run batch file from ruby as admistrator
Postby simonstaton » Wed Jun 23, 2010 2:10 pm
I am running a batch file from ruby using:
ge=UI.openURL(Sketchup.find_support_file('')+"/registergoogleearthcmd.cmd")
inside the batch file is the following:
"C:\Users\Simon\Documents\Action Design Your Own v2\Action 3D\client\googleearth.exe" /regserver
however when I run sketchup and the batch file is loaded it says it needs to be run as administrator now this command works fine if I load up cmd as admin and manually typing it in it goes straight through.
So my question is how can I run this from ruby as an administrator?
Simon
simonstaton
Re: run batch file from ruby as admistrator
Postby Dan Rathbun » Wed Jun 23, 2010 2:23 pm
simonstaton wrote:So my question is how can I run this from ruby as an administrator?
What would be the point of having an Operating System Security if any script was allowed to run with Administrative Rights?
Oh wait... I do remember MS-DOS :lol:
    I'm not here much anymore. But a PM will fire email notifications.
    User avatar
    Dan Rathbun
    PluginStore Author
    PluginStore Author
    Postby simonstaton » Wed Jun 23, 2010 2:29 pm
    hmm so there is no way of doing this? I have updated my script with the following:
    Code: Select all
    tmp_cmd="My_tmp_file_"+Time.now.to_i.to_s+".cmd"
    cmd_path="C:/Temp/"+tmp_cmd
    cmd_line="\""+Sketchup.find_support_file('')+"/client/googleearth.exe\" /regserver\nexit"
    cmd=File.new(cmd_path, "w")
    cmd.puts(cmd_line)
    cmd.close
    UI.openURL(cmd_path)
    sleep(1)
    File.delete(cmd_path)
    if I cant run as admin is there any other way or registering google earths location outside of its default through command line or ruby?
    Simon
    simonstaton
    Postby Dan Rathbun » Wed Jun 23, 2010 2:32 pm
    You'd need to use the runas.exe utility.
    It's in the Windows/system32 folder, so is available in the PATH.
    Open a CMD window, and type:
    runas /?
    for parameter information.
    For more info, do a search at MSDN
      User avatar
      Dan Rathbun
      PluginStore Author
      PluginStore Author
      Postby simonstaton » Wed Jun 23, 2010 2:34 pm
      dont worry solved I just need to right click sketchup and run as administrator
      simonstaton
      Postby Dan Rathbun » Wed Jun 23, 2010 2:40 pm
      simonstaton wrote:dont worry solved I just need to right click sketchup and run as administrator
      Manual? I could have told you that!
      You asked how to do it with a batchfile... :roll:
        User avatar
        Dan Rathbun
        PluginStore Author
        PluginStore Author
        Postby simonstaton » Wed Jun 23, 2010 2:49 pm
        yes I know, but that easiest solution slipped through my hands :shock:
        simonstaton
        by Ad Machine » 5 minutes ago
        Ad Machine
        Robot
        Return to Developers' Forum
        Who is online
        Users browsing this forum: Fernando Lino, Hilman123 and 14 guests
        Visit our sponsors:
