[Plugin] Eclate_Deplace (fragmentation-exploded view)
Thank you for this plugin.
0.3.1 Decimal point fixed
Congratulation - welcome to the Ruby Brotherhood
In the English version dialog popout substitute "Group|Component|Both" for the untransalted French version to get it to work... -
Ah Damned! Thx (fixed)
With esperanto that will be more easy just one language -
Ah Damned! Thx
With esperanto that will be more easy just one languageThere is already one World language - unfortunately it's English [and it's American too!]
Il y a déjà une langue du monde - c'est malheureusement anglais [et aussi c'est Américain!]
Estas jam unu Monda lingvo - bedaŭrinde ĝi estas Angla [kaj tio estas Amerika ankaŭ!]
Good Works Pilou...............for the translation OF COURSE!!!
:facepunch: :facepunch: :facepunch: :facepunch: :facepunch: :facepunch: :facepunch:
c.plassais
@C.plassais: sorry a very hard hyperactive end of year
See you soon next year!
[flash=500,405:1je4n8r4]http://www.youtube.com/v/o9698TqtY4A[/flash:1je4n8r4] -
Oh Guys, I miss a lot beeing on travel for the last 15 days.
Excellent work, I 'll use it very fast for technical explanations
MALAISE
great plugin, thanks. if you could rename this "Exploded View" or "Exploded Model Viewer" or similiar, it would be much more precise and easier to find.
Edit the script with a plain text editor - like Notepad.exe [osa] - and replace any 'French' text inside "" with your 'English' translation[s]. Keep a copy in case you screw up...
You can adjust a script to say whatever you want.... -
yes, i was refering to the thread title. i don't think anyone searching for an "exploded view" would ever find it currently.
He got a point..
it would make it a little more clear what the plugin is for as well.
Done and tested with the search Engine
No someone can find it by the title and by your post -
Anyone experiencing Bugsplats with SU7.1 and this plugin?
Haven't used since last SU update now it Bugsplat everytime. I've attached the model if anyone want to see if it's just me?
I know i have the components nested in a component but use this plugin when not nested
Hello,
Same problem for me with SU7.16860, I get a Bugsplat each time I try to use it.
Any idea?
Rgds,
Stephan
No bugsplat to me, although i do not understand why some groups stay glued together..
In this example there are only first-class groups:
