[Plugin] Extended Views v1.2 UPDATE May 23, 2013
Yeah Aces, thats not possible with Ruby.
Also, a HUGE thing I forgot to mention is that I don't think this plugin will work with anything before version 7. I'm pretty sure that the trick I am using in this plugin is new to version 7. Version 6 might still align to the original axis. Sorry, nothing I can do about it. I'll test to confirm though,
EDIT: Confirmed, it doesn't work with version 4,5,6 or earlier. Just version 7. Sorry Pilou and any other SU6/5 devotees!
still can't believe it
NOTE: Fails miserably inside of components
I'll have to think that through a little better. Plus I noticed that it is not compatible with organizer. so if someone tries to use organizer on this first version, the icons will not appear correctly. I'll fix that in the next maintenance release.
Wow, ok I just checked it out and it crashed SU quickly if your inside a group or component. So i've removed the plugin for now. If I can get it working, I'll post it again later.
UPDATE!
OK! I think I got it working inside of groups and components now. Sorry about that. hopefully I didn't make you lose too much work when it crashed!
So its a new updated version in the first post now. I wouldn't dream of asking anyone to do it, but if someone WANTED to make some nice icons, I wouldn't object! (seriously, its probably not that popular of a plugin though. So it might not be worth the effort).
Don't worry; I had no progress in a model. I always see what's going to make a plugin crash before I use it, just incase. That way, no unexpected surprises. In fact, other than the group and component thing, your plugin seems to work fine; even while other plugins and tools are being used, or loading.
... Also, how to you embed Jing videos in the forum????? I've been trying to forever!
I noticed the more I use the plugin, the slower the response is to the ISO view. This slow down even affects the Sketchup views.
Thanks for all your work on scripts.
Ken
@Ken - So is it a little slow down, or major? So far I am unable to reproduce anything. It might be caused by increasing geometry as you work, making the plugin work a little slower. But that shouldn't affect the regular views. If anyone else sees it, or has any thoughts, let me know!
@BTM - Good, glad I didn't break anything. As for videos, the videos i make are flash videos and I host them on my webserver. So I use the "Flash" button in the post creation page.
[flash=800,600]http://www.myurl.com/my_vide.swf[/flash]
Thats what it looks like. If you are doing a youtube video, you have to dig through the "embed" code they give you to find the url, but otherwise it works exactly the same. Simon LeBon created a big thread with VERY detailed inscrutctions how to do it too. It was quite informative. Search for it, I don't remember if it was in the corner bar or the sketchup main forum, or possibly the tutorials forum.
Thanks everyone for testing/using these plugins. I know some of them are sort of specialized, but its great to have people download and use them. Thanks!
BTM, have a read through this: http://www.sketchucation.com/forums/scf/viewtopic.php?f=79&t=10103&st=0&sk=t&sd=a&hilit=video
Ah, Standard View as they should be.
Yeah, really! If only this fixed SU's inabilty to easily print to scale from a non standard view.
chris for PRES! i always wanted SU to align to my new axis, wow thanks
thank alot chris..
a little question, would it be possible
to add "custom" points of views ?
something like self configure able points of view (Camera positions)?hope it gets clear, what i mean..
respect!
@xymox said:
thank alot chris..
respect!
Wouldn't you just set up Scenes for that?
thanks for the plugin Chris
its Views as they should be
just one question is it possible to make a button to toggle between perspective view and parallel projection? So you dont need to go throgh the menu all the time.
that would be so nice.Thanks in advance!
You could assign a keyboard shortcut for that if you use it that often.
I do 'shift+P'... -
Will I downloaded Jing to record what was happening. However, the problem seems to have been an aberration. Right now I cannot get it to repeat.
It was a major slow down.It would take the ISO view over ten seconds to respond. I wasn’t modeling, just using a small model for testing. Maybe something else was going on. Will keep Jing in the standby mode.
Thanks for your quick reply.
Ken
Very cool, Chris... hey while you're at it, how about adding the 3 other ISO views - SW, NW, & NE?
