[Plugin] Make Fur v.2.1.0(20140323)
Postby tak2hata » Wed May 05, 2010 8:55 am
Hello ,All.
This Plugin is Fur Maker.
It is convenient to glowing grass etc.
How To Use: Select Menu From "PLUGINS"-"Fur_EN"
I am not good at English.So Please look at the appended image.
NOTICE::This plugin make too much polygons so model will be large size.(Worst case It can not open.)Please use carefully.
General disclaimer
I MAKES NO GUARANTEE OF VALIDITY about this script.
Please use this script at your own risk.
DOWNLOAD HERE
Get the latest version from the PluginStore:
http://sketchucation.com/resources/plug ... pln=fur_en
or AutoInstall from within SketchUp using the SketchUcation Tools
Versions:
Since : 2010-04-21--- v0.0
....many revisions...
Rev : 2010-0624 -- v1.4c(test webdialog for mac)
    fixing webdialog problem on mac os.
    (referred to forum "[Web dialog] switch snippet for pc / mac" and jim's "protrude.rb")
    Russian translation by blajnov(Thanks) :D
Rev : 2010-0625 -- v1.4d(Test2 webdialog for mac)
    I wish this work on mac.Thanks Oxer and Mario.
Rev : 2010-0625 -- v1.4e
    Remove from context menu.
    "Crowd" Problem on mac do not fix yet.
Rev : 2010-1028 -- v1.5a
    Add preview button.(preview only points of density.)
    in the case of using Inputbox,
    first ,preview points,Press Enter or select "make fur" from context menu.
    Width of some buttons in webdialog increased.
    "Preview Fur"and"Back to Dialog" added to translation word
    I change filename to "fur_en.rb".
    remove older fur rubys from plugins folder.
    fur_lang_**.txt is parameter name translate.
    the usage like this.
    Density|DENSITY
    Length|LENGTH
    This converts "Density" to "DENSITY".
    language translate file copy to sketchup plugins directory.
    If language file is not exist in plugins dir,then parameter name do not rewrite.
    and select it from menu.
Rev : 2013-06-02-- v2.0.1
Rev : 2014-03-23-- v2.1.0 : Bugfix.Slider did not work when units are "inch" or "feet".
    Fit to Extension class.
    Improve UI.
    Add function "edit preset list"
    Add function "select language file"
    Including language files.
Rev :2013-0602-- v2.0.2
    include language file for persian by majid.Thanks!
Rev :2013-0602-- v2.0.3
    include language file for czech by pepa.Thanks!
Rev :2013-0602-- v2.0.4
    UI Slider value optimized when units is not "mm".
Rev :2013-0608-- v2.0.5
    include language file for Spanish by Oxer.Thanks!
    include new language file for Chinese by hebeijianke.Thanks!
Rev :2013-0612-- v2.0.6
    include language file for Serbian by srx.Thanks!
Tutorial Video
Spanish translation by Oxer.http://forums.sketchucation.com/viewtopic.php?f=323%26amp;t=28092%26amp;start=210#p247640
Franch translation by Daredevilhttp://forums.sketchucation.com/viewtopic.php?f=323%26amp;t=28092%26amp;start=195#p247400
Persian translation by Majidhttp://forums.sketchucation.com/viewtopic.php?f=320%26amp;t=28179
Viet nam translation by ktslambieng(100608updated)http://forums.sketchucation.com/viewtopic.php?f=323%26amp;t=28092%26amp;start=300#p250660
Portuguese-BR (Brazil) translation by Paulower.http://forums.sketchucation.com/viewtopic.php?f=323%26amp;t=28092%26amp;start=285#p249923
Chinese translation by hebeijianke.http://forums.sketchucation.com/viewtopic.php?f=323%26amp;t=28092%26amp;start=300#p250314
Russian translation by blajnov.http://forums.sketchucation.com/viewtopic.php?f=323%26amp;t=28092%26amp;start=315#p253618
German translation:Thanks Burkhard.http://forums.sketchucation.com/viewtopic.php?f=323%26amp;t=28092%26amp;start=330#p255389
Czech translation:Thanks Pepa.http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=28092%26amp;start=480#p478540
Serbian translation:Thanks Srx.http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=28092%26amp;start=480#p480168
Zieios makes New ICON for fur.Thank you very much!
Fur grown Very Thick!
http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=28092%26amp;p=478541#p473352
How to Use.
add crowd mode.
20
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Re: [Plugin] Make Fur
Postby pilou » Wed May 05, 2010 9:21 am
Seems very cool! :enlight:
Speedy Galerie
User avatar
Top SketchUcator
Postby thomthom » Wed May 05, 2010 9:26 am
Hey! Welcome to SCF.
Very nice plugin.
Got a couple of comments:
It does not create the grass in the active context. If I open a group or component and select faces it does not add the grass to that group. By design?
Why are there so many Groups generated? To cut down generation time? Just find it a bit odd that a patch will have grass in multiple locations:
As for the grass - would it be an idea to make each grass straw a component, and then use scaled and skewed instances of that strand?
5
User avatar
PluginStore Author
PluginStore Author
Postby tak2hata » Wed May 05, 2010 10:00 am
Thank you for using this plugin.
Sorry, I will change to create in the active context
Yes.
Creating Too Much Polygon is very slow.
And to use code "entities.fill_from_mesh" must need blank Group.
This Plugin executes each selected faces.
Creating Group each new 800 polygons.
so it parts.
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Postby thomthom » Wed May 05, 2010 10:14 am
Yea - creating geometry slows down as more entities are in the context you add to - I've noticed that myself.
But would it be faster to make each grass strand to be a ComponentInstance of a single ComponentDefinition? That way one can easily edit the grass afterwards as well.
User avatar
PluginStore Author
PluginStore Author
Postby tak2hata » Wed May 05, 2010 10:29 am
It is nice idea !
I will examine it.
I think that time hangs for a moment to change this plugin.
thanks.
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Postby meak » Wed May 05, 2010 1:47 pm
:berserk: :ecstatic: :sketchstatic:
cool plugin
thanks, thanks,thanks.
+1 componentinstance! :mrgreen:
meak
Postby EarthMover » Wed May 05, 2010 2:28 pm
Nice! Autograss for sketchup!
Thomthom, is there is a simple code fix that we could implement to have the blades made as component instances, or does that involve some rewriting?
Content Creator at Skapeup
User avatar
EarthMover
Premium Member
Premium Member
Postby thomthom » Wed May 05, 2010 2:34 pm
Dunno - haven't looked at the code.
User avatar
PluginStore Author
PluginStore Author
Postby xrok1 » Wed May 05, 2010 3:05 pm
thats pretty sweet! thank you. :ecstatic:
xrok1
Postby EarthMover » Wed May 05, 2010 3:16 pm
Nice render results...great job with the UI!
I guess one could also just use the plugin to create a small patch of grass, convert it to a component and then spray it into the areas needed.
User avatar
EarthMover
Premium Member
Premium Member
Postby thomthom » Wed May 05, 2010 3:34 pm
Suggestions:
Make the type box and Option box.
I like that it inherits the colour of the face it sits on. An nice option would be if it could generate a given set of material variants (0 to n) and use that.
User avatar
PluginStore Author
PluginStore Author
Postby xrok1 » Wed May 05, 2010 3:56 pm
8-) this is greaaaat!
xrok1
Postby rickgraham » Wed May 05, 2010 4:05 pm
Umm my dialog box for furmaker is blank. :?:
Rick
rickgraham
Postby thomthom » Wed May 05, 2010 4:06 pm
xrok1 wrote:8-) this is greaaaat!
Nice patch. Is that just one plain colour for the grass?
User avatar
PluginStore Author
PluginStore Author
Postby solo » Wed May 05, 2010 4:07 pm
:shock:
This looks interesting....
Thanks mate.
I'm better with polys than words
User avatar
Global Moderator
Postby thomthom » Wed May 05, 2010 4:17 pm
solo wrote::shock:
Thanks mate.
Render comp?? :D
User avatar
PluginStore Author
PluginStore Author
Postby xrok1 » Wed May 05, 2010 4:26 pm
ground cover>Vegetation_Grass1
xrok1
Postby jeff hammond » Wed May 05, 2010 4:36 pm
rickgraham wrote:Umm my dialog box for furmaker is blank. :?:
Rick
same here..
no fur for osx :|
User avatar
Global Moderator
Postby Ben Ritter » Wed May 05, 2010 5:57 pm
Quite fun to play around with. Thank you so much.
Could you provide a brief description of each setting. Some are painfully obvious, others not so much, for me at least.
Ben
Ben Ritter
Postby rickgraham » Wed May 05, 2010 6:12 pm
Rick
same here..
no fur for osx :|
Wonder how hard it would be to make it Mac-friendly? This looks like something that would have great benefit for myself and my line of work.
Rick
rickgraham
Postby xrok1 » Wed May 05, 2010 6:14 pm
hmmm! :D
would be nice to be able to pre-select the material though. i had to paint the branches green and then back to brown after.
xrok1
Postby SU Reviewer » Wed May 05, 2010 6:24 pm
Great Plugin! I'm in the process of reviewing it for my site. But I keep running into an issue, whenever I select my settings and then click the "Fur" button it creates the fur on the wrong side of the face. Always facing down. Is there a way to fix this?
Thanks for your efforts!
Living Einstein's dream through SketchUp.
"Imagination is a preview of life's coming attractions" - Albert Einstein
Joe Simhon ~ SketchUp Plugin Reviews
SU Reviewer
Postby solo » Wed May 05, 2010 6:26 pm
Make sure your face is orientated correctly.
User avatar
Global Moderator
Postby tak2hata » Wed May 05, 2010 6:30 pm
Hi, Jeff and rick.
I update Fur_en.rb
The WebDialog has problem in Mac OSX.
So I put another menu for the correspondence of this problem.
The menu named "fur!(MAC)".
Using InputBox Dialog.
How in this?
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Postby thomthom » Wed May 05, 2010 6:39 pm
SU Reviewer wrote:Great Plugin! I'm in the process of reviewing it for my site.
Very nice site. I've not seen it before. New?
User avatar
PluginStore Author
PluginStore Author
Postby dale » Wed May 05, 2010 6:53 pm
Yes, Wow thanks for this. I got a feeling some real interesting things will happen with this plugin.
User avatar
dale
Top SketchUcator
Postby xrok1 » Wed May 05, 2010 7:03 pm
how can we access the component instance option? also did you consider the color preselect or a don't copy material option?
also if it would remember settings from 1 usage to the next would be great. a drop down with saved presets would be even better. :oops:
xrok1
Postby rickgraham » Wed May 05, 2010 7:07 pm
tak2hata wrote:Hi, Jeff and rick.
I update Fur_en.rb
How in this?
Works great now, many thanks!
If I can make one little suggestion - I'm not sure if the PC guys are the same or not, but when the dialog box comes up, it is right in the middle of the screen and I have to move it each time. Is there a way to have come in some place other than center? And I would love to see documentation of what the various controls do.
Again, thanks for the great plugin.
Rick
rickgraham
Postby xrok1 » Wed May 05, 2010 7:20 pm
i knew i should have popped that before it got out of hand! :shock:
who would have ever imagined fur for SU????????????????????????????? :sketchstatic:
xrok1
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Next
Return to Plugins
Who is online
Users browsing this forum: Gioarquitect, Majestic-12 Bot and 8 guests
Visit our sponsors:
