[Plugin] Solid Inspector
Postby thomthom » Wed Sep 01, 2010 7:12 pm
Overview
A feeble beginning for a tool that checks if Groups or Components are solids or not, highlighting holes or areas or errors.
Access
Tools > Solid Inspector
Usage
Click on an group or component to analyst it for holes.
Use Tab (Shift+Tab) to cycle through and zoom to the errors.
Use Up/Down Left/Right arrows to cycle between errors.
Use Return to zoom to current error.
Version 1.1.0:
If nothing is selected - the current context will be inspected.
Future Ideas
  • Webdialog list of errors with description of each error. If possible, attempt to automatically fix.
Requirements
  • SketchUp 7 or newer - ( Other versions untested )
  • TT_Lib2
Download
Footprint
<Sketchup>/Plugins/
tt_solid_inspector.rb
7
User avatar
PluginStore Author
PluginStore Author
Re: [Plugin] Solid Inspector (1.0.0) — 01 September 2010
Postby Ben Ritter » Wed Sep 01, 2010 7:32 pm
Wow Thomas, this is more exciting than the version 8 release. Thank you.
Ben Ritter
Postby jeff hammond » Wed Sep 01, 2010 7:52 pm
ha! that just saved me a a bunch of headache (well the headache was already coming on trying to figure out why and older group of mine wouldn't be recognized as a solid in su8)..
used your inspector and it found the teeniest tiniest little face inside
:thumb: :thumb:
thank you!
User avatar
Global Moderator
Postby pilou » Thu Sep 02, 2010 1:31 am
Creation's crisis! :D :enlight:
Speedy Galerie
User avatar
Top SketchUcator
Postby notareal » Fri Sep 03, 2010 7:53 am
Nice!
notareal
Thea Render Support
Thea Render Support
Postby jsteacy » Fri Sep 03, 2010 2:31 pm
This is a great tool! Awesome!
jsteacy
Premium Member
Premium Member
Postby olishea » Fri Sep 03, 2010 4:24 pm
cheers :thumb:
oli
User avatar
olishea
Premium Member
Premium Member
Postby GWD » Sat Sep 04, 2010 12:58 pm
Solid Inspector doesn't load. I place the plugin in the plugin folder and also downloaded the TT_lib2 and placed it on the right placed. But the menu doesn't show up. I tried to load it manually and get the following error:
Error: #<LoadError: (eval):923:in `load': No such file to load -- tt_solid_inspector.rb>
(eval):923
regards,
Guy
GWD
PluginStore Author
PluginStore Author
Postby thomthom » Sat Sep 04, 2010 1:01 pm
What is the exact location to extracted tt_solid_inspector.rb to?
User avatar
PluginStore Author
PluginStore Author
Postby GWD » Sat Sep 04, 2010 8:15 pm
C:\Program Files\Google\Google SketchUp 8\Plugins
GWD
PluginStore Author
PluginStore Author
Postby thomthom » Sat Sep 04, 2010 10:01 pm
This is just odd...
You have the file at "C:\Program Files\Google\Google SketchUp 8\Plugins\tt_solid_inspector.rb" - and when you type in load "tt_solid_inspector.rb" into the Ruby Console you get
(eval):923
which claims the file is not there... ?
I also don't understand why it says (eval):923
When I try to load a non-existent file I get:
load 'test'
Error: #<LoadError: (eval):0:in `load': no such file to load -- test>
(eval)
(eval):0
Are you sure you didn't but the .rb file in a folder and not directly in the Plugins folder?
Can you post a screenshot of the file in Explorer (including the filepath in the address bar). Sorry to have to make you confirm what you say, but I have had cases like this where the file actually was misplaced.
User avatar
PluginStore Author
PluginStore Author
Postby GWD » Sun Sep 05, 2010 5:04 am
thomthom,
no problem...
regards,
Guy
GWD
PluginStore Author
PluginStore Author
Postby Krisidious » Sun Sep 05, 2010 5:40 am
I know you're tryin to get me to upgrade Thom...
By: Kristoff Rand
Home Designer
Unique House Plans
User avatar
Krisidious
Postby GWD » Sun Sep 05, 2010 9:14 am
ThomThom,
Problem is fixed. I completly removed v7 from my system. It seams that he sometimes opened v7 when i thought i was working with v8.
regards,
Guy
GWD
PluginStore Author
PluginStore Author
Postby thomthom » Sun Sep 05, 2010 9:46 am
Krisidious wrote:I know you're tryin to get me to upgrade Thom...
This doesn't require SU8. ;)
User avatar
PluginStore Author
PluginStore Author
Postby thomthom » Sun Sep 05, 2010 9:47 am
GWydouw wrote:ThomThom,
regards,
Guy
Ah - yes, if you double-click a file to open SU it will open the version you last used.
User avatar
PluginStore Author
PluginStore Author
Postby GWD » Mon Sep 06, 2010 2:40 pm
ThomThom,
Thanks for this fantastic plugin!!!!
regards,
Guy
GWD
PluginStore Author
PluginStore Author
Postby thomthom » Mon Sep 06, 2010 2:42 pm
User avatar
PluginStore Author
PluginStore Author
Postby fountainhead » Mon Sep 06, 2010 7:06 pm
I think this plug-in is long overdue...great job ThomThom! I can't tell you the number of times I've tried a boolean operation, or a volume calculation, only to get the "this ain't a real solid dude" message.
"It isn't a real solid...well what's wrong with it?"
"Not gonna tell ya...but it's wrong for sure. Good luck finding the problem man."
Now instead of hunting aimlessly for the micro gapped edge, or the itty bitty hanging triangle that can only be seen under exponential magnification, you point us right to it.
NICE.
fountainhead
Postby thomthom » Mon Sep 06, 2010 7:16 pm
User avatar
PluginStore Author
PluginStore Author
Postby tomislavm » Tue Sep 07, 2010 2:31 pm
When can we expect this
Future Ideas
* Webdialog list of errors with description of each error. If possible, attempt to automatically fix.
Automatically fix, o yes!
tomislavm
Postby thomthom » Tue Sep 07, 2010 2:44 pm
I don't know. It all depends on when I get a spare moment. I'm currently looking into some UV mapping tool.
User avatar
PluginStore Author
PluginStore Author
Postby Jim » Tue Sep 07, 2010 3:02 pm
Hi Thom. Here's a scenario - I have a Group I'm checking for a solid. It's quite big and takes a few seconds to open and close the Group. When I use Solid Inspector on the Group to find the errors, I then need to open the Group for editing to fix them, then close it to re-check - open, close, open, close, etc.
Would it be possible to tell the plugin to operator on the current context so we do not need to always change the context between checking and fixing?
-1
Jim
Global Moderator
Postby thomthom » Tue Sep 07, 2010 3:10 pm
Jim wrote:Would it be possible to tell the plugin to operator on the current context so we do not need to always change the context between checking and fixing?
Yea - I've been thinking it needs a function like that.
*adding to the todo list*
User avatar
PluginStore Author
PluginStore Author
Weight calculator
Postby Bertier » Wed Sep 08, 2010 3:36 am
Hi there, would it be possible to tell solid :
this is (for example) : solid oak
solid oak is : 640 kg / cubic meter
solid weight : whatever volume * 640 in this case ?
that would be great.
thanx to you guys !
Bertier
Postby d12dozr » Wed Sep 08, 2010 4:35 am
Bertier,
Have you seen Volume Calculator by TIG?
http://goo.gl/f7ooYh
d12dozr
Top SketchUcator
Postby Bertier » Wed Sep 08, 2010 6:27 pm
thank, I hadnot seen it.
Bertier
Postby Chris Fullmer » Thu Sep 09, 2010 4:56 am
tomislavm wrote:Future Ideas
I've also written a solid checking tool about a year and a half ago here:
viewtopic.php?f=323&t=17876
The next day TIG followed my plugin with one of his own that attempts to fix missing faces here:
viewtopic.php?p=143720
So you might already have a script that eill help detect and cleanup non-solids. Good luck,
User avatar
SketchUp Team
SketchUp Team
Postby mariocha » Wed Sep 15, 2010 3:16 am
You made made day !!!
Works just fine.
This is going to be so usefull ! :berserk:
Mario C.
Certified SketchUp Trainer, QC CA.
Every rule has exceptions, but some.
User avatar
mariocha
Premium Member
Premium Member
Postby Fabiazz » Tue Oct 12, 2010 4:09 pm
Why I didn't notice this plugin before. This will fix all my unsolidity problem. Great work!
User avatar
Fabiazz
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Next
Return to Plugins
Who is online
Users browsing this forum: baldaman, blajnov, diepgia1986, Google Bot, Mamun up, narenderkumar, vitorluciano and 11 guests
Visit our sponsors:
