[WIP] Reconstruction of my favorite disco Palladium New York
Looking forward to seeing what you do with it Jo. Enjoy your holiday
I'm back and I'm going to continue that project.
Here's what I'm going to remodel: The Palladium club was located in New York, it was an old theatre, which was reconstructed in the mid 80ties to a big nightclub, with one of the best lightshows i have seen so far. The backside of the stage was painted by keith haring. It was pulled down in 1998 make place for a new building. here are some pictures and videos of the original:
http://www.youtube.com/watch?v=t5_NI2MSmp8
Youtube Video
here are the first two twilight- renders (with some trange results)
jo-ke: how come you don't post on twilight forum? you'd get much more direct help.
This is a good idea. I will do that in addition.
here's a small render took 3 hours with preset low
I would suggest sorting out your lighting/gobo projections first before using the fog material. it really really slows down render time so use it right at the end.
like the silhouettes! looking good
what do you mean by "sorting"? At the moment the beams doesn't work anymore. I added some other lights to the scene, I don't know what happend but the "fogbeams" doesn't render anymore.
I mean making sure the rest of the lighting works before you play with beams.
With a fog material the camera must be outside the" fog box" or it won't render (for bias) and the camera must be inside the fog box for unbias (progressive presets)
I was using preset low and the camera was definitely outside the fogbeams.
I have an older version and the render in the same position still works, but not at the new verson.
here's another one without beam (but with preset 11, so I expected no beams)
a small render after 4 and a half hours with preset low.
I think I make the big one, when I'm out...
Looking good!
my notebook has rendered all nicht long. here's the result
here's another one:
I'd say you've captured the nightclub look perfectly. Which is not an easy thing to do with so many lights and odd shadows.
yesterday I rebuild the famous stairs with the lights. I rendered the scene again in twilight with preset low for 12 hours. I don't know what happend but the beams weren't rendered right to the end.
same scene, preset 10 for 6 houres without volumetrics
at the moment I'm working on an update of this old project:
first test render
update
another view:
one more
