[Plugin] $ Copy Brick (Updated 5/04/11)
Postby sahi » Sun Aug 01, 2010 9:13 pm
Copy group ( $ 1.05.2011)
Enter >> Exit
Double click >> Exit
Remove the previous script from a folder Plugins "kirpich.rbs" and "blokk.png"
downloaded http://stroyka.name/brick.php
EDIT: Inserted Video by rclub24
sahi
PluginStore Author
PluginStore Author
Re: [Plugin] Copy (Brick)
Postby solo » Sun Aug 01, 2010 9:55 pm
Very cool plugin mate!!!
I love the rotation tool it comes with.
I'm better with polys than words
User avatar
Global Moderator
Postby Daniel S » Sun Aug 01, 2010 10:00 pm
Awesome Sahi!!! :berserk: :berserk: :berserk:
Love the UI!!
But I have a problem with the orientation/rotation... I tried with groups, components but without luck.
Look at this .gif.
Any idea on how to fix it?
Thank you,
Daniel S
Daniel S
Postby xrok1 » Sun Aug 01, 2010 10:01 pm
thats cool! but where's the brick part of the plugin? :D
xrok1
Postby solo » Sun Aug 01, 2010 10:05 pm
Try using the arrow keys
User avatar
Global Moderator
Postby Daniel S » Sun Aug 01, 2010 10:09 pm
solo wrote:Try using the arrow keys
It is exactly the same... the preview box show a good orientation... but when I insert the group the orientation is always the same, it dosen´t change.
Daniel S
Daniel S
Postby Daniel S » Sun Aug 01, 2010 10:13 pm
More information...
if I have the ruby console open it says:
Code: Select all
WARNING: make_unique is a deprecated methodof Sketchup:Group
Error: #<NoMethodError: undefined method `transformation_rotation_array' for #<Kirpichi_create_raspolozhenie:0x8970330>>
(eval):787:in `kirpichi_create_raspolozen'
(eval):622:in `onLButtonDown'
(eval):787
Daniel S
Daniel S
Postby solo » Sun Aug 01, 2010 10:13 pm
I get the same issue now, however if you initially use the arrow keys and not the protractor thing then it works, as soon as you touch the protractor it stops working...glitch.
User avatar
Global Moderator
Postby sahi » Sun Aug 01, 2010 10:15 pm
Daniel S wrote:But I have a problem with the orientation/rotation... I tried with groups, components but without luck.
I understand. The problem in the axes
I'll try to fix this error.
sahi
PluginStore Author
PluginStore Author
Postby sahi » Sun Aug 01, 2010 10:37 pm
sahi wrote:But I have a problem with the orientation/rotation... I tried with groups, components but without luck.
I corrected this error.
First Message Brick_2.zip
sahi
PluginStore Author
PluginStore Author
Postby solo » Sun Aug 01, 2010 10:45 pm
works great now.
User avatar
Global Moderator
Postby sahi » Sun Aug 01, 2010 10:56 pm
Upgrade plugins First Message Brick_3.zip
sahi
PluginStore Author
PluginStore Author
Postby Daniel S » Sun Aug 01, 2010 11:10 pm
Sahi, Thank you for the quick update.
It works very well.
But there is a small cosmetic bug... look at the wireframe using groups.
In this .gif I show that using components looks well and groups not:
This happens with simple boxes too.
Daniel S
Daniel S
Postby sahi » Sun Aug 01, 2010 11:27 pm
Fixed
Upgrade plugins First Message Brick_4.zip
sahi
PluginStore Author
PluginStore Author
Postby sahi » Sun Aug 01, 2010 11:37 pm
xrok1 wrote:thats cool! but where's the brick part of the plugin? :D
Yes
I'm working on it
sahi
PluginStore Author
PluginStore Author
Postby Ken » Sun Aug 01, 2010 11:52 pm
This program shut my Sketchup down without a error. Stops every time I pick the icon.
However, thanks for the plugin, I know you will get it working.
Ken
User avatar
Ken
Premium Member
Premium Member
Postby sahi » Sun Aug 01, 2010 11:55 pm
Ken wrote:This program shut my Sketchup down without a error. Stops every time I pick the icon.
Ken
Double Click = Exit
sahi
PluginStore Author
PluginStore Author
Postby boofredlay » Mon Aug 02, 2010 12:06 am
Ooo, nice.
User avatar
boofredlay
Global Moderator
Postby xrok1 » Mon Aug 02, 2010 12:09 am
Yes
I'm working on it
:D
xrok1
Postby Daniel S » Mon Aug 02, 2010 12:16 am
Sahi, thanks again...
I was trying your plugin... and discover a new issue.. but this one is very important
I put 60º in the protractor but the result is 59,38º for example.
If I put 30º the result is similar, but not 30°.
Perhaps the problem is with my units... I attach a .skp file.
Daniel S
Daniel S
Postby sahi » Mon Aug 02, 2010 1:17 am
Daniel S wrote:Sahi, thanks again...
Fixed
Upgrade plugins First Message Brick_6.zip
sahi
PluginStore Author
PluginStore Author
Postby Daniel S » Mon Aug 02, 2010 1:28 am
Thank you Sahi!!! :berserk: :berserk: :berserk:
A great plugin!!!
http://www.sketching3d.com.ar/2010/08/c ... lugin.html
Daniel S
Daniel S
Re: [Plugin] $ Copy (Brick)
Postby tomislavm » Mon Aug 02, 2010 7:46 am
tomislavm
Postby urgen » Mon Aug 02, 2010 11:51 am
Ooo very useful! :bounce: thanks! :thumb:
--pupil forever...------
User avatar
urgen
Postby sahi » Mon Aug 02, 2010 4:48 pm
Upgrade plugins First Message Brick_7.zip
sahi
PluginStore Author
PluginStore Author
Postby sahi » Mon Aug 02, 2010 7:30 pm
Upgrade plugins First Message Brick_8.zip
sahi
PluginStore Author
PluginStore Author
Postby utiler » Tue Aug 03, 2010 12:01 am
Daniel S wrote:Thank you Sahi!!! :berserk: :berserk: :berserk:
A great plugin!!!
http://www.sketchup8.com.ar/2010/08/cop ... lugin.html
Daniel S
Off topic:
Daniel, I've had a look at your blog, follwoing it now!!! Just curious, why Sketchup8.com.ar? WHat happens when V8.0 is out and V9.0 is next? ;)
purpose/expression/purpose/....
User avatar
utiler
Top SketchUcator
Postby Daniel S » Tue Aug 03, 2010 1:19 am
utiler wrote:Off topic:
The domain names in Argentina are .com.ar
And the 8 will be changed for ∞ using the future SU 9.0 technology:
:P :P :P
Daniel S
Daniel S
Postby utiler » Tue Aug 03, 2010 1:41 am
Clever boy! look forward to following.... :thumb:
User avatar
utiler
Top SketchUcator
Postby njh » Tue Aug 03, 2010 12:19 pm
Hi Sahi / Guys,
Just downloaded the plugin and I'm VERY VERY impressed but I have a question as a mac user with an apple full size USB keyboard.
The arrow keys work fine for rotation and scale and the ctrl key works fine for the mirror on (red?) axis but my keyboard doesn't have the second functions shown on the numeric keypad (home etc) so I can't seem to mirror along the other two axis.
Sorry if this has already been explained earlier in the post or if I'm just being a bit dim and don't know how to use an apple keyboard properly!
Hope someone can help.
Cheers
NJH
njh
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Next
Return to Plugins
Who is online
Users browsing this forum: ar_parashar, Bing [Bot], BrokenBo, goga63, Schtuu, vorosliliom1915 and 10 guests
Visit our sponsors:
