[Plugin] extrudeEdgesByLathe
• Page 3 of 4 • 1, 2, 3, 4
Re: [Plugin] extrudeEdgesByLathe v2.1Here's v2.1, with the ES lingvo file updated by Defisto.
viewtopic.php?p=184477#p184477 TIG
Re: [Plugin] extrudeEdgesByLathe v2.2Here's v2.2 - a typo preventing the Plugins Menu item working has been corrected.
![]() viewtopic.php?p=184477#p184477 TIG
Re: [Plugin] extrudeEdgesByLathe v2.3Here's v2.3 - FR lingvo file updated by Pilou...
Re: [Plugin] extrudeEdgesByLathe v2.3Feedback:
The Plugins Dropdown Menu commands for the extrusion suite appear to be operational with your latest revisions. Thank you, again. I take the slow, deliberate approach in my aimless wandering.
Re: [Plugin] extrudeEdgesByLathe v2.3Here is Chinese lingvo file by me from http://www.SuBlog.net
Re: [Plugin] extrudeEdgesByLathe v2.3Arc
Thank you. I shall include it in the next update - meanwhile any Chinese users can download it now and unzip it into their ../Plugins/TIGtools/ folder. I note you have called it 'extrudeEdgesByLatheCN.lingvo' BUT I think it should be 'extrudeEdgesByLatheZH-CN.lingvo' ? I think locale for a Chinese PC is ZH-CN ? If it is then the file needs renaming to suit that: otherwise the locale test won't find it and the text will default to English[US]... To check this please type [or copy/paste] in the Ruby Console Sketchup.get_locale.upcase, for you it should return ZH-CN ? For me it'd be EN-US. Whatever it returns is what the 'suffix' on the file name should be... Thanks for the help ![]() TIG
Re: [Plugin] extrudeEdgesByLathe v2.3Request
"A zoom extents" before the first dialog box for have all the object on the screen for an more easy answer ![]() (or a zoom wkindow of the generated object) Maybe the same for the other EEb...
It's not auto use extrudeEdgesByLatheZH-CN.lingvo file. I usually change the filename and overwhite extrudeEdgesByRailsEN-US.lingvo file. Re: [Plugin] extrudeEdgesByLathe v2.3
Aha ! ![]() That way you can even have a EN-US locale but with Chinese text... I know Pilou does that with the FR version... However if you have your locale set to something other than EN-US then any lingvo file in your desired language needs to be named ScriptNameLOCALE.lingvo where LOCALE= your-locale code obtained from using Sketchup.get_locale.upcase in the Ruby Console. This way you can have an EN-US locale but map your desired language lingvo files using that suffix... then you can use SUp even in Esperanto [EO] if you have a translation ! ![]() TIG
I thought of that but as you can orbit whilst picking the curves you CAN ensure you can see everything before committing to it... One of my longer term plans is/was to add a combined web-dialog to the end so you could still orbit/pan/zoom to view the mesh and change the settings and when satisfied press OK... ![]() TIG
Re: [Plugin] extrudeEdgesByLathe v2.4Here's v2.4 - FR lingvo file update by Pilou.
Re: [Plugin] extrudeEdgesByLathe v2.4hey Tig,
here's a request for the lathe tool to tuck away for those rainy days ![]() your extrusion suite has radically changed the way i model in SU as i very rarely use the followme tool anymore.. lathe pretty much fixes the multiple problems i encounter with ![]() anyway, the only problem i have with lathe.rb is when i'm trying to rotate to an approximate degree (ie - ~74° etc.).. would it be possible to incorporate a protractor of sorts that can measure the actual angle instead of typing it in? (see attached skp for example situation) thanks! dotdotdot
Re: [Plugin] extrudeEdgesByLathe v2.4As you know [sssh
![]() ![]() TIG
sweet! i do have a decent workaround for now that still gives me the accuracy i'm after so i'll just wait patiently (with fingers crossed ![]() dotdotdot
Re: [Plugin] extrudeEdgesByLatheHi Tig. excellent update.
I attach the file to Spanish translation. add the missing lines. Two suggestions: - Please delete the sound it makes when we choose the tool. is very annoying. - The command Ctrl + z does not work properly. - Would be more practical angle by reference to generate 0 to 360. instead of 0 to 180 and 180 to 360
Re: [Plugin] extrudeEdgesByLatheviewtopic.php?p=184477#p184477 is the latest version with new lingvos.
I posted the new ES lingvo file before I read this - can you please read it and [re]advise... The 'beep' sound it makes is a UI.beep - edit the file and find that line in the code and add a # at the start of the line to stop it loading. It is not Ctrl+Z for the angle-direction 'toggle' - it's <Ctrl> alone... I know it would be better to have 0 to 360 degrees... BUT its coding has missed me so far - hence the 0-180 & 180-360, with a toggle <Alt>... TIG
Re: [Plugin] extrudeEdgesByLatheI didn't read the 6 pages prior so if this is already covered I apologise...
Attached is a .skp that Lathe removes faces from when 'Remove Co-Planar edges is chosen? No Ruby Console messages There's a frontroom and a backroom....reverse faces
Interestingly, when I tested it I got 6+ more facets erased! I know why it's happening... When you test for coplanar-ness you look at the face normals. You erase edges that bound a pair of faces with the same normals. However, it was realized by @last/Google that this doesn't always work... You can have two faces that will heal into one if there common edge is erased BUT they won't return the same normal ! The tiniest variation in the normal would prevent that... It's all down to tolerances of how SUp works out face normals etc that are really 'equal'... In Line#755 it says ...e.faces[0].normal.dot(e.faces[1].normal) > 0.99999999999 - i.e. it's almost one! If I add/subtract an extra 9 on the end it's even worse?? My own separate 'erase_coplanar_edges' tool uses 0.99999999 and that fails too... but with only two faces lost that time! But if I try to use its 0.9999999 test in EEbyLathe it'll still knack up... So... it's not an error just one of the limitations of the tolerances that crop up when you have managed just to get some 'not quite' coplanar faces and try to remove some 'not quite' coplanar edges... If it knacks up then all you can do is to undo it one step back to keep coplanar edges - try other coplanar fixing tools and report back... OR just learn to love them... otherwise try to make forms that don't mess with SUp's head ![]() TIG
Re: [Plugin] extrudeEdgesByLatheThere is a minor correction to this tool so the 'db' translation for the 'start_operation' is now done correctly - there is also an updated ES lingvo file - thanks to deFisto...
Re: [Plugin] extrudeEdgesByLatheHi TIG,
This is another great one, including the control it gives on the angle etc. However I have a project in which I want smooth edges for the curved faces but not along the flat faces that result. So I wonder if this is the wrong tool and you have other suggestions. I have attached a file if you are interested. Given the work to create this otherwise (create full circle and cut with intersections), it may not be too much to smooth all the edges "manually". This is only a prototype for a coming project which will probably be drawn many times in design, so I am seeking the best method. Just seeing if I am using the right tool or using it correctly. Thank you for the plugin and, of course, anyone can chime in. Peter Last edited by pbacot on Sat Oct 22, 2011 11:01 pm, edited 1 time in total.
MacOSX Mojave High Sierra SketchUp Pro v19 Twilight v2 Thea v2 PowerCADD
Re: [Plugin] extrudeEdgesByLatheNo file attached
![]() It's relatively simple to select all and smooth/unsmooth. Use Hidden Geometry ON to see what's happening It's also relatively simple to do it to a selection. You can also use a selection of edges and Entity Info to uncheck smooth/soft [and hidden] settings for edges. The tool produces smoothed-edges if desired. I'm not sure what you are trying to do that it doesn't do OR what isn't easy to do by hand later ??? TIG
Re: [Plugin] extrudeEdgesByLatheThe file is attached. I see it there. I reloaded and perhaps you viewed in the moment that I did that.
The edges I need to smooth are many and selection would need to be almost one by one, to not get the wrong edges. If this is best way, so be it. If I create many versions of this model, I want to be more efficient if I can. Also I should say, look at both scenes. Thanks, Peter MacOSX Mojave High Sierra SketchUp Pro v19 Twilight v2 Thea v2 PowerCADD
Re: [Plugin] extrudeEdgesByLathe^
i always have problems with the smooth option as well (as in, it smooths everything) choose no for smooth then select the group and smooth is via the soften/smooth dialog dotdotdot
Re: [Plugin] extrudeEdgesByLatheYes, Jeff the smooth option smooths every edge--too much here.
I got it, I think! Using this tool and ThomThom's Selection Toys to quickly select those edges I need to smooth. MacOSX Mojave High Sierra SketchUp Pro v19 Twilight v2 Thea v2 PowerCADD
Re: [Plugin] extrudeEdgesByLatheOK, now I see the issue.
You want yes to smooth? not to smooth every edge - for example leave those with only one face or two faces at right-angles of sharper ? TIG
Re: [Plugin] extrudeEdgesByLatheUpdated v3.4 so it now only smooths edges with more than one face.
Who is online
Users browsing this forum: spoon2384 and 18 guests
