thank you so much. ![]() Re: [Plugin] Flatten to Plane v1.1Ok, I must be doing something wrong. I am building a model wind turbine and want to cut out blades for the model. The blades wrap around a frame in a helical design. I want to flatten the helical shape so that I can get the 2d curve that best approximates the shape of the blade. So I download both plugins and select a plane and select my model. I run the flatten plugin and I now have a blue box around my model blade, but it is still in 3 dimensions. Any ideas as to what I am doing incorrectly? This looks like a great plugin and is just what I need to get my new business started if I can make it work! Thanks in advance for your help.
Re: [Plugin] Flatten to Plane v1.1Gude
I can see the problem... I can't see see what's causing it [yet] ![]() I think perhaps you need Jim Foltz's 'unfold.rb'.............. TIG
This tool only 'projects' a form onto a plane [when it's working!] - if you want to 'unfold' a form use Jim Foltz's 'unfold.rb'.......... There is is also 'flatten.rb' from Smustard ? TIG
Re: [Plugin] Flatten to Plane v1.1Here's an alternative 'Silhouette to Plane' Tool viewtopic.php?p=281445#p281445
Re: [Plugin] Flatten to Plane v1.1Thanks so much for the info on the unfold tool. This is exactly what I need to convert the 3d curve to a 2d shape that I can have manufactured. I have my first customer for my wind turbine design but the blade design has been a hangup as my manufacturer was unable to determine the curves to cut for the blades. Not knowing CAD, I was at a loss. I can't put into words how great it is to have a solution. Thanks a million!
Keith Tully Power Wall Systems www.powerwallsystems.net Re: [Plugin] Flatten to Plane v1.1first I must thank you for your marvelous plugins. so I try this one and exept for the workplane coplanar to the ground the result is not coplanar with is workplane but seems to be perpendicular. SU 8 on mac 10.6 see attatchment. " c'est curieux chez les marins ce besoin de faire des phrases "
Re: [Plugin] Flatten to Plane v1.1I think the problem lies with the transformations of the WorkPlanes...
If you simply move / rotate the WorkPlane group then the tool will use its 'plane' correctly - as the WorkPlane is effectively 2D and its bounds are not orthogonal to the main axes. You seem to have unlocked and edited the internal contents of the WorkPlane group so that they are then angled within the group and therefore whilst the group is 'orthogonal' to the axes the plane's face is not: because the tool takes the WorkPlanes group's transformation to place the 'flattened' version it appears 'orthogonal' matching the WorkPlane group's alignment and not the internal 'face'... I can probably trap for this too... ![]() TIG
Re: [Plugin] Flatten to Plane v1.2 20101023Here's v1.2 viewtopic.php?p=281320#p281320
The correct Plane of a 'WorkPlane' is now used even if it has been Transformed inside its own Group. TIG
Re: [Plugin] Flatten to Plane v1.2 20101023sorry for the stupid question, but I can't test this at the moment.
does this script take geometry and lay it flat, or does it create a projection onto the work plane? I'm looking for a script that will take a bunch of randomly oriented faces and lay them out nice and flat on the ground plane. For lasercutting, so I don't want them projected/distorted. Thanks, C Re: [Plugin] Flatten to Plane v1.2 20101023
This tool makes a 'projection' of the vertices in a shape to the nearest points on a plane. Therefore if the object is skewed relative to the plane its projection will be distorted compared to its 'parent'. This tool and its sibling 'SilhouetteToPlane' are very similar - this one projects vertices into new lines and keeps grouping etc whilst the other makes a cardboard-cutout silhouette of the 'profile' and faces it. To lay the faces in objects flat onto the ground I suggest you try Jim Foltz's 'unfold.rb' - it's not 'automatic' but it's easy enough to use... Are your faces individually grouped? If so it might be easy enough to script a tool to transform them all 'flat' [normal=[0,0,1]] and all moved to be on the ground - z=0 - you might need to do some tidying if they overlapped etc... but another algorithm to shift them around once they were 'flat' so their bounds didn't intersect would also be feasible... Adding text-tags to the grouped faces and their 'flattened' counterparts would also be helpful to keep track of them? ![]() TIG
Re: [Plugin] Flatten to Plane v1.2 20101023Could someone provide a few worked examples where this tool, and Silouette to plane, prove useful? I am still not clear on function.
Thanks! Bob
Re: [Plugin] Flatten to Plane v1.2 20101023Dear TIG,
Many thanks for the illustration. So, am I right in thinking that this tool could be used to create third angle projects? Presumably, after using the flattening to plane/keep all edges tool, one could then delete unwanted lines and/or change lines to construction lines to show hidden detail? Kind regards, Bob Re: [Plugin] Flatten to Plane v1.2 20101023
That's the idea ![]() TIG
Re: [Plugin] Flatten to Plane v1.2 20101023works great now.
![]() ![]() thanks a lot " c'est curieux chez les marins ce besoin de faire des phrases "
Re: [Plugin] Flatten to Plane v1.2 20101023Dear TIG.
I'm using this script to project elevations from a model. Its working flawless. Now I wanted to project a 2d of the model that is just visible from a plane And this requires me to select faces with visibility criteria from a given view. I am doing this with a the following method but I hope there will be a better of doing it. ** Give a colour to my elevations for different views. For example faces that qualify to project on front be coloured red, side views colored yellow etc. then select by similar material and project selection to the working plane. Faces that are visible on more than one elevation will be given another color and included in selection. ** As faces that are perpendicular to my working plane do not need to project these may be selected and hidden on projection just to refine the criteria. Is there any criteria that evaluates faces in the model according to their visibility from the working plane? Assuming that our model is opaque and rays from my working plane get reflected to the projection plane. I.e for Not projecting rear side view on the front one etc ... Thanks lot again. Re: [Plugin] Flatten to Plane v1.2 20101023It projects all selected faces - so to not include the rear don't select it ?
Re: [Plugin] Flatten to Plane v1.2 20101023got some strange trouble
![]() Re: [Plugin] Flatten to Plane v1.2 20101023Dem
What's the problem ? Are you saying that the new 'flat' lines cross each other and they don't 'break' ? If so, then that is how it should be - the 3D edges are projected flat onto the plane. If you want the new lines to intersect, then select all of the geometry inside its group and 'Intersect with Context', so that they all split themselves where they cross... It's a quick fix if you are looking to erase some bits later... Like this TIG
Re: [Plugin] Flatten to Plane v1.2 20101023@gude
Have you checked out cubicpanout.rb? i7-4930K 3.4Ghz, 2x GTX780 6GB, 32GB DDR3-1600 ECC, OCZ Vertex 4 500GB, WD Black 3TB, 32TB NAS, 4x 27" Monitors, SpaceMouse Pro, X-keys XK-60
Re: [Plugin] Flatten to Plane v1.2 20101023TIG, is there a way to combine this with your Axo + Iso View plugin to export a 2D isometric view?
I thought of Work Plane but I can't seem to get it right ![]() Re: [Plugin] Flatten to Plane v1.2 20101023how stupid...I just need to export a 2d graphic of course
Who is online
Users browsing this forum: ashunighut7, cris3030, gabitouma, Lars Nielsen, MarcelaEs, mybreeze, panjidanuarta, reforminteriors and 15 guests
