[Plugin] Eclate_Deplace (fragmentation-exploded view)
@daniel s said:
Great plugin But Iยดm having a problem...
Iยดm using centimeters and in "Amplitude translation" I put 100:
Look that the final translation is 254.
Seems that the plugin works only in inches??Daniel S
Daniel
I sent version 0.2 to Pilou
This version supports the model's current unit
it's heavy, but it works.
I look for the other problem you mentionedChristophe
Update version v 0.3
Units problem resolved
Model from ZXT at 3Dwarehouse
Maybe you must explode first levels of components, depending of the management
[attachment=0:22cevkep]<!-- ia0 -->2008 Bugatti Veyron 16.jpg<!-- ia0 -->[/attachment:22cevkep]A-aaaaaaaaaaaaaaa! Stop making this GREAT PLUGINS!!! Please, leave me some time for eating and sleeping!!
:+1: :+1:
Thank you for this plugin.
0.3.1 Decimal point fixed
Congratulation - welcome to the Ruby Brotherhood
In the English version dialog popout substitute "Group|Component|Both" for the untransalted French version to get it to work... -
Ah Damned! Thx (fixed)
With esperanto that will be more easy just one language -
Ah Damned! Thx
With esperanto that will be more easy just one languageThere is already one World language - unfortunately it's English [and it's American too!]
Il y a dรฉjร une langue du monde - c'est malheureusement anglais [et aussi c'est Amรฉricain!]
Estas jam unu Monda lingvo - bedaลญrinde ฤi estas Angla [kaj tio estas Amerika ankaลญ!]
Good Works Pilou...............for the translation OF COURSE!!!
:facepunch: :facepunch: :facepunch: :facepunch: :facepunch: :facepunch: :facepunch:
c.plassais
@C.plassais: sorry a very hard hyperactive end of year
See you soon next year!
[flash=500,405:1je4n8r4]http://www.youtube.com/v/o9698TqtY4A[/flash:1je4n8r4] -
Oh Guys, I miss a lot beeing on travel for the last 15 days.
Excellent work, I 'll use it very fast for technical explanations
MALAISE
great plugin, thanks. if you could rename this "Exploded View" or "Exploded Model Viewer" or similiar, it would be much more precise and easier to find.
Edit the script with a plain text editor - like Notepad.exe [osa] - and replace any 'French' text inside "" with your 'English' translation[s]. Keep a copy in case you screw up...
You can adjust a script to say whatever you want.... -
yes, i was refering to the thread title. i don't think anyone searching for an "exploded view" would ever find it currently.
He got a point..
it would make it a little more clear what the plugin is for as well.
Done and tested with the search Engine
No someone can find it by the title and by your post
