by rickgraham » Wed May 05, 2010 7:24 pm
rickgraham wrote:tak2hata wrote:Hi, Jeff and rick. I update Fur_en.rb
The WebDialog has problem in Mac OSX. So I put another menu for the correspondence of this problem. The menu named "fur!(MAC)". Using InputBox Dialog. How in this?
I cannot tell what the intended difference between the 1 - Linear and 2- Arch are. By the way, the Mac only shows 1,2,3,4 - I saw another persons screen shot which showed me what they were for. Rick
rickgraham
- Name: Rick Graham
by jeff hammond » Wed May 05, 2010 7:37 pm
- Global Moderator
- Name: Jeff Hammond
- Operating system: Mac
- SketchUp version: 2015
- License type: Pro
- SketchUp use: architecture
- Level of SketchUp: Advanced
by solo » Wed May 05, 2010 7:44 pm
Was just a matter of time until someone posted hairy balls.
- Global Moderator
- Name: solo
- Operating system: Windows
- SketchUp version: 2017
- License type: Pro
- SketchUp use: other
- Level of SketchUp: Intermediate
by xrok1 » Wed May 05, 2010 7:48 pm
i can hear all the script writers now " Why the fook didn't i think of that? , its so fookin simple too! " awsome, simply awsome!
“There are three classes of people: those who see. Those who see when they are shown. Those who do not see.” http://www.Twilightrender.com try it!
xrok1
- Name: Rocky
by rickgraham » Wed May 05, 2010 8:01 pm
xrok1 wrote:i can hear all the script writers now " Why the fook didn't i think of that? , its so fookin simple too! " awsome, simply awsome!
This is a banner day for me and SU. Rick
rickgraham
- Name: Rick Graham
by ken28875 » Wed May 05, 2010 8:26 pm
Follow Your Dreams.
ken28875
- Name: Ken Nguyen
- License type: Pro
- SketchUp use: game and/or sci-fi modelling
by thomthom » Wed May 05, 2010 8:30 pm
Mandatory:
- PluginStore Author
- Name: Thomas Thomassen
- SketchUp version: 2019
- License type: Pro
by ark » Wed May 05, 2010 8:58 pm
Absolute fantastic Somehow I can't seem to generate short hair? I set the "Lenght" to 0.0001 but the hair doesn't seem to get shorter then approx. 50 mm! It would be nice to be able to save presets!!! Great job
ark
- Premium Member
- Name: ARK
- SketchUp version: 8
- License type: Free/Make
by solo » Wed May 05, 2010 9:23 pm
Teddy fur.
Which all but choked SU to death.
- Global Moderator
- Name: solo
- License type: Pro
by minguinhirigue » Wed May 05, 2010 9:34 pm
Really nice one I missed from a long time...  Thanks.
minguinhirigue
- SketchUp version: 2013
by Mike Lucey » Wed May 05, 2010 9:59 pm
Thanks tak2hata, I can see this plugin becoming a great favorite Mike
Mike Lucey
- Mayor
- Name: Mike Lucey
- SketchUp version: 2021
- License type: Pro
by utiler » Wed May 05, 2010 11:31 pm
No way!! Now I can see what a woman looks like with a beard.
purpose/expression/purpose/....
utiler
- Top SketchUcator
- Name: Andrew
- License type: Pro
by Whaat » Thu May 06, 2010 3:25 am
Great plugin! Thanks for sharing!
Whaat
- Name: Whaat
- License type: Pro
by CadFather » Thu May 06, 2010 8:36 am
Just when you think you've seen it all.. tak2hata comes along with another great idea...thanks!
CadFather
- Name: CadFather
- SketchUp version: 2014
- License type: Pro
- SketchUp use: landscape architecture
by tomasz » Thu May 06, 2010 8:55 am
Hi, Thanks a lot for such an interesting plugin! tak2hata wrote:Creating Too Much Polygon is very slow. And to use code "entities.fill_from_mesh" must need blank Group. This Plugin executes each selected faces. Creating Group each new 800 polygons. so it parts.
I have a request as a developer. Can you add an option to attach a fur parameters to a SU material as attributes. Multiple exporters to rendering programs could call your plugin to receive info on location and parameters of the fur. Instead of choking SU, an exporter would get the geometry info (EDIT: transformations of components) from your plugin and translate it into the rendering program entities, without creating it inside SU. Would it be possible? Cheers Tomasz
tomasz
- SU2TH & SU2KT Developer
- Name: Tomasz Marek
- License type: Pro
by CadFather » Thu May 06, 2010 8:59 am
yes please..
CadFather
- Name: CadFather
- License type: Pro
by thomthom » Thu May 06, 2010 9:18 am
Tomasz wrote:I have a request as a developer. Can you add an option to attach a fur parameters to a SU material as attributes. Multiple exporters to rendering programs could call your plugin to receive info on location and parameters of the fur. Instead of choking SU, an exporter would get the geometry info from your plugin and translate it into the rendering program entities, without creating it inside SU.
Oooh! Good idea. Keep all data as attributes per face. And use simple lines (in reduced numbers) to represent the fur.
- License type: Pro
by notareal » Thu May 06, 2010 9:36 am
Cheers Tomasz
That would be great!
notareal
- Thea Render Support
- Name: notareal
by olishea » Thu May 06, 2010 10:03 am
one of the best plugins around!! i'm making everything furry! render cooking
oli
olishea
- Premium Member
- Name: olishea
by tomasz » Thu May 06, 2010 10:05 am
I am testing the plugin and have noticed that it doesn't take an area of a triangle into account. It think it won't be that hard to fix.
tomasz
- License type: Pro
by thomthom » Thu May 06, 2010 10:18 am
That's probably because of MaxNumber(/Face) setting you have set. The Dencity(Num/m2) appears to deal with the area, but larger faces needs more fur, so you need to increase the MaxNumber.
- License type: Pro
by olishea » Thu May 06, 2010 10:34 am
so much fun!! would be nice if there was a "set defaults" button....and if it remembered your settings between tweaking. would also be good if the grass was automatically placed on a new layer so you can quickly turn it off or on....you could render the scene without the geometry even being present. Sketchup view of an old model of mine:
oli
olishea
- Premium Member
- Name: olishea
by tridem » Thu May 06, 2010 11:05 am
one more THANK YOU ...and one more request  in such a tool it's usefull having the Esc key available, to stop the process if it take too long than expected
tridem
- Name: Luca
by thomthom » Thu May 06, 2010 11:11 am
tridem wrote:...and one more request  in such a tool it's usefull having the Esc key available, to stop the process if it take too long than expected
That is easier said than done. It's difficult to get any key press events while scripts are running. Though I thing Fredo has some feature like that...
- License type: Pro
by massimo » Thu May 06, 2010 11:34 am
Really funny thank you tak2hata!
massimo
- Name: Massimo Siracusa
- License type: Pro
by KarinaGM » Thu May 06, 2010 11:38 am
Wow! Amazing tool. I've just downloaded it and can't wait to start (playing) experimenting
THANKS!
"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminará perdiendo ambas"
-Benjamín Franklin.
KarinaGM
- Name: Karina
by tridem » Thu May 06, 2010 12:48 pm
thomthom wrote:.. Though I thing Fredo has some feature like that...
I believe so... eg 'round corner' can do it
tridem
- Name: Luca
by tak2hata » Thu May 06, 2010 1:58 pm
I updated the plugin. it's version 1.0.
I saw some requests now. It seems to be difficult in my skill. Hereafter, I will study Ruby more.
----------- by TAK2HATA
tak2hata
- Name: tak2hata
- License type: Pro
by thomthom » Thu May 06, 2010 2:25 pm
tak2hata wrote:I updated the plugin. it's version 1.0.
 Yea, you've started something.  If you need help with anything just ask at this forum, people are happy to help.
- License type: Pro
by olishea » Thu May 06, 2010 2:26 pm
beautiful plugin. I placed the grass on hidden layer and replaced the component with a single line. Then rendered in twilight using "render all hidden layers" option. so each line represents blade of grass. close up of components
twilight render
oli
olishea
- Premium Member
- Name: olishea
by Ad Machine » 5 minutes ago
Ad Machine
- Robot
Return to Plugins
