[Plugin] Manifold v2.2
Re: [Plugin] Manifold v1.4
Postby Jim » Wed Jan 27, 2010 5:38 pm
What does the word "manifold" mean in this context? I gather "water-tight", but is it more than that?
Jim
Global Moderator
Postby driven » Wed Jan 27, 2010 6:05 pm
Jim wrote: but is it more than that?
Yes , and tons of info at wikipedia, but the way I described to my six year old if the computer trying to find the walls of a room from the inside and the window is open it will precede to circumnavigate the earth until it gets back to where it started and then panic... she believed me...
driven
PluginStore Author
PluginStore Author
Postby TIG » Wed Jan 27, 2010 6:08 pm
Jim wrote:What does the word "manifold" mean in this context? I gather "water-tight", but is it more than that?
Manifold means 'many' or 'of many parts' - it's also a type of thin typing paper !
But in the sense of a 3D mesh it means 'whole', 'complete', 'imperforate', 'without holes, imperfections, complexities or sub-elements'... from the Mathematical term "Manifold: a Topological surface or space that is connected and locally Euclidean"...
Ironically its 'antonym' is 'simple or single', which is exactly what we are trying to achieve with the processed mesh !!!
User avatar
Global Moderator
Postby driven » Wed Jan 27, 2010 6:11 pm
TIG, no dialogs and I get this that I haven't had before,
27/01/2010 16:26:58 [0x0-0x6f06f].com.google.sketchupfree7[925] #<NoMethodError: undefined method `flattenUVQ' for #<Manifold:0x1e6005a4>>
27/01/2010 16:26:58 [0x0-0x6f06f].com.google.sketchupfree7[925] /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/manifold.rb:580:in `triangulateFace'
27/01/2010 16:26:58 [0x0-0x6f06f].com.google.sketchupfree7[925] /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/manifold.rb:574:in `each'
27/01/2010 16:26:58 [0x0-0x6f06f].com.google.sketchupfree7[925] /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/manifold.rb:574:in `triangulateFace'
27/01/2010 16:26:58 [0x0-0x6f06f].com.google.sketchupfree7[925] /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/manifold.rb:621:in `triangulate_faces'
27/01/2010 16:26:58 [0x0-0x6f06f].com.google.sketchupfree7[925] /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/manifold.rb:619:in `each'
27/01/2010 16:26:58 [0x0-0x6f06f].com.google.sketchupfree7[925] /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/manifold.rb:619:in `triangulate_faces'
27/01/2010 16:26:58 [0x0-0x6f06f].com.google.sketchupfree7[925] /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/manifold.rb:112:in `activate'
27/01/2010 16:26:58 [0x0-0x6f06f].com.google.sketchupfree7[925] /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/manifold.rb:701:in `select_tool'
27/01/2010 16:26:58 [0x0-0x6f06f].com.google.sketchupfree7[925] /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/manifold.rb:701:in `manifold'
27/01/2010 16:26:58 [0x0-0x6f06f].com.google.sketchupfree7[925] /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/manifold.rb:716
driven
PluginStore Author
PluginStore Author
Postby TIG » Wed Jan 27, 2010 6:15 pm
driven wrote:TIG, no dialogs and I get this that I haven't had before,
I haven't changed that ? It's trying to map textures back onto triangulated faces properly ??? I'll investigate...
Avoid textured faces for now...
User avatar
Global Moderator
Postby driven » Wed Jan 27, 2010 6:30 pm
TIG,
I have had it before, I just went back through the logs and buried in there is the same report, at least for 1.3, 1.4
driven
PluginStore Author
PluginStore Author
Postby driven » Wed Jan 27, 2010 6:55 pm
A re-start found the dialogs, so 1.3 would not pass this (which is correct) due to more then 2 faces per edge, also reversed faces made it through...
driven
PluginStore Author
PluginStore Author
Postby driven » Wed Jan 27, 2010 11:03 pm
d12dozr wrote:...easier than me starting over from scratch :)
Here's a semi complex one that sort of worked with 1.2, but on 1.3 it would only hang....
I'm about to re-test it on my Mac and a PC comparison would show up if some of the problems are me or not...
If it fails first try, manually orient the reversed faces, then remove the internal disc on the bottom run and try again.
it 'should' remove the internal overlap on the bottom 2/3 twists (1.2 left these intact)
it might still make a hash of the end, Fredo's bend tool can be unkind to meshes.
hanger_maybe.skp
driven
PluginStore Author
PluginStore Author
Postby hsjzyangbin » Thu Jan 28, 2010 9:24 am
HI,TIG,is there have some differece between trigulaer face .rb and Manifold v1.4?
hsjzyangbin
Postby TIG » Thu Jan 28, 2010 10:38 am
hsjzyangbin wrote:HI,TIG,is there have some difference between trigulate face .rb and Manifold v1.4?
If the read the notes in the first post... 'manifold' does triangulate faces at the end, BUT it does so much more - it tidies the shapes to remove faceless edges, remove flaps, remove disconnected geometry, heal holes and very small faces, orient faces and then triangulates, and finally 'reports' on what it's done.
It is an attempt to automate the making of a 'manifold' surfaced mesh that will work properly when it's exported for use in a 3D printer, and some other 3D apps...
It's still under development...
User avatar
Global Moderator
Postby otb designworks » Thu Jan 28, 2010 3:20 pm
You are the Man, TIG!
This plug in is a great great idea.
Cheers, Chuck
Cheers, Chuck
OTB Designworks is on Youtube
otb designworks
Re: [Plugin] Manifold v1.5
Postby TIG » Fri Jan 29, 2010 5:43 pm
Here's v1.5 viewtopic.php?p=218691#p218691
Various adjustments on speed, reporting, lingvo etc...
Still need to sort out 'pretzels' better... :roll:
User avatar
Global Moderator
Postby driven » Fri Jan 29, 2010 5:53 pm
Cheers TIG,
I was just logging in to say, I've set up one of my Macs, with a fresh instal and only a few basic rubies that I've triple checked are clean. Just to test Manifold. That way any log errors on my system console should be easily spotted, and you posted this, so excellent timing. I'll keep you informed. john
driven
PluginStore Author
PluginStore Author
Postby driven » Fri Jan 29, 2010 6:17 pm
Fresh off the press, No error messages in console, had lots of info zipping through, had Pass dialogs, so all seems to be functioning, but all passed have inner faces? john
EDIT: I did the first with Transparency ON, so just in case it wasn't see the faces I re-did with Trans OFF, but the faces are still inside and the orientation is different from first
driven
PluginStore Author
PluginStore Author
Postby TIG » Fri Jan 29, 2010 6:19 pm
driven
Can you PM that file so I can test it too... :?:
Don't bother - I made one like it and I see the problem :roll:
User avatar
Global Moderator
Re: [Plugin] Manifold v1.6
Postby TIG » Sat Jan 30, 2010 5:07 pm
Here's v1.6 viewtopic.php?p=218691#p218691
Face making error fixed, 3-edge faces removal improved.
Sub-groups/Instances now within Group removed & reported.
Error reporting improved.
User avatar
Global Moderator
Postby driven » Sat Jan 30, 2010 6:47 pm
Hi TIG,
I think it's working really nicely now, lot faster, plenty of info, it still passes inner faces that don't necessarily break the 1 edge, 2 face rule.
There are only two '4-faced' edges in the original drawing and if a BoolTool, VWS, or a manual delete is done first, (as it should be) than manifold does a speedy and detailed correction, orientation and triangulation. I'm wondering if a simple pre-flight check that states, "I'm not doing this-there are inner faces highlighted that you need to remove first" or something less long winded, might not be in order. I'll PM you some other screen shot's as well.
Am I the only one testing this????
driven
PluginStore Author
PluginStore Author
Re: [Plugin] Manifold v1.7
Postby TIG » Sun Jan 31, 2010 3:05 pm
Here's v1.7 viewtopic.php?p=218691#p218691
It now does a quick initial 'Health-Check' on the group and a dialog reports - it also temporarily shows any probable 'internal faces' in Magenta and faces adjoining probable 'holes' in Cyan etc...
If it's a lot of errors you can answer 'No' to not continue and then attempt to fix them manually, before trying again - or answer Yes to continue if there are no problems identified, or answer Yes anyway to try and auto-fix any problems [with a final error report and red/green/.../-.- highlighting in an "error-group"]...
:geek:
User avatar
Global Moderator
Postby driven » Sun Jan 31, 2010 3:16 pm
TIG....do you sleep???
driven
PluginStore Author
PluginStore Author
Postby otb designworks » Sun Jan 31, 2010 3:18 pm
any chance this can be adjusted to not triangulate all faces? It is very useful for me to be able to clean up a model that I have carefully constructed so that I have consistent quads everywhere, which is what I need for sending into ZBrush for further detail modeling.
I know that Cheetah, too, triangulates everything when performing boolean functions, which I also find annoying. It is this, more than anything, that keeps me away from automated solutions for ensuring manifold meshes.
Cheers, Chuck
Cheers, Chuck
otb designworks
Postby TIG » Sun Jan 31, 2010 3:31 pm
OTB Designworks wrote:any chance this can be adjusted to not triangulate all faces? It is very useful for me to be able to clean up a model that I have carefully constructed so that I have consistent quads everywhere, which is what I need for sending into ZBrush for further detail modeling.
Cheers, Chuck
I'll add triangulation as a closing option ? :geek:
User avatar
Global Moderator
Postby otb designworks » Sun Jan 31, 2010 3:38 pm
That would be quite useful, for me.
Now, how about a plug-in that cuts a model up into beautifully perfect quads? I'd pay cold hard cash for that one, too.
Thanks TIG!
Cheers, Chuck
otb designworks
Re: [Plugin] Manifold v1.8
Postby TIG » Sun Jan 31, 2010 3:41 pm
Here's v1.8 viewtopic.php?p=218691#p218691
Triangulation is now an option near the end - Answer Yes to do it... :geek:
User avatar
Global Moderator
Postby driven » Sun Jan 31, 2010 3:47 pm
TIG,
slight problem, when choosing Yes to continue after an 'initial health check' pass, it zapps everything even unselected groups.... both on badly grouped and clean booled groups, I'll do some more and send pics.
I'll see if it still happening in 1.8
driven
PluginStore Author
PluginStore Author
Postby TIG » Sun Jan 31, 2010 4:03 pm
driven wrote:TIG,
Odd - I can't get it to error at all... :? Please 'feedback'.............
User avatar
Global Moderator
Postby driven » Sun Jan 31, 2010 4:18 pm
TIG wrote:Odd - I can't get it to error at all... :? Please 'feedback'.............
been trying to up load pics, site is slow, pics to follow
it's on both machines, 1.7 and 1.8
3 groups from Draw Shapes Menu, grouped, manifold_1.7and8, both give a pass
Yes to continue....zapppp
Same 3 groups, exploded then regrouped is running as predicted on other mac at the moment, this site is slow from this machine....
driven
PluginStore Author
PluginStore Author
Postby driven » Sun Jan 31, 2010 4:26 pm
driven
PluginStore Author
PluginStore Author
Postby driven » Sun Jan 31, 2010 4:28 pm
something screwy going on with uploads, sorry it makes thing disjointed
driven
PluginStore Author
PluginStore Author
Postby TIG » Sun Jan 31, 2010 4:33 pm
I get no problems... but can you PM me that model asap, so that I have exactly the same starting point... :?
The 'no problems found' report is on any geometry that hasn't already be relegated to 'red'... looks like everything is removed BEFORE we do the health check - it's not a group inside a group is it ?
User avatar
Global Moderator
Postby driven » Sun Jan 31, 2010 4:51 pm
TIG,
they were groups inside a group, and got a pass, (they are all manifold) it only zaps them if you say YES,
the same thing happened after I BoolTool'd all 3 groups into 1 group, initial pass (as it should), but zapped if you choose YES, I only got the RED on that one drawing, I'll re run the first set-up and post the if no red is shown again.
I have just set a Bool'd group run that Passed initial and didn't blitz the drawing when I hit YES
It's on a pair of torus + geodasic sphere bool group, and it is running.
original set ungrouped, but not booled
driven
PluginStore Author
PluginStore Author
by Ad Machine » 5 minutes ago
Ad Machine
Robot
PreviousNext
Return to Plugins
Who is online
Users browsing this forum: alvarezalberto1975, digitalium, Pedrucci, sketchucation101, thuckientruc and 11 guests
Visit our sponsors:
