win32 output debugging
Postby Jim » Sun Sep 26, 2010 6:21 am
An alternative way for debugging on Windows machines using Win32API.so.
You need a system debug viewer running such as DebugView and output goes to the debugger window. Also,
If the application has no debugger and the system debugger is not active, OutputDebugString does nothing.
This could also be used with Al's trace ruby messages technique so instead of output going to files ,it goes to the debugger.
Come to think of it, something like this should be part of the api.
Code: Select all
OutputDebugString = Win32API.new("kernel32.dll", "OutputDebugString", ['P'], 'V')
def opd(s="\0")
    s = s.to_s + "\0"
    OutputDebugString.call(s)
opd(Time.now)
Jim
Global Moderator
Re: win32 output debugging
Postby thomthom » Sun Sep 26, 2010 11:44 am
This is excellent! :thumb: :thumb:
Jim wrote:Come to think of it, something like this should be part of the api.
Double Plus Good!
User avatar
PluginStore Author
PluginStore Author
Postby Chris Fullmer » Sun Sep 26, 2010 5:45 pm
How would I use this Jim? I add that code to a script while I'm writing it. And do do what with it? It just does everything on its own?
User avatar
SketchUp Team
SketchUp Team
Postby Jim » Sun Sep 26, 2010 6:15 pm
Here's what I came up with. Just make sure it is alphabetically the first file in Plugins in order to capture the earliest output.
Code: Select all
require 'Win32API'
class CL_rps_console < Sketchup::Console
    def write(smess="\0")
        smess = smess.to_s + "\0"
        OutputDebugString.call(smess)
# redefine standard output to our new class
$old_stdout = $stdout # in case you want to turn off traces
$stdout = CL_rps_console.new
$stderr = $stdout
puts "-" * 40
puts Time.now
puts "Starting SketchUp"
puts "-" * 40
Jim
Global Moderator
Postby Jim » Mon Sep 27, 2010 12:30 am
In DebugView, you can clear the debugger window by outputting the string "DBGVIEWCLEAR"
Jim
Global Moderator
Postby tbd » Mon Sep 27, 2010 8:25 am
Jim: are you working for Render Plus now ? ;)
http://plugins.ro
User avatar
tbd
Postby thomthom » Mon Sep 27, 2010 8:56 am
I think this thread should be sticky... or in the sticky thread...
User avatar
PluginStore Author
PluginStore Author
Postby Jim » Tue Sep 28, 2010 3:12 am
It turns out this OutputDebugString example is straight out of the Pickaxe book.
Jim
Global Moderator
Postby thomthom » Wed Oct 13, 2010 7:34 pm
Sketchup::Console :?: :?:
User avatar
PluginStore Author
PluginStore Author
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Developers' Forum
Who is online
Users browsing this forum: No registered users and 15 guests
Visit our sponsors:
