[Plugin] ExtrudeTools - Full Set
Re: [Plugin] ExtrudeTools - Zipped Set
Postby TIG » Thu Jun 03, 2010 4:57 pm
I didn't make a separate EEby.. tool since you can do it relatively easily with EEbyRails as in this example
User avatar
Global Moderator
Postby stefx » Thu Jun 03, 2010 5:18 pm
Thank you TIG.
I have tried but:
1: i create my face with all the edges welded
2. i select the profile as curve
3. i select the 2 rails
4. i select the melding-prfile curve
5. Sketchup crashes!
I am thinking to split the face-curve in two parts.
Stef.
stefx
Postby TIG » Thu Jun 03, 2010 5:30 pm
Can you post an example skp ?
User avatar
Global Moderator
Postby stefx » Thu Jun 03, 2010 5:43 pm
Here it is!
basically it is roof design, you could find the profile of the roof and 2 rails.
The two rails don't touch the profile.
So I welded the whole profile, I welded the 2 rails but when I try to use the plugin everything crashes!
I have tried to split the profile in more parts, and it looks like working.
Stef.
stefx
Postby TIG » Thu Jun 03, 2010 6:18 pm
It can only be done after the model is 'fixed'.
The roof profile is not quite coplanar [try to add a face to it - you can't !] so it adds all sorts of additional problems... with geometry flying off into space etc etc...
Complex 3D curves will work as Profiles but especially looped ones with slight discrepancies can be problematical !
To fix it select the roof profile curve and use EEbyVector on it to make a small temporary roof-bit [ extruded away from the 'rails' but in line with the first edge].
Now draw a large vertical rectangle that intersects the whole of this new roof-bit.
Select that rectangle and right-click > intersect > with model.
Erase the unwanted bits of the rectangle and keep just the faced roof profile.
Erase the temporary roof-bit too.
You know have a coplanar roof profile.
Select the edges of it and weld them into one curve.
Move it near to the rails but not touching them, so it doesn't 'split'.
Check that the rails have the same number of edges - if not group them draw over them with lines and erase the originals then when they have the same number of edges [select and use entity info] weld each set in turn into a curve.
Now you can use EEbyRails...
Select the Profile, then the Rails in turn and the Profile again as the melding-profile [in is 'assumed' at the other end of the rails as required].
The mesh is made as expected...
You need to add 'end-faces' by drawing over an edge at the ends... :ugeek:
User avatar
Global Moderator
Postby stefx » Fri Jun 04, 2010 9:38 am
Hi TIG, thank you for your tutorial.
I guess it is a problem of my Sketchup.
This a licensed version that I used at work.
I am saying that because i have tried to use a simple rectangle with 2 rails (I draw one and copied as 2 rail just to have the same number of segments and same features).
(see attached)
After I welded the edge of the rectangle if I try to use the Extrude By Rails sketchup quit the work.
I think I have to do the same splitting the edge of the rectangle or roof in different pieces.
:cry:
stefx
Postby TIG » Fri Jun 04, 2010 1:29 pm
How do the want the profile to end at the rail-ends ? If it's wanted as 'flat' then you need to copy the profile to the end and rotate it etc. I'd let the rails split the profiles and make two extrusions, then group their groups, edit that group and explode the two into one st of geometry inside this parent-group.
If you want to extrude the profile along the rail in the same plane all if the time then try EEbyEdges [group] the two sets of profile and path first...
User avatar
Global Moderator
Postby stefx » Fri Jun 04, 2010 5:51 pm
Hi Tig,
thank you for your tutorial......again.....
I have followed your indications. I got the results I wondered.
We don't need Extrude face by rails as soon we could get the same results in other ways.
Thanks again.
Stef.
stefx
Postby rizal21 » Fri Jul 02, 2010 7:48 am
my toolbar for this not show up, please help :| , found #extrusionToolbar.rb, but i think it's for menu
rizal21
Postby TIG » Fri Jul 02, 2010 9:45 am
The file you found IS needed to make the menu AND toolbar.
You need to activate the toolbar from View > Toolbars > Extrusion Tools :?
User avatar
Global Moderator
Postby tiagomedeirosdsg » Sat Aug 14, 2010 2:39 pm
Obrigado pelo plugin
tiagomedeirosdsg
Postby Gaieus » Sat Aug 14, 2010 3:53 pm
tiagomedeirosdsg wrote:Obrigado pelo plugin
Google Translate wrote:Thanks for [the] plugin
:thumb:
User avatar
Postby olishea » Thu Aug 26, 2010 10:08 am
For some reason, when I install this plugin....my sketchup starts up very quickly. I used to wait 15 seconds or so for all my plugins to load, now it's instant!!
confused!!
having a play with these amazing tools, thank you so much TIG.
are there any videos in the pipeline? I feel they would help a lot.
Also, how do you define a "melding profile"....I mean I know what it does.....is it just the finishing profile? if that makes sense
oli
User avatar
olishea
Premium Member
Premium Member
Postby TIG » Thu Aug 26, 2010 1:28 pm
Oli
There are quite a few [illustrated] pages for each tool in the set - see the many links from the main zipped set download page...
A lot of the tools need two profiles and two rails.
The pick order is:-
    A 'profile' - the starting curve form that will 'extrude' down the rails.
    B 'rail-1' - the first rail to follow with this extrusion.
    C 'rail-2' - the second rail to follow with this extrusion - Note: you can also pick 'rail-1' again as 'rail-2' and it then assumes a copy of 'rail-1' is placed at the other end of the 'profile'.
    D 'melding-profile' [it's a fancy name for 'profile-2'!] is what the 'profile' will 'morph' into [meld] as it is repeated down the rails - Note: you can pick 'profile' again as the 'melding-profile' and then the only 'morphing' the profile will undergo is the fitting between the rails etc.
The curves need not touch but it can be helpful to visualize the result if they do... the 'mesh' is made 'over' the 'rails'.
Pairs of profiles/rails need NOT have equal curve segment counts... but if they do not and the numbers are not simple multiples then extra vertices are added to adjust the mesh and it might not be what you expected...
:ugeek:
User avatar
Global Moderator
Postby maxel99 » Sun Aug 29, 2010 11:17 am
excellent ruby tig, truly amazing.
I just had two questions:
*The extrude edges by faces does not appear to work with lines - can you make this work?
A work around for this is to create a line and then break it apart and use the 'weld' ruby to put it back together. BUT is there a simpler way? It'd be great if this just worked for straight lines - or do you know of a similar ruby plugin that does this function?
*second: are there tutorials for these tools? I am struggling to use them and it looks like there are bits and pieces of info on them but they are not in one central location - would it be possible to unify the tutorials for these into a few critical images for each tool like you unified the toolbar?
Would be great, and as I said earlier, great tools as they are (just wish I could use them better with more tutorials!)
maxel99
Postby TIG » Sun Aug 29, 2010 11:40 am
It only uses Curves BUT as explained in it's notes you can have a single segment Curve made from a selected Line - use Divide > 2 and then Weld the still selected 2 parts to make a Curve, now draw another Line to split the Curve at it's center Vertex and erase one part. You now have a single segment Curve.
It cannot use lone Lines as it would recognize each segment in a selected Curve as a Line - so it's all Curves I'm afraid - it's not too onerous to make Lines into 'straight' Curves - Tip: I use shortcuts for Divide [Ctrl+D], Weld [J] etc...
User avatar
Global Moderator
Postby jeff hammond » Sun Aug 29, 2010 3:34 pm
maxel,
fredo's BezierSpline plugin:
viewtopic.php?t=13563
..can draw polylines (or one segment curves if you will) which work great with the extrude tools
either draw the lines in place (using 'polyline'.. the second icon in the toolbar) or, draw the lines with SU's line tool then right click it -> BZ Convert To -> polyline.
as to the tutorials, i'm pretty sure there isn't a consolidated list.. these are fairly new tools tig has developed and many of the early adopters are still learning them.. best thing to do at this time is post an example .skp here showing what you'd like to accomplish and someone will be able to tell you if it's possible or how to do it..
User avatar
Global Moderator
Postby olishea » Tue Aug 31, 2010 7:49 pm
cheers for explanation TIG, i just needed it in words!!
oli
User avatar
olishea
Premium Member
Premium Member
Postby InterArchi » Mon Sep 20, 2010 8:05 am
Thank you sir for this script...
Can anyone here show us what did he do with this script in a real project, in a design work or in sketch project ?
I mean I know it is very great to work with thhis plugin, but I really want to see an architectural work made by this great plugin, Any one ?
InterArchi
Postby jeff hammond » Mon Sep 20, 2010 9:52 pm
InterArchi wrote:Thank you sir for this script...
i have a bunch of concepts and construction drawings which i drew using these tools but i have to keep them off the web..
i've got an actual project beginning in 3 weeks which was designed using extrude by rails.. i'll post some pictures upon completion.
User avatar
Global Moderator
Postby InterArchi » Sat Sep 25, 2010 10:15 am
Hi sir ..Still waiting for your post sir
InterArchi
Postby ofarcan » Sat Oct 16, 2010 1:39 am
thanks for plugin.
ofarcan
Re: [Plugin] ExtrudeTools - Zipped Set 20101023
Postby TIG » Sat Oct 23, 2010 4:11 pm
Here's an updated zipped set viewtopic.php?p=217663#p217663
The 'extrudeEdgesByRailsToLattice' tool has been updated to include a pane-thickness option - useful if the pane might be viewed from both sides and/or exported to a 3rd party renderer where back-faces are not rendered. Also its .lingvo files have been updated to suit...
User avatar
Global Moderator
Re: [Plugin] ExtrudeTools - Zipped Set 20101027
Postby TIG » Wed Oct 27, 2010 12:30 pm
Here's an updated zip viewtopic.php?p=217663#p217663
The main changes are...
The 'Extrusion Toolbar' title's db() translation is fixed with a new lingvo file.
In EEbyVector you can now end an 'extrusion' in with a 'double-click'.
In EEbyFace if there is no 'suitable' face in the selection it's trapped with error message.
In EEbyLathe it now undoes in fewer 'steps' - ~one for each 'optional dialog'.
In EEbyRailsToLattice the missing db() on 'Processing...' in corrected.
User avatar
Global Moderator
Re: [Plugin] ExtrudeTools - Zipped Set 20101030
Postby TIG » Sat Oct 30, 2010 12:49 pm
Here's an updated set viewtopic.php?p=217663#p217663
ExtrudeEdgesByRailsByFace is now trapped to stop you selecting a non-flat face and breaking Sketchup!
the lingvo files are also updated to suit.
User avatar
Global Moderator
Postby smiley007 » Sun Oct 31, 2010 7:02 pm
Thanks very much for these exellent tools.
smiley007
Re: [Plugin] ExtrudeTools - Zipped Set 20101102
Postby TIG » Tue Nov 02, 2010 11:27 am
There a new tweak to EEbyRailsByFace to catch no face selected or an empty selection at the start [as well as any 'inappropriate' selections].
Also two of the ES lingvo files have some minor rephrasing by Defisto [again!]...
User avatar
Global Moderator
Postby cdurkin » Wed Nov 17, 2010 11:32 pm
Hello
Ive just added the extrude tools zipped set to my ruby library but, despite getting the plugins to work on version 7, I'm having difficulty getting them to work with SU version 8. Has anyone else had the same problem??? know how to fix??
cdurkin
Postby TIG » Thu Nov 18, 2010 4:28 pm
cdurkin
What error messages do you get at startup or later in the Ruby Console when you try to use the tool ?
It works fine for most users in v8, if it's correctly installed.
Hove you copied all of the required files and sub-folders over ?
Make sure there are none in the wrong place too, even if you have done a full install from the zip you might have some files misplaced and causing clashes...
Their has been one report of a clash with SketchyPhysics in v8 [I suspect that SP rewrites a SUp base-class method ill-advisedly that some EEby... (and other's) tools are using... but it's not yet established/resolved].
If you have SketchyPhysics try removing its .rb files from Plugins temporarily and see if that fixes the glitch...
User avatar
Global Moderator
Postby cdurkin » Thu Nov 18, 2010 10:36 pm
Hello again
The Specific problem has to do with the icons on the toolbar and heading eg(extrude edges on edges ect.)on the menubar. Some of them work and others don't. It sounds like it may be the folder allocation problem you suggested. I have all files that came with the plugin in the the TIGtools folder accept the 10 extrudeEdgesByEdges.rb.......to...extrudeEdgesByVector.rb files which are directly in the plugins folder. The icons on the toolbar that seem to be giving my trouble are:
extrudeEdgesByFace.rb
extrudeEdgesByFaces.rb
extrudeEdgesByRails.rb
extrudeEdgesByRailsByFace.rb
extrudeEdgesByRailsToLattice.rb
I can use all the commands, it even says in the command prompt at the bottom of the screen the the geometry is being made, yet no matter how long i wait the extruded geometry does not appear.
extrudeEdgesByLathe.rb
extrudeEdgesByLoft.rb all work fine
If it is the file allocation problem do you know which other files I should move?
cdurkin
by Ad Machine » 5 minutes ago
Ad Machine
Robot
PreviousNext
Return to Plugins
Who is online
Users browsing this forum: alissonpastorio, aneurys_1818, bennio72, doubleping, matsuo_lano, MauricioSancho, senaag and 17 guests
Visit our sponsors:
