RPS3D PDF portable
RPS3D PDF portable
Postby Burkhard » Fri Dec 28, 2007 7:55 pm
I`m interested to see a portable version of RPS 3D PDF.
Is it possible?
Burkhard
User avatar
Burkhard
Premium Member
Premium Member
Re: RPS3D PDF portable
Postby richcat » Sat Dec 29, 2007 10:42 pm
Hi Burkhard
By portable I presume you mean could it ported to be made to work on a Mac.
I've had a look at the RPS Forum and RPS Wiki, but no luck there.
I'm sure Al Hart will soon see this and give you a definitive answer as he is really the only person who could tell you. ;)
Richcat
richcat
Postby Burkhard » Sun Dec 30, 2007 11:41 am
Not really MAC, more to take it with me on an USB stick for using it at different situations. ( No installation on a desktop PC ). :P Thanks for the response.
User avatar
Burkhard
Premium Member
Premium Member
Postby Burkhard » Thu Jan 03, 2008 11:11 pm
Get it! solved :o
User avatar
Burkhard
Premium Member
Premium Member
Postby richcat » Fri Jan 04, 2008 11:41 am
Hi Burkhard
If you don't mind I have copied your original post over to the RPS forum in the 3D PDF Forum
Richcat ;)
richcat
Postby Al Hart » Fri Jan 04, 2008 4:07 pm
Re MAC Version
RPS does not plan any MAC versions of its Plug-ins at this time.
Al Hart
IRender nXt from Render Plus
User avatar
Al Hart
PluginStore Author
PluginStore Author
Postby Al Hart » Fri Jan 04, 2008 4:18 pm
Re MEMORY STICK
This should be possible. You should be able to copy the contents of C:\Program Files\Render Plus Systems\3D_PDF onto a memory stick, place it into a computer and run skp_to_3d_pdf.exe from the memory stick.
We will give it a try.
However, I can think of a few problems.
1. Some Visual Studio DLL's may not be on the target computer.
If we discover what they are, then they can be copied onto the memory stick and that may work (or we may have to create a new release of 3D PDF with the missing DLLs)
2. You will not be licensed to run RPS 3D PDF on the target machine.
I don't know how we will solve this problem. We can discuss it after you get the comcept working properly.
There are 2 other solutions to the general problem.
1. You can "remote log in" to your own computer, which is licensed for RPS 3D PDF from the client machines, run RPS 3D PDF remotely, load a file from the client machine and process it.
2. You can bring your portable computer with you to the client location, put the .SKP file from the client machine onto your portable, and use your portable to create the PDF file.
Al Hart
User avatar
Al Hart
PluginStore Author
PluginStore Author
Postby richcat » Fri Jan 04, 2008 7:20 pm
Thank Al :)
Richcat
richcat
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Extensions & Applications Discussions
cron
Who is online
Users browsing this forum: No registered users and 0 guests
Visit our sponsors:
