[Plugin Beta] Curviloft 1.8a - 31 Oct 18 (Loft & Skinning)Re: [Plugin Preview] Curviloft 1.0 (Loft and Skinning)Wooo. this is cool. it must be award for your amazing job
![]() Re: [Plugin Preview] Curviloft 1.0 (Loft and Skinning)Diego Many thanks for the examples. Here is the results, in video (quickly done), but before a few remarks: - the script does not support Sweep (i.e. Loft along two paths) - when contours are borrowed from component, you have to do a manual selection, because SU does not let you select edges within and outside component at the same time. - Holes are not supported directly. You need to generate the loft surface for each contour, inner and outer (just imagine that you can have many holes, and that you cannot edit the inner part if the outer part is generated at the same time) - I am still struggling to understand how SU orient faces when generated them. So for the time being, junctions may be oriented up or down (this can anyway easily be fixed afterward with Orient Faces and Reverse Faces). 1) the easy ones 2) Loft along path with 2 tubes 3) This one shows that the script has still an issue with the vertex matching. But this is a way to also show how to correct it by editing the vertex matching. 4) Another loft along path 5) Some skinning, one still with an issue (a bug in SU API for colinear edges)
Re: [Plugin Preview] Curviloft 1.0 (Loft and Skinning)fredo excellent.
models if you need more let me know. "Fredo:- the script does not support Sweep (i.e. Loft along two paths)" perhaps the plugins of kilrill, you help. the uses a second paths who calls " pick pathface adjuste curve" a question. the interface (panel floating bar) could be programmed in html? perhaps more could be done similar to dialog boxes of sketchup regards
From what I understand, the face direction depends in the direction the points are added. Clockwise or counter-clockwise. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin Preview] Curviloft 1.0 (Loft and Skinning)Great Dude! This is making the history of SU!
Tom, That's the rule. But the question is about add_faces_from_mesh. Ruby seems to choose an orientation and then stick to it. But what is teh rule for the first orientation, because in 3D there is nothing like clockwise or anticlockwise if you do not have a reference vector. Is it the absolute Z_AXIS or the Z_AXIS of the view coordinates or something else? Fredo
I'm afraid that Curviloft won't really help for these cases. Curviloft works on matcing vertices of contours, but has no clue of the real meaning of the geometry created. I think it is better to have a dedicated plugin (in particular for terrain contours). Maybe it already exists. Fredo
Re: [Plugin Preview] Curviloft 1.0 (Loft and Skinning)Ok Fredo,
thanks for trying out ! The sandbox is already a goog tool for terrain, but the post cleaning and the triangulation not already good needs enhencements. Regards.
The problem with one closed polyline is where do you make the 'corners' - certainly with my EEbyRails tool anyway - perhaps Fredo has a cunning plan... It's easy to make the shape you show with EEbyRails - [and almost certainly with Fredo's newer and chic tool] but you need the 2 profiles and 2 rails. I Exploded the whole polyline [Curve], Selected the pieces of the two Curves and Welded them into a profile and a rail, then Divided the two remaining lines into 12/18 Segments in turn, then Welded those into straight 'Curves' - that way the tool doesn't have to be guessing about how best to divide up uneven pairs of sides: then EEbyRails simply made the form you see, using the four pieces as two profiles and two rails... I'm sure Fredo's tool will be as capable [or better ![]() TIG
Hello Fredo6, fantastic plugin !!! and by occasion - what tool are you using to crate those beautiful small gifs videos? regards Re: [Plugin Preview] Curviloft 1.0 (Loft and Skinning)
Howard, TIG's EEbyRail can handle it well, if you split the contour into 4 pieces. Curviloft will try to manage automatically the split (in particular when you have multiple contours), but this is more tricky and I still have some issues. So, for the time being, Curviloft would use the same method as recommended by TIG. Note however that Curviloft will accept contours made of curves and / or individual edges Fredo Last edited by fredo6 on Sun May 30, 2010 1:56 pm, edited 1 time in total.
I use Camtasia Studio 7 (which has a free one-month trial period). Fredo
Re: [Plugin Preview] Curviloft 1.0 (Loft and Skinning)Wow Fredo6....amazing! Any idea when you will have this plugin ready to post? Thanks in advance, I can't wait!
Jeff Have I mentioned how much of a laugh I get out of some of the Signatures on here!
Re: [Plugin Preview] Curviloft 1.0 (Loft and Skinning)Perfect work , great plugin. I was looking for this for a long time.
Re: [Plugin Preview] Curviloft 1.0 (Loft and Skinning)Fredo / TIG,
Thanks very much for the replies from both of you. As suspected (for now) closed polylines must be broken up before processing (whichever tool is used) - but its not too painful. ...................... Keep up the good work with your EXCELLENT scripts. Hugely appreciated by all. ...................... Regards Howard L' Re: [Plugin Preview] Curviloft 1.0 (Loft and Skinning)This looks like a very powerful plugin & Im amazed at how fast things are developping. It certainly looks like it will improve the possibilities of more organic modelling.
Will this plugin be FREE or a commercial item upon release? Do you have an ETA? Does the created surface act as a normal SU surface allowing you to push pull edit vertices etc? Ive got one eye keenly focused on this development ![]() Re: [Plugin Preview] Curviloft 1.0 (Loft and Skinning)
Answer is FREE
The surface generated are pure SU, as a combination of edges and faces, encpasulated within a group. You can do whatever you like with it with all SU tools. Fredo
Amazing professional work AND great generosity. You deserve the "SU Knight" gold medal, man! I am speechless.. ![]() ![]() Re: [Plugin Preview] Curviloft 1.0 (Loft and Skinning)Dear Fredo6,
I should like to add my applause and thanks too. Your generosity is greatly welcomed by the community with is Sketchup. With all best wishes, Bob Re: [Plugin Preview] Curviloft 1.0 (Loft and Skinning)You Ruby guys never fail to amaze me.
Keep up the great work and thanks for your generosity Fredo! Mark P. Re: [Plugin Preview] Curviloft 1.0 (Loft and Skinning)![]() Re: [Plugin Preview] Curviloft 1.0 (Loft and Skinning)Fredo fantastico
![]() ![]() ![]() Now we need you in the Gulf! Re: [Plugin Preview] Curviloft 1.0 (Loft and Skinning)I will add my kudos to the long list too. It seems to me that 2010 is really shaping up to be the year of awesome plugins.
![]() Wonder, if we should do a top 10 plugins at the end of each year based on comments and downloads? ![]() Rick Re: [Plugin Preview] Curviloft 1.0 (Loft and Skinning)This should be a standard tool for SU!!! way to rock our world!
IOviz.com
SU Pro 2017 PC Thea: latest vray4SU latest Re: [Plugin Preview] Curviloft 1.0 (Loft and Skinning)
wasnt SubDivideSmooth getting a makeover ? Re: [Plugin Preview] Curviloft 1.0 (Loft and Skinning)Nice job ... it isnt possible download yet?
Re: [Plugin Preview] Curviloft 1.0 (Loft and Skinning)Thanks so much Fredo, your genius and generosity go hand in hand.
![]() Can't wait to try it out. ![]() Re: [Plugin Preview] Curviloft 1.0 (Loft and Skinning)
yes and profile builder too. “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
http://www.Twilightrender.com try it! |
