[Plugin] SmartPushPull v0.26 (05 nov)
Postby a4chitect » Thu Nov 05, 2009 12:12 am
I have always wanted this feature, and since it didn't appear as of now, I have decided to dedicate few hours to it. It is far from perfect but works in many cases.
v0.26 (05 nov)
5. Tab key toggles between normal Push/Pull and Smart Push/Pull behavior
v0.25 (05 nov)
ADDED:
2.vcb (aka "Measurements") shows the offset distance and typing custom value sets the offset
6.easier to set the distance with the mouse
7.single click confirmation
8.works inside unopen groups
v0.11 (05 nov)
very minor update - it makes the push/pull in more cases then 0.1 but still fails to create non planar side faces in those v0.1 problematic scenarios
v0.1 (04 nov)
Available/In-progress/Missing functionality LIST:
0.Push/Pull faces in their natural shape and mesh context
1.ability to toggle between additive push-pull (similar to sketchup push/pull + ctrl), normal push-pull and target face only (great for solid subdivision)
2.ability to control offset via the VCB
3.nicer and better algorithm (to clean unnecessary original lines, to correctly offset all scenarios)
4.toolbar with icon and cursor icon
5.ability to toggle the standard push/pull behavior
6.better dynamic offset interface - at the moment it doesn't work right and you have to change camera position to allow for setting the offset (ecuadorian)
7.simple click to confirm the action instead of the doubleclick (thomthom)
8.work inside unopen groups
9.code cleanup!!! and commenting
any help with the above is appreciated
HUGE THANKS TO FREDO6 for leaving his code unencrypted, most of the dynamic offset code is from him
24
a4chitect
PluginStore Author
PluginStore Author
Re: [Plugin] SmartPushPull v0.1 (04 nov)
Postby Chris Fullmer » Thu Nov 05, 2009 12:14 am
That's great, I'll try to check it out later. Thanks!
User avatar
SketchUp Team
SketchUp Team
Postby DIEGO-RODRIGUEZ » Thu Nov 05, 2009 12:26 am
incredible. excellent tool, thank you very much for sharing
DIEGO-RODRIGUEZ
Banned
Postby Ecuadorian » Thu Nov 05, 2009 12:27 am
Getting rid of the extra material is a lot easier than trying to do this manually, thank you! :D I see that to clearly define the direction of the push/pull, you need to orbit your view a little bit.
Ecuadorian
Postby utiler » Thu Nov 05, 2009 1:01 am
WOW!!! I can't wait to try this.....! :berserk:
love it mate, very cool!!!!! :bounce: :bounce:
purpose/expression/purpose/....
User avatar
utiler
Top SketchUcator
Postby Mike Lucey » Thu Nov 05, 2009 2:20 am
Thanks a4chitect for the script also for the very clear explanatory graphic.
Mike
User avatar
Mike Lucey
Mayor
Postby gavvy » Thu Nov 05, 2009 2:30 am
a4chitect
:thumb:
your plugins always give me a :o shock
gavvy
PluginStore Author
PluginStore Author
Postby Stinkie » Thu Nov 05, 2009 7:33 am
Brilliant. Thank you.
User avatar
Stinkie
Postby thomthom » Thu Nov 05, 2009 8:33 am
Sweet! :thumb:
User avatar
PluginStore Author
PluginStore Author
Postby publied » Thu Nov 05, 2009 8:48 am
nice and smarty. thank you.
publied
Postby dylan » Thu Nov 05, 2009 9:06 am
That is a definite winner, thanks :thumb:
dylan
Postby rv1974 » Thu Nov 05, 2009 9:10 am
Finally! Shiny!
Dear ruby coders please help arc4tect to refine this tool (long awaited and really usefull- a real pearl in the ruby
slag)
rv1974
Postby cather009 » Thu Nov 05, 2009 9:13 am
Hi Everyone,
How can i use this plugin? i already download it.
cather009
Postby thomthom » Thu Nov 05, 2009 9:22 am
cather009 wrote:Hi Everyone,
Tools->SmartPP
Extrude the face and doubleclick to finish.
btw, a4chitect: why do you have to doubleclick? Why not normal click like the regular PP?
User avatar
PluginStore Author
PluginStore Author
Postby thomthom » Thu Nov 05, 2009 9:25 am
I really like this plugin. Really looking forward to see how it develops.
I tried it on some simple shape and it worked most of the time. But occasionally it doesn't - not sure why, can't tell the different between what works and what doesn't.
Code: Select all
Error: #<ArgumentError: Points are not planar>
C:/Programfiler/Google/Google SketchUp 7/Plugins/A4_smartpushpull.rb:205:in `add_face'
C:/Programfiler/Google/Google SketchUp 7/Plugins/A4_smartpushpull.rb:205:in `smartPP'
C:/Programfiler/Google/Google SketchUp 7/Plugins/A4_smartpushpull.rb:184:in `each'
C:/Programfiler/Google/Google SketchUp 7/Plugins/A4_smartpushpull.rb:184:in `smartPP'
C:/Programfiler/Google/Google SketchUp 7/Plugins/A4_smartpushpull.rb:79:in `onLButtonDoubleClick'
I've attached a sample model which caused the error. I was trying to SPP the face I highlighted orange.
User avatar
PluginStore Author
PluginStore Author
Postby a4chitect » Thu Nov 05, 2009 10:15 am
thanks for all the cheers! will look into all the requests but please be patient. I'm not abandoning the development :)
thomthom: I'm aware of this bug - it is all due to almost no exception-catching code
a4chitect
PluginStore Author
PluginStore Author
Re: [Plugin] SmartPushPull v0.11 (05 nov)
Postby kwistenbiebel » Thu Nov 05, 2009 11:15 am
Wow, thank you a4chitect. :thumb:
You know, I never use the default scale tool anymore as Fredo's scale (and taper) tool is much better.
Your 'smart push pull' concept has the same potential to knock the old default Sketchup PushPull out of business.
Wonderful concept man!
I hope you will keep on working on it as this can become a life saving gem.
Thanks again.
kwistenbiebel
Postby plot-paris » Thu Nov 05, 2009 11:34 am
kwistenbiebel wrote:Your 'smart push pull' concept has the same potential to knock the old default Sketchup PushPull out of business.
1+ absolutely fabulous tool, a4chitect. thanks a lot.
User avatar
plot-paris
Postby j_forrester » Thu Nov 05, 2009 11:59 am
Great tool. Just one idea maybe, when you select the face you want to extrude, you get the option of deleting the original lines to clean it up. Would be a nice addition. but still a great plugin nether the less.
j_forrester
j_forrester
Postby utiler » Thu Nov 05, 2009 12:11 pm
thomthom wrote:btw, a4chitect: why do you have to doubleclick? Why not normal click like the regular PP?
I thought the same thing, TT.
User avatar
utiler
Top SketchUcator
Postby rv1974 » Thu Nov 05, 2009 1:08 pm
Hi ar4itect I think your 'to do' list misses multiple adjasent\non adjacent faces push-pull.
It'd be special case of Fredo's JPP. BTW While ago I asked him to implement it but unfortunatly it didn't happen.
rv1974
Postby plot-paris » Thu Nov 05, 2009 1:20 pm
oh, and to make it the almighty super tool, you could enalbe push/pull of more than one selected face simulaneously, making it a lot faster to do extrude several faces with the sam distance (something that I always wanted the push/pull tool to be capable of) :)
User avatar
plot-paris
Postby erikB » Thu Nov 05, 2009 4:06 pm
a4chitect,
very usefull ruby, well done !
For me the possibilty to control the offset by means of the VCB is the one thing that is missing to make it a true replacement for the 'standard' push pull tool. (But it is already in the to do list !! ;) )
Thanks for sharing,
erikB
User avatar
erikB
Postby david_h » Thu Nov 05, 2009 4:31 pm
okay . .this is total awesomenicity. Any possible way it could be written to be accessed from a right-click like JPP? That would just be cherry.
THx,
D
If I make it look easy. . .then it probably is.
User avatar
david_h
Top SketchUcator
Postby MALAISE » Thu Nov 05, 2009 5:55 pm
Yeee! Thanks a lot for this plugin :thumb:
MALAISE
User avatar
MALAISE
Re: [Plugin] SmartPushPull v0.26 (05 nov)
Postby matteo » Fri Nov 06, 2009 1:24 am
oooh!
“The one fact about the future of which we can be certain is that it will be utterly fantastic” – Arthur C Clarke
“The one fact about ruby coders of which we can be certain is that next ruby plugin will be utterly fantastic” – Matteo Bignozzi
thank you a lot arc4tect
matteo
Postby EscapeArtist » Fri Nov 06, 2009 4:05 pm
Fantastic tool. I've been wishing for something like this for a while.
Nice job, I'm looking forward to any improvements you make.
User avatar
EscapeArtist
Top SketchUcator
Postby dtrarch » Fri Nov 06, 2009 4:54 pm
a4
Simply just a :berserk: WOW :berserk:
Thank you
dtr
dtrarch
Premium Member
Premium Member
Postby CADAddict » Fri Nov 06, 2009 6:40 pm
Very nice,
I noticed the original lines remain, hahe you though of using smething like "remove cplanar edges" to eliminate thos elines after the push/pull operation?
Great job anyways!
CADAddict
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Next
Return to Plugins
cron
Who is online
Users browsing this forum: AK99, Dudstar5000, ETuru, Google Bot, Majestic-12 Bot, Quensaring, swarma100 and 22 guests
Visit our sponsors:
