[Plugin] Center of Gravity
Postby TIG » Wed Mar 03, 2010 2:57 pm
Usage and Download from the PluginStore
Download
3
User avatar
Global Moderator
Re: [Plugin] Center of Gravity
Postby TIG » Wed Mar 03, 2010 3:17 pm
Here's a Composite C of G, made from the three stone detailing pieces assembled - useful if they are of differing density materials and to be fixed together off site and then handled/lifted on site...
[Original CofG's hidden for clarity]
User avatar
Global Moderator
Postby TIG » Wed Mar 03, 2010 4:08 pm
Here's v1.1 viewtopic.php?p=229401#p229401
Accuracy improved.***
CompoCofG description improved.
***The shape is now sampled at 0.5% of its height.
So if it's 1000mm high that is at 5mm c/c* - this should pick up most fine detail ins and outs in its section.
Ins and outs in plan are picked up anyway.
If you do have a weird shape that's say 'combed' in the vertical at very close centers* then you could turn the shape on its side to get an even more accurate CofG... BUT 99% of the time the default analysis will be sufficient - within a 'mm' or so - considering the variability of natural materials' densities I'd say that "sufficient is fit"...
:geek:
User avatar
Global Moderator
Postby MALAISE » Wed Mar 03, 2010 7:12 pm
Interesting plugin, as far as I can use it in SketchyPhysics.
Thx TIG
MALAISE :thumb:
User avatar
MALAISE
Postby TIG » Wed Mar 03, 2010 7:50 pm
It was actually made after a request by someone making historical stonework detailing. They needed to find the top Suspension-Point to add a lifting-eye so the delicate pieces can be lifted squarely and simply and bedded in place...
For that you need the Center of Gravity which gives you six axial SP's...
:ugeek:
User avatar
Global Moderator
Postby Dave R » Wed Mar 03, 2010 7:52 pm
Very nice TIG. I didn't know I needed this plugin until now. Thanks. :thumb:
User avatar
Global Moderator
Postby alexschreyer » Wed Mar 03, 2010 10:31 pm
Thanks, TIG, for expanding into the third dimension. This is a great plugin.
Cheers, Alex
Author of "Architectural Design with SketchUp":
http://sketchupfordesign.com/
User avatar
alexschreyer
PluginStore Author
PluginStore Author
Postby honoluludesktop » Wed Mar 03, 2010 10:33 pm
Wow, SU as a structural engineering engine?
User avatar
honoluludesktop
In Remembrance
Postby utiler » Thu Mar 04, 2010 12:49 am
Dave R wrote:Very nice TIG. I didn't know I needed this plugin until now. Thanks. :thumb:
Like Dave, I didn't think i needed this until now.... Looks neat TIG!!
purpose/expression/purpose/....
User avatar
utiler
Top SketchUcator
Postby mitcorb » Thu Mar 04, 2010 1:24 am
This item could be very handy. Thank you.
User avatar
mitcorb
Top SketchUcator
Postby jonorman » Thu Mar 04, 2010 11:19 pm
I am out off words. This is a plugin I`ve been waiting but thought never would come.. I`m so greatfull :berserk:
jonorman
Premium Member
Premium Member
Postby pilou » Fri Mar 05, 2010 5:41 pm
Damned another very cool tool for ingeniery :enlight:
Speedy Galerie
User avatar
Top SketchUcator
Postby watkins » Fri Mar 05, 2010 6:25 pm
Forgot to say that TIG's volume calculator (+ density) and CofG calculator give you the complete story when reviewing loads.
watkins
Postby DSG2k » Sun Mar 07, 2010 11:06 am
Vista and SketchUp 7.1.6860 . . .
Unzip of CoG plugin zip in the plugins folder resulted in a lot of overwrite requests (I just got your Manifold, too). I overwrote the older deBabelizer with the newer one.
Now on load a "Load Errors" window pops up, saying:
Error Loading File CofGravity.rb
undefined method `deBabelizer' for main:Object
And the plugin does not appear in the Plugin menu.
I don't know Ruby so I didn't actually poke at anything in the code, nor did I see anything obvious to me.
Just FYI.
DSG2k
Postby TIG » Sun Mar 07, 2010 11:23 am
Have you got a file called deBabelizer.rb in the Plugins folder.
If not then please put a copy of it in there***.
You must extract all of the files and sub-folders in a zip file keeping their sub-folders etc.
A good unzip application will do that for you.
Moving files manually leads to problems as they end up in the wrong place.
Unzipping directly into Plugins can cause problems as files seemingly overwritten are not !***
With Vista you are probably best firstly extracting everything into a folder on your Desktop [e.g. 'CofG_1.1'] and then use copy/paste on all of that folder's contents [unchanged], en mass into the Plugins folder...
***You are on Vista so I suspect you have some access-right problems with your Plugins folder :roll: :?:
The dreaded 'compatibility files' issue - it looks like you put the file into the folder but Vista 'protects you' by putting it into a parallel 'compatibility folder' so you don't actually get to find it, load it etc as it's not really there...
So I recommend you change the access-rights to the folder [properties] so you can write to it without problems...
The deBabelizer.rb file issued with all tools is the same file - you only need one copy in Plugins for any tool that uses it to load and to use it...
:geek:
User avatar
Global Moderator
Postby Gaieus » Sun Mar 07, 2010 3:03 pm
Hm. This is a very interesting piece of plugin, TIG; thanks!
It immediately brings teaching into my mind - as how you can (for instance) explain the different vectors arising in a Gothic structure for instance. It would be (also) interesting to see how these centers of gravity can interact with each other after a structure is assembled.
User avatar
Postby pilou » Sun Mar 07, 2010 3:53 pm
Why not put the Xray mode at the end of the process?
Because we can't see the CofG when this one is inside a volume ;)
Pilou
Speedy Galerie
User avatar
Top SketchUcator
Postby TIG » Sun Mar 07, 2010 9:35 pm
Here's v1.2 viewtopic.php?p=229401#p229401
with FR lingvo file by Pilou...
User avatar
Global Moderator
Pilou wrote:Why not put the Xray mode at the end of the process?
Pilou
You can't set Xray mode on your own ?
Many want just the top SP for lifting, and the weight - so CofG is secondary...
If you want it then you can Xray it...
Sorry if I sound cranky... long week and tomorrow's Monday [aaargh!] ;)
Vous ne pouvez pas définir le mode Xray sur vos propres?
Beaucoup veulent juste le SP haut pour le levage, et le poids - donc CofG est secondaire ...
Si vous le souhaitez vous pouvez le Xray ...
Désolé si j'ai l'air grognon ... longue semaine et demain lundi [aaargh!];)
User avatar
Global Moderator
Postby TIG » Sun Mar 07, 2010 9:41 pm
Gaieus wrote:Hm. This is a very interesting piece of plugin, TIG; thanks!
It came from a PM request for a tool to find the perfect lifting point for a delicate piece of restoration stonework...
I added the composite tool to combine the CoG's and SP's of assembles of multiple or varying density units...
Any more ideas welcome... :?
User avatar
Global Moderator
Postby pilou » Sun Mar 07, 2010 10:59 pm
No problem i can make the Xray mode by hands ;)
Another thing
Seems "Composite mode" don't works for me :o
object goup 1(without CoF), object goup 2(without CoF),
group 3 = Group1 + Group 2
Find Cof for group3 ok :enlight:
object goup 1(with CoF), object goup 2(with CoF)
Composite group 3 not Ok :(
What I miss?
Speedy Galerie
User avatar
Top SketchUcator
Postby TIG » Mon Mar 08, 2010 11:27 am
'Composite C of G' is for use only on existing C of G elements - it's used to get a combined C of G for them.
If you have an assembly of parts that all have the same density then you can just make one group of all of them and find the C of G of that one group.
BUT if you have an assembly of parts of different densities you'll need to find the individual C of G's of each of them: then you select these C of G elements [only these, nothing else] and use the Composite C of G tool on them.
You only need to use the Composite C of G tool on the C of G's of parts with different densities that could unexpectedly relocate the assembly's C of G - 'off center' for example... Otherwise group and get the one C of G...
User avatar
Global Moderator
Postby pilou » Mon Mar 08, 2010 11:32 am
haaaaaaaa :enlight:
THX! :fro:
Speedy Galerie
User avatar
Top SketchUcator
Postby chrisjk » Mon Mar 08, 2010 12:55 pm
I can't seem to get it to do anything on a Mac..
chrisjk
Premium Member
Premium Member
Postby TIG » Mon Mar 08, 2010 1:46 pm
chrisjk wrote:I can't seem to get it to do anything on a Mac..
Please explain a little more...
What can't you get to work ?
Open the Window > Ruby Console.
Select a group or component instance that has a volume - we are trying to find it's C of G !
Run the tool and answer the dialog's questions...
What happens / doesn't happen ?
What are the messages if any in the Ruby Console...
There is nothing different between a PC and a Mac for this tool [except 'PEBCAK' ;) ]
User avatar
Global Moderator
Postby driven » Mon Mar 08, 2010 2:08 pm
Error: #<NoMethodError: undefined method `db' for CofGravity:Class>
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/CofGravity.rb:153:in `calculate'
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/CofGravity.rb:813
driven
PluginStore Author
PluginStore Author
Postby Dave R » Mon Mar 08, 2010 2:15 pm
I just installed it on my MacBook and tried running it. It worked fine for me. Thank you TIG.
User avatar
Global Moderator
Postby TIG » Mon Mar 08, 2010 2:27 pm
driven wrote:Error: #<NoMethodError: undefined method `db' for CofGravity:Class>
Have you got deBabelizer.rb in the Plugins Folder ?
This file is for translation and is used by many of my tools and it ships with each of them - although it's always the same file...
It should come with the zip and is installed into the same folder as CofGravity.rb ?
The error is because 'db' which is the local def of deBableizer in the class is failing to get defined...
User avatar
Global Moderator
Postby driven » Mon Mar 08, 2010 3:15 pm
TIG wrote:Have you got deBabelizer.rb in the Plugins Folder ? :?
Hi Tig,
I only installed it to send you a report from another Mac, and am sure I used all of the correct instal procedures.
your other tools are still working (EEby.., Manifold, Vol..2) , after the CofG_1.2 instal (including deBalelizer.rb)
after the first (_1.2) Error, I replaced both files with the _1.1 files and had the same error.
I then tested all in the same drawing
EEby Rail--worked
Volume2 --worked
Manifold --worked
CofG --same error report (-1.2 re-installed from zip)
driven
PluginStore Author
PluginStore Author
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Next
Return to Plugins
Who is online
Users browsing this forum: Augrid, Drumatik, endlessaffection, Getz2007, reisfedr, velasanz, ZHTing and 15 guests
Visit our sponsors:
